Adding muscles to BodyModel_Mus3E
Following the previous messages about foot model i decided to try the
one segment model in anybody and see if i can get data i need.
I investigated the Gait3D model in anybody and understood very well
the code for it but i have some more questions on it.
I want to add muscles and ligaments around the ankle and wanted to ask
you how can I do it ? and in which file ?
What I didn’t understand too, is how we are putting the x y z
coordinates in modeling. I know we are defining a global reference
with coordinates { 0, 0, 0 } but i m not able to know how i define
exactly the muscles in that frame myself.
One other thing, i have read that I can see the ankle joint forces. I
have found the folder Ankle joint when i m running the simulation but
how can i see the forces? because inside this folder there is
positions velocities and acceleration. Is there way to investigate the
forces in the ankle joint itself ?
Thanks
Mike
Hi Mike,
To add muscles and ligaments you first need to define the origin and
insertion (optionally via points) of each muscle. This must be done
by adding AnyRefNode in the corresponding segment folder, foot and
shank in your case located in Brep/Aalborg/Leg3D/Seg. Then add the
muscles in the files …/Leg3D/MusWithNames.
Concerning the coordinate system: there is a global reference frame
but then each segment has is own local frame. You can visualize such
frame by adding an AnyDrawRefFrame in the segment folder. The node of
a segment are defined in the local frame of the segment, so you have
to enter the origin and insertion point coordinates according to
local frame of the segment they belong.
And to visualize the reaction forces on a joint just go in the folder
you already found (…/Jnt/Ankle) after running the simulation. You
will find here a subfolder called Reaction, enter and click Pos, you
will now see the reaction forces in the joint.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “marakilo” <marakilo@…> wrote:
> Hi,
the
ask
I
but
the
> Thanks
> Mike
Hi Mike
There is a few more files you will need to do modifications on in order to
add a muscle to the leg model, these are:
1 Mus.any this is the file defining the muscle, the MusWithNames.any
mentioned in the previous posting is basically doing the same, but it will
also plot the names on the muscles. It is better to use Mus.any because the
other one is not normally used and needs to be switched in if you want to
use it.
2 MusPar.any this is the strength parameters for the three element muscles
ere you need to add the parameters for your muscles
3 MusParSimple.any this is the strength parameters for the constant strength
muscles
Of AnyBody Support
Sent: 14 March 2008 09:59
Subject: [AnyScript] Re: Adding muscles to BodyModel_Mus3E
Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
Hi Sylvain
I am trying to read and understand the code in Brep/Aalborg/ Leg3D/Seg and I
want can see that there are a lot of nodes on the whole foot which hasn't been
used in the BodyModel_Mus3E and which can help me in my model.
I wanted to ask you for example on the ankle joint reference node:
AnyRefNode AnkleJoint = {
sRel = .Scale ( {0.06, 0.06, ....Sign*0.0});
#include "../DrawSettings/JointAxesProximal.any"
What does ...Sign0.0 means ? I have seen in it a lot in this file ...Sign-0.01
...Sign*0.025 What should I understand by Sign , the number , and the
multipilcation.
Defining the nodes in the foot they almost all include sRel and ARel which i
understand but in the ankle joint I didint understand what do we mean by
maybe becuase i didint find the file myself. Can I get explanation of what this
statment will do ?
Mike
----- Original Message ----
Sent: Friday, March 14, 2008 8:58:30 AM
             Hi Mike,
shank in your case located in Brep/Aalborg/ Leg3D/Seg. Then add the
muscles in the files …/Leg3D/MusWithNames .
you already found (.../Jnt/Ankle) after running the simulation. You
Sylvain, AnyBody Support..
--- In anyscript@yahoogrou ps.com, "marakilo" <marakilo@.. .> wrote:
> Hi,
the
ask
> What I didn't understand too, is how we are putting the x y z
I
but
the
> Thanks
> Mike
#ygrp-mkp{
border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;}
#ygrp-mkp hr{
border:1px solid #d8d8d8;}
#ygrp-mkp #hd{
color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;}
#ygrp-mkp #ads{
margin-bottom:10px;}
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
color:#0000ff;text-decoration:none;}
#ygrp-sponsor #ygrp-lc{
font-family:Arial;}
#ygrp-sponsor #ygrp-lc #hd{
margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;}
#ygrp-sponsor #ygrp-lc .ad{
margin-bottom:10px;padding:0 0;}
 #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;}
#ygrp-mlmsg table {font-size:inherit;font:100%;}
#ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean,
sans-serif;}
#ygrp-mlmsg pre, code {font:115% monospace;}
#ygrp-mlmsg * {line-height:1.22em;}
#ygrp-text{
font-family:Georgia;
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
padding-top:10px;font-family:Verdana;font-size:77%;margin:0;}
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;}
#ygrp-actbar .left{
float:left;white-space:nowrap;}
.bld{font-weight:bold;}
#ygrp-grft{
font-family:Verdana;font-size:77%;padding:15px 0;}
#ygrp-ft{
font-family:verdana;font-size:77%;border-top:1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom:10px;}
#ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrp-reco #reco-head {
font-weight:bold;color:#ff7900;}
#reco-grpname{
font-weight:bold;margin-top:10px;}
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;}
#ygrp-vital #vithd{
font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp
ercase;}
#ygrp-vital ul{
padding:0;margin:2px 0;}
#ygrp-vital ul li{
list-style-type:none;clear:both;border:1px solid #e0ecee;
#ygrp-vital ul li .ct{
font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri
ght:.5em;}
#ygrp-vital ul li .cat{
font-weight:bold;}
#ygrp-vital a{
#ygrp-vital a:hover{
text-decoration:underline;}
#ygrp-sponsor #hd{
color:#999;font-size:77%;}
#ygrp-sponsor #ov{
padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;}
#ygrp-sponsor #ov ul{
padding:0 0 0 8px;margin:0;}
#ygrp-sponsor #ov li{
list-style-type:square;padding:6px 0;font-size:77%;}
#ygrp-sponsor #ov li a{
text-decoration:none;font-size:130%;}
#ygrp-sponsor #nc{
background-color:#eee;margin-bottom:20px;padding:0 8px;}
#ygrp-sponsor .ad{
padding:8px 0;}
#ygrp-sponsor .ad #hd1{
font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%
#ygrp-sponsor .ad a{
#ygrp-sponsor .ad a:hover{
#ygrp-sponsor .ad p{
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
blockquote{margin:0 0 0 4px;}
.replbq{margin:4;}
________________________________________________________________________________\
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Hi Sylvain
Sorry for missing a part in my previous email.
