My name is Robert Price, I’m from the University of Washington in Seattle. I’m
very new to
AnyScript and I am attempting to modify the Rancho Wheelchair Demo to run with
MoCap
data collected in our lab. I’ve been successful so far in switching the marker
set from
what’s in the demo to a marker set that corresponds to what we used. I’m now
trying to
adapt the driver section to move the shoulder via our acromial marker. Below is
the driver
code snippet I’ve adapted. The commented out section is what appeared
originally and is
replaced by my attempt to drive the segment with a marker. The snippet for the
humerus
is included for reference. When I attmpt to run the model (which compiles
successfully), it
fails on time step zero, some of the error messages are included below. What is
wrong
with what I did and how do I fix it?
Thanks
Robert
//Sterno clavicular joint driver
AnyKinEqSimpleDriver SCDriverLeft ={
// AnyKinMeasureOrg &ref1
=…HumanModel.Interface.Left.SternoClavicularProtraction;
// AnyKinMeasureOrg &ref2
=…HumanModel.Interface.Left.SternoClavicularElevation;
// AnyKinMeasureOrg &ref3
=…HumanModel.Interface.Left.SternoClavicularAxialRotation;
// DriverPos = pi/180*{
// .JntPos.Left.SternoClavicularProtraction,
// .JntPos.Left.SternoClavicularElevation,
// .JntPos.Left.SternoClavicularAxialRotation
// DriverVel = {
// .JntVel.Left.SternoClavicularProtraction,
// .JntVel.Left.SternoClavicularElevation,
// .JntVel.Left.SternoClavicularAxialRotation
// Reaction.Type={Off,Off,Off};
AnyKinLinear Lin={
Ref=0;
AnyRefFrame &ref1 =
Main.Model.HumanModel.Left.ShoulderArm.Seg.Scapula.ArtAcromiocalviculareMarker;
AnyRefFrame &ref2=Main.Model.Markers.Acro.Seg;
MeasureOrganizer={0,1,2};
DriverPos={0,0,0};
DriverVel={0,0,0};
AnyKinEqSimpleDriver LeftLateralEpicondyleDrv ={
AnyKinLinear Lin={
Ref=0;
AnyRefFrame &ref1 =
Main.Model.HumanModel.Left.ShoulderArm.Seg.Humerus.LateralEpicondyleMarker;
AnyRefFrame &ref2=Main.Model.Markers.LEP.Seg;
MeasureOrganizer={0,2};
DriverPos={0,0};
DriverVel={0,0};
Reaction.Type={Off,Off};
Failed to resolve kinematic constraints (final kin. error = 1.177291E+000)
Constraint no. 6 above error tolerance 0.000001, error = 0.000002. - constr. #0
in
‘Main.Model.HumanModel.Trunk.JointsLumbar.L4L5Jnt.Constraints’
Constraint no. 7 above error tolerance 0.000001, error = 0.000003. - constr. #1
in
Constraint no. 8 above error tolerance 0.000001, error = 0.000001. - constr. #2
in
Constraint no. 9 above error tolerance 0.000001, error = 0.000007. - constr. #0
in
‘Main.Model.HumanModel.Trunk.JointsLumbar.L3L4Jnt.Constraints’
Constraint no. 10 above error tolerance 0.000001, error = 0.000016. - constr. #1
in
Constraint no. 11 above error tolerance 0.000001, error = 0.000002. - constr. #2
in
Constraint no. 12 above error tolerance 0.000001, error = 0.000021. - constr. #0
in
‘Main.Model.HumanModel.Trunk.JointsLumbar.L2L3Jnt.Constraints’
Constraint no. 13 above error tolerance 0.000001, error = 0.000049. - constr. #1
in
Constraint no. 15 above error tolerance 0.000001, error = 0.000044. - constr. #0
in
‘Main.Model.HumanModel.Trunk.JointsLumbar.L1L2Jnt.Constraints’
