hello every one.
I am going to learn the transmissibility in standing human body using
anybody.well known that attenuation must be emerged. I have add initial
motion on the standing model,but I couldn’t find attenuation in the
study.
what should I do?
Hello Yueningma
I don’t think it is possible to do what you are planning on. If what
you want to do is to apply an oscillating movement one place and see
how that affects the body somewhere else? then this is not possible to
calculate using inverse dynamics, i.e. AnyBody. I am not sure if I
understand you correctly?
Christian, AnyBody Support
— In anyscript@yahoogroups.com, “yueningma” <yueningma@…> wrote:
> hello every one.
> study.
> what should I do?
hell Christian.
thanks for your help.
I fairly add an oscillating movement one place and see
how that affects the body somewhere else. If possible, could I use
anybody to analyze the transmissibility?
waiting for your reply
best regards
Yueninig
wrote:
> Hello Yueningma
to
> Best regards
> — In anyscript@yahoogroups.com, “yueningma” <yueningma@> wrote:
> > hello every one.
using
initial
the
> > study.
> > what should I do?
Hi Yueninig
The problem is if you add fast movements to the body then that means
in inverse dynamics that the muscles have to move fast, i.e. the model
tries to move the body in the same oscilating way. I can’t find a good
way of doing what I think you would like to do. Could you explain a
bit more what exactly you were thinking to do?
> hell Christian.
> best regards
> Yueninig
> wrote:
> > Hello Yueningma
> to
> > Best regards
> > > hello every one.
> using
> initial
> the
> > > study.
> > > what should I do?
Hi Christian!
what I want to do is a standing model with vertical vibrating
conditions by anybody. According to it, I 'd like to get the
transmissibility of vibrations,transformation of some special muscles
and so on.
So far as I know, AnyBody modeling system has the
clacss “AnyMuscleModel3E” with some parameters. What I want to do is
by using this class to set up a model and learn about the vibrate
transimissibility. Could it be done?
Wish you a good weekend.
yuening, polyu
wrote:
> Hi Yueninig
model
good
> Best regards
> > hell Christian.
use
> > best regards
> > Yueninig
> > wrote:
> > > Hello Yueningma
what
and see
possible
> > to
if I
> > > Best regards
wrote:
> > > > hello every one.
body
> > using
add
> > initial
in
> > the
> > > > study.
> > > > what should I do?
Hi Yuening
This problem is not so well suited for the AnyBody modelling system, I
believe.
I am not entirely sure what you mean by transmissibility?, but if you define
the transmissibility as a function of input motion and output motion, then
it can not be done in AnyBody I guess. This is because that the input to the
model is the motion, so the motion will always stay as it has been defined
in the input. This will make the transmissibility impossible to calculate?.
Please if possible try to explain more about what you would like to
calculate? Frequency range etc.
Of yueningma
Sent: 03 November 2007 10:55
Subject: [AnyScript] Re: About using anybody to learn the transmissibility
Hi Christian!
and so on.
yuening, polyu
wrote:
> Hi Yueninig
model
good
> Best regards
> > hell Christian.
use
> > best regards
> > Yueninig
> > wrote:
> > > Hello Yueningma
what
and see
possible
> > to
if I
> > > Best regards
wrote:
> > > > hello every one.
body
> > using
add
> > initial
in
> > the
> > > > study.
> > > > what should I do?