I wanted to ask you how big is 1 unit in AnyBody ? Is it 1cm ?
Why we are making .Scale for the coordinates ? Are they the real ones ?
Thanks for your reply
Regards
             Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
       __.._,_.___
         Messages in this topic           (2)
         Reply           (via web post)          |
       Start a new topic
                          Messages              |    Files              |
Photos | Links | Database |
Polls | Members | Calendar
       Users of the AnyBody Modeling System help each other create
biomechanical models in the AnyScript language.
   Change settings via the Web (Yahoo! ID required)
   Change settings via email: Switch delivery to Daily Digest | Switch format
to Traditional
     Visit Your Group
     Yahoo! Groups Terms of Use       |
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
  		    		    		    		                2
   New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
Feel better with fiber.
#ygrp-mkp{
#ygrp-mkp hr{
#ygrp-mkp #hd{
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Looking for last minute shopping deals?
Find them fast with Yahoo! Search.
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
Hi Mike
The sign variable is used for shifting between the right and left side. The
body model is always the same for both sides, but the sign variable makes it
possible to mirror the geometry. For the right side the variable will be one
for the left side it will be minus one.
The include statement mentioned, is only used for creating a visual
representation of the joint, nothing else.
-----Original Message-----
Of Mike Arakilo
Sent: 18 March 2008 12:21
Subject: Re: [AnyScript] Re: Adding muscles to BodyModel_Mus3E
Hi Sylvain
I want can see that there are a lot of nodes on the whole foot which hasn't
been used in the BodyModel_Mus3E and which can help me in my model.
...Sign
-0.01 ...Sign*0.025 What should I understand by Sign , the number ,
and the multipilcation.
this statment will do ?
Mike
             Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
g-right:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
122%;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Users of the AnyBody Modeling System help each other create biomechanical
models in the AnyScript language.Yahoo! Groups Links
Hi Mike
There are in principle no units definition in AnyBody, the user has to make
sure that the units provided in the models fits with each other.
That said all models in the repository are based on SI units so geometry are
in meters, forces in newtons, moments in newtons meters etc, I would not
recommend to use any other units.
The .Scale which is put around all srel values makes it possible to scale
these nodes. These nodes can be scaled in different ways, depending on the
scaling law provided in the main file. Please take a look in the
Gait3D.main.any file to see an example on this. If you choose the
ScalingStandard.any file it will not scale the model.
Of Mike Arakilo
Sent: 18 March 2008 12:39
Hi Sylvain
Regards
             Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
       __.._,_.___
       Start a new topic
                          Messages              |    Files              |
format to Traditional
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
g-right:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
122%;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Hi again
I was trying to follow the procedure on adding some ligaments to the model in
Gait3D and i have noticed a mistake in the model itself.
I was trying to add calcaneofibular ligament as a beginning of the process,
working on the right leg as usual i noticed that there is mistake with the model
on the fibula.
The bones are reverse side i.e fibula on the right leg should be on the right
and pointing outwards the body whereas in this model it is on the left and
pointing inside.
I dont know the consequences of all the nodes present for example the lateral
malleolus is strictly affected by the fibula. Is there any solution for
correcting the model ?
Sorry for any inconvenience ...
Regards
Sent: Tuesday, March 18, 2008 12:12:21 PM
Subject: RE: [AnyScript] Re: Adding muscles to BodyModel_Mus3E
             Hi Mike
Gait3D.main. any file to see an example on this. If you choose the
ScalingStandard. any file it will not scale the model.
From: anyscript@yahoogrou ps.com [mailto:anyscript@yahoogrou ps.com] On Behalf
Of Mike Arakilo
Hi Sylvain
Regards
Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
..,._
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
border:1px solid #d8d8d8;font- family:Arial; margin:14px 0px;padding: 0px
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
color:#628c2a; font-size: 85%;font- weight:bold; line-height: 122%;margin: 10px
0px;}
#ygrp-mkp #ads{
margin-bottom: 10px;}
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
color:#0000ff; text-decoration: none;}
font-family: Arial;}
margin:10px 0px;font-weight: bold;font- size:78%; line-height: 122%;}
margin-bottom: 10px;padding: 0 0;}
 #ygrp-mlmsg {font-size:13px; font-family: arial, helvetica, clean,
sans-serif;}
#ygrp-mlmsg table {font-size:inherit; font:100% ;}
sans-serif;}
#ygrp-mlmsg * {line-height: 1.22em;}
#ygrp-text{
font-family: Georgia;
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
padding-top: 10px;font- family:Verdana; font-size: 77%;margin: 0;}
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
clear:both;margin: 25px 0;white-space: nowrap;color: #666;text- align:right; }
#ygrp-actbar .left{
float:left;white- space:nowrap; }
.bld{font-weight: bold;}
#ygrp-grft{
font-family: Verdana;font- size:77%; padding:15px 0;}
#ygrp-ft{
font-family: verdana;font- size:77%; border-top: 1px solid #666;
padding:5px 0;
#ygrp-mlmsg #logo{
padding-bottom: 10px;}
#ygrp-reco {
margin-bottom: 20px;padding: 0px;}
font-weight: bold;color: #ff7900;}
#reco-grpname{
font-weight: bold;margin- top:10px; }
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
background-color: #e0ecee;margin- bottom:20px; padding:2px 0 8px 8px;}
#ygrp-vital #vithd{
font-size:77% ;font-family: Verdana;font- weight:bold; color:#333;
text-transform
:uppercase;}
#ygrp-vital ul{
padding:0;margin: 2px 0;}
#ygrp-vital ul li{
list-style-type: none;clear: both;border: 1px solid #e0ecee;
font-weight: bold;color: #ff7900;float: right;width: 2em;text- align:right;
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
text-decoration: underline; }
#ygrp-sponsor #hd{
color:#999;font- size:77%; }
#ygrp-sponsor #ov{
padding:6px 13px;background- color:#e0ecee; margin-bottom: 20px;}
padding:0 0 0 8px;margin:0; }
list-style-type: square;padding: 6px 0;font-size: 77%;}
text-decoration: none;font- size:130% ;}
#ygrp-sponsor #nc{
background-color: #eee;margin- bottom:20px; padding:0 8px;}
#ygrp-sponsor .ad{
padding:8px 0;}
font-family: Arial;font- weight:bold; color:#628c2a; font-size: 100%;line-
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
blockquote{margin: 0 0 0 4px;}
.replbq{margin: 4;}
http://tools. search.yahoo. com/newsearch/ category. php?category= shopping
         Messages in this topic           (7)
       Start a new topic
                          Messages              |    Files              |
to Traditional
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
  		    		    		    		                3
   New Files
	 Visit Your Group
Yahoo! Search
Find it faster
with Yahoo!
shortcuts.
                                       Y! Messenger
Send pics quick
Share photos while
you IM friends.
                                       Moderator Central
Yahoo! Groups
Get the latest news
from the team.
	 __,_.._,___
#ygrp-mkp{
#ygrp-mkp hr{
#ygrp-mkp #hd{
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Hi Mike
The Leg3D model of the repository which the Gait3D model is using, do not
include the Fibula bone, so I am little confused, but maybe you thought that
the Tibia and Fibula bone geometry file was somehow merged in this model.
I have double checked and the Tibia bone looks ok in the Gait3D model.
In order to add the Calcaneo fibular ligament you will need to add a new
node on Tibia for this at the Malleolus lateralis. This node will be placed
in free air since the Fibula is not there.
I hope it made things clearer, otherwise please write again
Of Mike Arakilo
Sent: 20 March 2008 14:50
Hi again
in Gait3D and i have noticed a mistake in the model itself.
model on the fibula.
right and pointing outwards the body whereas in this model it is on the left
and pointing inside.
lateral malleolus is strictly affected by the fibula. Is there any solution
for correcting the model ?
Regards
             Hi Mike
Behalf
Of Mike Arakilo
Hi Sylvain
Regards
Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
..,._
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
       Start a new topic
                          Messages              |    Files              |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
3
New Files
	 Visit Your Group
Yahoo! Search
Find it faster
with Yahoo!
shortcuts.
                                       Y! Messenger
Send pics quick
Share photos while
you IM friends.
                                       Moderator Central
Yahoo! Groups
Get the latest news
from the team.
	 __,_.._,___
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
g-right:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
122%;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
I understood very well what you have meant and it sounds fair enough though i
understand that the bones are for visual purposes and the nodes are more
effective.
I followed the procedure you have told me but i got some errors.
for the Calcaneo fibular ligament i made the following statments and put them in
the specific file:
In BRep/Aalborg/Leg3D/Seg i have added the following statements in the foot
folder:
// Drawing of the ORIGIN point of the calcaneofibular ligament on the calcaneous
AnyRefNode CalcaneoFibularOrigin = {
sRel = .Scale({0.012, 0.075, ....Sign0.022});
AnyDrawRefFrame drwRefFrameHeelNode = {RGB = {0, 0, 0};};
// Drawing the INSERTION point of the calcaneofibular ligament on the Lateral
Maleolous
AnyRefNode CalcaneofubularInsertion = {
sRel = .Scale({0.065, 0.053, ...Sign
0.025});
AnyDrawRefFrame drwRefFrameLateralMaleolouusNode = {RGB = {0, 0, 0};};
In BRep/Aalborg/Leg3D/Mus i have added the following statements:
//Calcanefibular Ligament
AnyViaPointLigament CalcaneoFibular = {
AnyLigamentModelPol &LigMdl = ..MusPar.CalcaneoFibularPar;
AnyRefNode &Ori = ..Seg.Foot.CalcaneoFibularOrigin;
//AnyRefNode &Via = .Arm.ViaNode;
AnyRefNode &Ins = ..Seg.Foot.CalcaneofubularInsertion;
AnyDrawPLine drw = {
Thickness = 0.05;
RGB = {1,0,0};
In BRep/Aalborg/Leg3D/MusPar i have added the following statments
// Ligament Parameter for CalcaneoFibular Ligament
AnyLigamentModelPol CalcaneoFibularPar = {
L0 = 0.375;
eps1 = 0.053;
F1 = .StrengthScaleShank*.StressIndex*1000;
// a0 = 1;
// a1 = 1;
// LinRegionOnOff = On;
The ligament parameters are set randomly just for I can test the code. But i got
a strange drawing of that ligament with some warmings.
I got the following warning during building the model.
Configuring model...
WARNING(OBJ.DES1) :
T:\AnyScripts\Repository.6.1\BRep\Aalborg\Leg3D\LegCal1.any(51) :
'LegCalibrationStudy1.Internal_dependency' : Wrong initialization of
'AnyVarRef' linking to value 'L0' in study 'LegCalibrationStudy1' :
Dependency (Right-hand side or internal dependency) has earlier evaluation
moment than this AnyVarRef object, which is not allowed for AnyVarRef
initialization.
Location of 'L0' :
T:\AnyScripts\Repository.6.1\BRep\Aalborg\Leg3D\MusPar.any(21)
WARNING(OBJ.DES1) :
T:\AnyScripts\Repository.6.1\BRep\Aalborg\Leg3D\LegCal1..any(51) :
initialization.
Location of 'L0' :
I beleive they are the same warming but for right and left.
and then i got a strange ligament model so big and round all the ankle joint.
There is certainly an error in it.
I have run muscle calibration and Inverse Dynamics and got a folder for this
ligament with postion velocity and acceleration without any Forces.
What can I do to enhance this model for i can add further ligaments at a later
stage?
I have tried to put a muscle model on the calcaneofibular ligament using
AnyMuscleModel3E and AnyViaPointMuscle and it worked without warmings and gave
me all the forces and muscle activity.
Can i get further help in this ?
Regards
Sent: Tuesday, March 25, 2008 11:09:25 AM
             Hi Mike
Of Mike Arakilo
Hi again
Regards
Hi Mike
From: anyscript@yahoogrou ps.com [mailto:anyscript@ yahoogrou ps.com] On
Behalf
Of Mike Arakilo
Hi Sylvain
Regards
Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
..,._
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
3
New Files
	 Visit Your Group
Yahoo! Search
Find it faster
with Yahoo!
shortcuts.
                                       Y! Messenger
Send pics quick
Share photos while
you IM friends..
                                       Moderator Central
Yahoo! Groups
Get the latest news
from the team.
	 __,_.._,___
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
#ygrp-mkp{
#ygrp-mkp hr{
#ygrp-mkp #hd{
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Hi again
I have solved the issue for the shape of the ligament by decreasing the
thickness from 0.05 to 0.002 but still getting the warnings and the issue of the
forces of the ligament.
How can i see if the ligament is working ?
Hope this might help a bit
Regards
             Hi Mike
Of Mike Arakilo
Hi again
Regards
Hi Mike
Behalf
Of Mike Arakilo
Hi Sylvain
Regards
Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
..,._
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
3
New Files
	 Visit Your Group
Yahoo! Search
Find it faster
with Yahoo!
shortcuts.
                                       Y! Messenger
Send pics quick
Share photos while
you IM friends..
                                       Moderator Central
Yahoo! Groups
Get the latest news
from the team.
	 __,_.._,___
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
#ygrp-mkp{
#ygrp-mkp hr{
#ygrp-mkp #hd{
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
Hi Mike
As I read your script the ligament originates on the foot and attach on the
foot, and it do not have connection to other nodes. This means that it will
not have any effect on the model at all since there will be no length change
for any movement. I guess one of these nodes should be on the shank.
About the error message, this is a bug in the system, I am very sorry for
this. We will fix this for the next release of the system, thanks for making
us aware of this. L0 is by mistake set to be a Constant, which means that
the calibration study is not allowed to calibrate it. Since you have
inserted the ligament in the muscles folder it will automatically be part of
the calibration study with the muscles.
The best way for you to fix it, is to place the ligament in another folder
than the muscles so that it will not be calibrated and then calibrate it
manually, by adjusting the parameters like L0.
There is a tutorial about the ligaments if you have not seen it
http://www.anybodytech.com/682.0.html it might be helpful.
Of Mike Arakilo
Sent: 25 March 2008 15:02
i understand that the bones are for visual purposes and the nodes are more
effective.
them in the specific file:
folder:
calcaneous
Lateral Maleolous
0.025});
Thickness = 0.05;
RGB = {1,0,0};
L0 = 0.375;
eps1 = 0.053;
// a0 = 1;
// a1 = 1;
got a strange drawing of that ligament with some warmings.
WARNING(OBJ.DES1) :
initialization.
Location of 'L0' :
WARNING(OBJ.DES1) :
initialization.
Location of 'L0' :
joint. There is certainly an error in it.
later stage?
gave me all the forces and muscle activity.
Regards
             Hi Mike
Behalf
Of Mike Arakilo
Hi again
Regards
Hi Mike
Behalf
Of Mike Arakilo
Hi Sylvain
Regards
Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
..,._
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
3
New Files
	 Visit Your Group
Yahoo! Search
Find it faster
with Yahoo!
shortcuts.
                                       Y! Messenger
Send pics quick
Share photos while
you IM friends..
                                       Moderator Central
Yahoo! Groups
Get the latest news
from the team.
	 __,_.._,___
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
g-right:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
122%;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Hi Mike
You should be able to find the ligament in the output folder of the
ModelTree and locate the Fout object, it should display the force.
AnyBody Support, support@anybodytech.com.
Phone +45 9635 4289.
For free support, please go to http://groups.yahoo.com/group/anyscript.
Of Mike Arakilo
Sent: 25 March 2008 15:08
Hi again
the forces of the ligament.
Regards
             Hi Mike
Behalf
Of Mike Arakilo
Hi again
Regards
Hi Mike
Behalf
Of Mike Arakilo
Hi Sylvain
Regards
Hi Mike,
> Hi,
the
ask
I
but
the
> Thanks
> Mike
..,._
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
3
New Files
	 Visit Your Group
Yahoo! Search
Find it faster
with Yahoo!
shortcuts.
                                       Y! Messenger
Send pics quick
Share photos while
you IM friends..
                                       Moderator Central
Yahoo! Groups
Get the latest news
from the team.
	 __,_.._,___
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
g-right:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
122%;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
I have followed your advice and have put one node in shank and one in foot for
they can be connected to other nodes.
I have also made an include file called Lig.any
Another include file called LigPar.any
I was searching in the BodyModel_Mus3E where we do call the Mus.any and
MusPar.any and have found it in LefMus3E.root.any
So, i have made two folders there next to them as follows
// Ligaments
AnyFolder Lig = {
#include "Lig.any"
// LigamentParameters
AnyFolder LigPar = {
AnyVar StressIndex=.StrengthRef.StrengthIndexLeg;
#include "LigPar.any"
In the include file Lig.any i have included the following statement:
AnyLigamentModelPol &LigMdl = ..LigPar.CalcaneoFibularPar;
AnyRefNode &Org = ..Seg.Shank.CalcaneoFibularNode;
THIS IS LINE 14 WHERE I AM GETTING THE ERROR !
AnyRefNode &Ins = ..Seg.Foot.CalcaneoFibularNode;
Thickness = 0.002;
RGB = {1,0,0};
In the include file LigPar.any i have included teh following statement:
AnyVar StrengthScaleShank = ...Scaling.StrengthScaling.Shank.StrengthScale;
AnyVar StrengthScaleThigh = ...Scaling.StrengthScaling.Thigh.StrengthScale;
AnyVar StrengthScalePelvis = ...Scaling.StrengthScaling.Pelvis.StrengthScale;
AnyVar FiberLengthScaleShank =
...Scaling.FiberLengthScaling.Shank..FiberLengthScale;
AnyVar FiberLengthScaleThigh =
...Scaling.FiberLengthScaling.Thigh.FiberLengthScale;
//Ligament Parameter for CalcaneoFibular Ligament
L0 = 0.375;
eps1 = 0.053;
// a0 = 1;
// a1 = 1;
Running the Model back again I am getting a silly error from a silly mistake i
could have done:
ERROR(SCR.PRS9) : T:\AnyScripts\Repository.6.1\BRep\Aalborg\Leg3D\Lig.any(14)
: 'CalcaneoFibularNode' : Unresolved object
As I can see, it didn't have any problem with the LigPar,any include file but is
it having problem with the Lig.any include file.
I tried to swap the insertion and origin points but i am still getting the error
on line 14 so i thought that i have mistyped something but they seem fine for me
expect if i needed to make some call somewhere else.
I do beleive that it will be difficult always to put the first ligament on track
and it will be easier for the rest.
Can I get some help with this error and how I should fix it ?
Regards
Sent: Wednesday, March 26, 2008 8:31:08 AM
             Hi Mike
http://www.anybodyt ech.com/682. 0.html it might be helpful.
Of Mike Arakilo
effective.
In BRep/Aalborg/ Leg3D/Seg i have added the following statements in the foot
folder:
calcaneous
AnyRefNode CalcaneoFibularOrig in = {
sRel = .Scale({0.012, 0.075, ....Sign0.022} );
Lateral Maleolous
AnyRefNode CalcaneofubularInse rtion = {
sRel = .Scale({0.065, 0..053, ...Sign
0.025} );
AnyDrawRefFrame drwRefFrameLateralM aleolouusNode = {RGB = {0, 0, 0};};
In BRep/Aalborg/ Leg3D/Mus i have added the following statements:
AnyLigamentModelPol &LigMdl = ..MusPar.CalcaneoFi bularPar;
AnyRefNode &Ori = ..Seg.Foot.Calcaneo FibularOrigin;
AnyRefNode &Ins = ..Seg.Foot.Calcaneo fubularInsertion ;
Thickness = 0.05;
RGB = {1,0,0};
In BRep/Aalborg/ Leg3D/MusPar i have added the following statments
L0 = 0.375;
eps1 = 0.053;
F1 = .StrengthScaleShank .StressIndex 1000;
// a0 = 1;
// a1 = 1;
WARNING(OBJ. DES1) :
T:\AnyScripts\ Repository. 6.1\BRep\ Aalborg\Leg3D\ LegCal1.any( 51) :
'LegCalibrationStud y1.Internal_ dependency' : Wrong initialization of
'AnyVarRef' linking to value 'L0' in study 'LegCalibrationStud y1' :
initialization.
Location of 'L0' :
T:\AnyScripts\ Repository. 6.1\BRep\ Aalborg\Leg3D\ MusPar.any( 21)
T:\AnyScripts\ Repository. 6.1\BRep\ Aalborg\Leg3D\ LegCal1... any(51) :
initialization.
Location of 'L0' :
later stage?
Regards
Hi Mike
Behalf
Of Mike Arakilo
Hi again
Regards
Hi Mike
Behalf
Of Mike Arakilo
Hi Sylvain
Regards
Hi Mike,
you already found (..../Jnt/Ankle) after running the simulation. You
> Hi,
the
> one segment model in anybody and see if i can get data i need..
ask
I
but
the
> Thanks
> Mike
..,._
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
2
New Files
	 Visit Your Group
Yahoo! Search
Try a shortcut
Get local weather
faster.
                                       Y! Messenger
Files to share?
Send up to 1GB of
files in an IM.
                                       All-Bran
Day 10 Club
on Yahoo! Groups
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
Start a new topic
Messages | Files |
     Visit Your Group
     Unsubscribe
    	    	      		 Recent Activity
			                3
   New Members
3
New Files
	 Visit Your Group
Yahoo! Search
Find it faster
with Yahoo!
shortcuts.
                                       Y! Messenger
Send pics quick
Share photos while
you IM friends..
                                       Moderator Central
Yahoo! Groups
Get the latest news
from the team.
	 __,_..._,___
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
10px
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
#ygrp-mkp{
14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
sans-serif;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family: Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77% ;}
#reco-desc{
font-size:77% ;}
#ygrp-vital{
#ygrp-vital #vithd{
text-transform
:uppercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
paddin
g-right:.5em; }
font-weight: bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
height:
122%;}
margin:0;}
o{font-size: 0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120% ;}
.replbq{margin: 4;}
#ygrp-mkp{
#ygrp-mkp hr{
#ygrp-mkp #hd{
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Hi Mike,
That kind of error is usually due to some misspelling in the path. I
don't see any mistake in the code, but the problem can come from
somewhere else, the segment folder for example. Make sure the node is
well defined in the shank folder and in the foot folder (a spelling
mistake can be there maybe). The 2 points before Seg when you
write "AnyRefNode &Org = ..Seg.Shank.CalcaneoFibularNode;" should be
ok but make sure you didn't add a folder somewhere that would require
more of these points.
These are the classical mistakes I'm thinking in. I cannot see what
is the exact mistake without the rest of the code. Try to check those
ideas, it should resolve it.
--- In anyscript@yahoogroups.com, Mike Arakilo <marakilo@...> wrote:
> Hi
in foot for they can be connected to other nodes.
and MusPar.any and have found it in LefMus3E.root.any
> // Ligaments
> AnyFolder Lig = {
> #include "Lig.any"
> AnyRefNode &Org
> Thickness = 0.002;
> RGB = {1,0,0};
statement:
= ...Scaling.FiberLengthScaling.Shank..FiberLengthScale;
= ...Scaling.FiberLengthScaling.Thigh.FiberLengthScale;
> L0 = 0.375;
> eps1 = 0.053;
> F1 = .StrengthScaleShank*.StressIndex1000;
> // a0 = 1;
> // a1 = 1;
silly mistake i could have done:
\BRep\Aalborg\Leg3D\Lig.any(14) : 'CalcaneoFibularNode' :
Unresolved object
include file but is it having problem with the Lig.any include file.
getting the error on line 14 so i thought that i have mistyped
something but they seem fine for me expect if i needed to make some
ligament on track and it will be easier for the rest.
> Regards
> From: AnyBody Support <support@...>
> Hi Mike
attach on the
it will
length change
shank.
sorry for
for making
means that
be part of
folder
calibrate it
> Best regards
ps.com] On Behalf
> Of Mike Arakilo
> Hi
enough though
are more
> effective.
and put
the foot
> folder:
the
> calcaneous
0.022} );
the
> Lateral Maleolous
> sRel = .Scale({0.065, 0..053, ...Sign*0.025} );
0, 0};};
> Thickness = 0.05;
> RGB = {1,0,0};
> L0 = 0.375;
> eps1 = 0.053;
> // a0 = 1;
> // a1 = 1;
code. But i
51) :
initialization of
y1' :
evaluation
AnyVarRef
> initialization.
> Location of 'L0' :
(51) :
initialization of
y1' :
evaluation
AnyVarRef
> initialization.
> Location of 'L0' :
ankle
for this
at a
> later stage?
using
warmings and
> Regards
> From: AnyBody Support <support@anybodytech .com>
> Hi Mike
do not
thought that
model.
model.
a new
be placed
> Best regards
ps.com] On
> Behalf
> Of Mike Arakilo
> Hi again
the model
process,
with the
the
the left
the
solution
> Regards
> From: AnyBody Support <support@anybodytec h .com>
> Hi Mike
to make
geometry are
would not
scale
on the
> Best regards
ps.com] On
> Behalf
> Of Mike Arakilo
> Hi Sylvain
ones ?
> Regards
> Hi Mike,
and
such
of
have
folder
You
you
> Best regards,
> --- In anyscript@yahoogrou ps.com, "marakilo" <marakilo@ .> wrote:
> > Hi,
> the
well
to
> ask
forces.
> I
> but
investigate
> the
> > Thanks
> > Mike
> ..,._
(2)
> Start a new topic
> Messages |
Files |
> Photos | Links |
Database |
Switch
> Visit Your Group
> Unsubscribe
> Recent Activity
> 3
> New Members
> 2
> New Files
> Visit Your Group
> Yahoo! Search
> Try a shortcut
> Get local weather
> faster.
> Y! Messenger
> Files to share?
> Send up to 1GB of
> files in an IM.
> All-Bran
> Day 10 Club
> on Yahoo! Groups
> #ygrp-mkp{
0px;padding: 0px
> 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
122%;margin:
> 10px
> 0px;}
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
122%;}
clean,
> sans-serif;}
clean,
> sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right;
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
8px;}
> #ygrp-vital #vithd{
> text-transform
> :uppercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right;
> paddin
> g-right:.5em; }
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
100%;line-
> height:
> 122%;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
> ____________ _________ _________ _________ _________ _________ _
> ________
shopping
biomechanical
> Start a new topic
> Messages |
Files |
> Photos | Links |
Database |
Switch
> Visit Your Group
> Unsubscribe
> Recent Activity
> 3
> New Members
> 3
> New Files
> Visit Your Group
> Yahoo! Search
> Find it faster
> with Yahoo!
> shortcuts.
> Y! Messenger
> Send pics quick
> Share photos while
> you IM friends..
> Moderator Central
> Yahoo! Groups
> Get the latest news
> from the team.
> ,...,_
> #ygrp-mkp{
0px;padding: 0px
> 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
122%;margin:
> 10px
> 0px;}
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
122%;}
clean,
> sans-serif;}
clean,
> sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right;
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
8px;}
> #ygrp-vital #vithd{
> text-transform
> :uppercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right;
> paddin
> g-right:.5em; }
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
100%;line-
> height:
> 122%;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
> ________
biomechanical
> #ygrp-mkp{
0px;padding: 0px
> 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
122%;margin: 10px
> 0px;}
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
122%;}
clean,
> sans-serif;}
clean,
> sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right; }
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
8px;}
> #ygrp-vital #vithd{
text-transform
> :uppercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right; paddin
> g-right:.5em; }
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
100%;line- height:
> 122%;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
> ________
biomechanical
> #ygrp-mkp{
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
> font-family:Arial;}
clean, sans-serif;}
clean, sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family:Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right;}
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77%;}
> #reco-desc{
> font-size:77%;}
> #ygrp-vital{
> #ygrp-vital #vithd{
transform:uppercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right;padding-right:.5em;}
> font-weight:bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
> margin:0;}
> o{font-size:0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120%;}
> .replbq{margin:4;}
I have tried everything I can for I can find the mistake but it doesn't seems to
me path mistake becuase they are totally right.
Seg, Mus, Lig, LigPar and LegMus3E are in the same folder.
I am created a folder in LegMus3E named Lig and another folder LigPar related to
the include file Lig and LigPar.
This is how i did to solve find the mistake.
As a beginning i commented to folders Lig and LigPar in LegMus3E, so I can run
the model using default and initial settings.
The Results was great and the model ran.
Second, i enabled the folders in LegMus3E and ran the model again.
The Result was the same error.
I have chosen another node point already defined in the initial code in seg
which is the MaleolousLateral and also it gave me the same error pointing on the
MaleolousLateral ..
I have chosen another node point already defined in the initial code inseg which
is the HeelJoint and also it gave me the same errorpointing on the HeelJoint .
I have copied the the Solus Muscle from the MusFile and put it in Lig, and here
also i got the same error pointing on the SolusNode
I have downloaded the repository again and replaced the Seg.any include file
with mine and without making any change i picked up again the MaleolousLateral
node and put it in the lig folder and unfortunately i got the same error.
The two points before seg should be right the path Seg.Shank. or Seg.Foot is
also right
The names are copy pasted.
I have included the following files
Seg
Lig
LigPar
LegMus3E.root
Hope we can find this error ...
Regards
Sent: Thursday, March 27, 2008 12:42:24 PM
             Hi Mike,
write "AnyRefNode &Org = ..Seg.Shank. CalcaneoFibularN ode;" should be
--- In anyscript@yahoogrou ps.com, Mike Arakilo <marakilo@.. .> wrote:
> Hi
and MusPar.any and have found it in LefMus3E.root. any
> // Ligaments
> AnyFolder Lig = {
> #include "Lig.any"
> AnyVar StressIndex= .StrengthRef. StrengthIndexLeg ;
> AnyLigamentModelPol &LigMdl = ..LigPar.CalcaneoFi bularPar;
> AnyRefNode &Org
> AnyRefNode &Ins = ..Seg.Foot.Calcaneo FibularNode;
> Thickness = 0.002;
> RGB = {1,0,0};
statement:
= ...Scaling.Strength Scaling.Shank. StrengthScale;
= ...Scaling..Strength Scaling.Thigh. StrengthScale;
= ...Scaling.Strength Scaling.Pelvis. StrengthScale;
> AnyVar FiberLengthScaleSha nk
= ...Scaling.FiberLen gthScaling. Shank..FiberLeng thScale;
> AnyVar FiberLengthScaleThi gh
= ...Scaling.FiberLen gthScaling.. Thigh.FiberLengt hScale;
> L0 = 0.375;
> eps1 = 0.053;
> // a0 = 1;
> // a1 = 1;
> ERROR(SCR.PRS9) : T:\AnyScripts\ Repository. 6.1
\BRep\Aalborg\ Leg3D\Lig. any(14) : 'CalcaneoFibularNod e' :
Unresolved object
> Regards
> From: AnyBody Support <support@... >
> Hi Mike
attach on the
it will
length change
shank.
sorry for
for making
means that
be part of
folder
calibrate it
> Best regards
ps.com] On Behalf
> Of Mike Arakilo
> Hi
enough though
are more
> effective.
and put
the foot
> folder:
the
> calcaneous
the
> Lateral Maleolous
0.025} );
0, 0};};
> Thickness = 0.05;
> RGB = {1,0,0};
> L0 = 0.375;
> eps1 = 0.053;
> // a0 = 1;
> // a1 = 1;
code. But i
51) :
initialization of
y1' :
evaluation
AnyVarRef
> initialization.
> Location of 'L0' :
(51) :
initialization of
y1' :
evaluation
AnyVarRef
> initialization.
> Location of 'L0' :
ankle
> joint.. There is certainly an error in it.
for this
at a
> later stage?
using
warmings and
> Regards
> Hi Mike
do not
thought that
model.
model.
a new
be placed
> Best regards
ps.com] On
> Behalf
> Of Mike Arakilo
> Hi again
the model
process,
with the
the
the left
the
solution
> Regards
> Hi Mike
to make
geometry are
would not
scale
on the
> Best regards
ps.com] On
> Behalf
> Of Mike Arakilo
> Hi Sylvain
ones ?
> Regards
> Hi Mike,
and
such
of
have
folder
You
you
> Best regards,
> > Hi,
> the
well
to
> ask
forces.
> I
> but
investigate
> the
> > Thanks
> > Mike
> ..,._
(2)
> Start a new topic
> Messages |
Files |
> Photos | Links |
Database |
Switch
> Visit Your Group
> Unsubscribe
> Recent Activity
> 3
> New Members
> 2
> New Files
> Visit Your Group
> Yahoo! Search
> Try a shortcut
> Get local weather
> faster.
> Y! Messenger
> Files to share?
> Send up to 1GB of
> files in an IM..
> All-Bran
> Day 10 Club
> on Yahoo! Groups
> #ygrp-mkp{
0px;padding: 0px
> 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
122%;margin:
> 10px
> 0px;}
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
122%;}
clean,
> sans-serif;}
clean,
> sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right;
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
8px;}
> #ygrp-vital #vithd{
> text-transform
> :uppercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right;
> paddin
> g-right:.5em; }
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
100%;line-
> height:
> 122%;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
> ________
shopping
biomechanical
> Start a new topic
> Messages |
Files |
> Photos | Links |
Database |
Switch
> Visit Your Group
> Unsubscribe
> Recent Activity
> 3
> New Members
> 3
> New Files
> Visit Your Group
> Yahoo! Search
> Find it faster
> with Yahoo!
> shortcuts.
> Y! Messenger
> Send pics quick
> Share photos while
> you IM friends..
> Moderator Central
> Yahoo! Groups
> Get the latest news
> from the team.
> ,...,_
> #ygrp-mkp{
0px;padding: 0px
> 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
122%;margin:
> 10px
> 0px;}
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
122%;}
clean,
> sans-serif;}
clean,
> sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right;
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
8px;}
> #ygrp-vital #vithd{
> text-transform
> :uppercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right;
> paddin
> g-right:.5em; }
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
100%;line-
> height:
> 122%;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
> ________
biomechanical
> #ygrp-mkp{
0px;padding: 0px
> 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
122%;margin: 10px
> 0px;}
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
122%;}
clean,
> sans-serif;}
clean,
> sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right; }
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
8px;}
> #ygrp-vital #vithd{
text-transform
> :uppercase;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right; paddin
> g-right:.5em; }
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
100%;line- height:
> 122%;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
> ________
biomechanical
> #ygrp-mkp{
0px;padding: 0px 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
height:122%; margin:10px 0px;}
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
clean, sans-serif;}
clean, sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right; }
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
> #ygrp-vital #vithd{
> font-size:77% ;font-family: Verdana;font- weight:bold; color:#333; text-
transform:uppercase ;}
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right; padding-right: .5em;}
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
size:100%;line- height:122% ;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
#ygrp-mkp{
#ygrp-mkp hr{
#ygrp-mkp #hd{
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
Did you uploaded the files? I cannot find them. Please tell me the
location where you upload them.
> Hi
doesn't seems to me path mistake becuase they are totally right.
LigPar related to the include file Lig and LigPar.
so I can run the model using default and initial settings.
code in seg which is the MaleolousLateral and also it gave me the
same error pointing on the MaleolousLateral ..
code inseg which is the HeelJoint and also it gave me the same
Lig, and here also i got the same error pointing on the SolusNode
include file with mine and without making any change i picked up
again the MaleolousLateral node and put it in the lig folder and
Seg.Foot is also right
> Seg
> Lig
> LigPar
> LegMus3E.root
> Regards
> ----- Original Message ----
> Subject: [AnyScript] Re: Adding muscles to BodyModel_Mus3E
> Hi Mike,
I
is
be
require
those
> Best regards,
> Sylvain, AnyBody Support.
> --- In anyscript@yahoogrou ps.com, Mike Arakilo <marakilo@ .> wrote:
> > Hi
one
Mus.any
> > // Ligaments
> > AnyFolder Lig = {
> > #include "Lig.any"
statement:
> > AnyRefNode &Org
ode;
> > Thickness = 0.002;
> > RGB = {1,0,0};
> statement:
> > L0 = 0.375;
> > eps1 = 0.053;
> > // a0 = 1;
> > // a1 = 1;
> Unresolved object
> > Regards
> > From: AnyBody Support <support@ >
> > Hi Mike
> attach on the
that
> it will
> length change
> shank.
> sorry for
> for making
> means that
have
> be part of
another
> folder
> calibrate it
> > Best regards
> > Søren, AnyBody Support
> ps.com] On Behalf
> > Of Mike Arakilo
> > Hi
> enough though
> are more
> > effective.
> and put
in
> the foot
> > folder:
> the
> > calcaneous
on
> the
> > Lateral Maleolous
0.025} );
{0,
> 0, 0};};
> > Thickness = 0.05;
> > RGB = {1,0,0};
statments
> > L0 = 0.375;
> > eps1 = 0.053;
> > // a0 = 1;
> > // a1 = 1;
> code. But i
> 51) :
> initialization of
> y1' :
> evaluation
> AnyVarRef
> > initialization.
> > Location of 'L0' :
21)
> (51) :
> initialization of
> y1' :
> evaluation
> AnyVarRef
> > initialization.
> > Location of 'L0' :
21)
> ankle
folder
> for this
Forces.
ligaments
> at a
> > later stage?
ligament
> using
> warmings and
> > Regards
> > Hi Mike
using,
> do not
> thought that
this
> model.
> model.
add
> a new
> be placed
> > Best regards
> ps.com] On
> > Behalf
> > Of Mike Arakilo
> > Hi again
> the model
the
> process,
> with the
on
> the
on
> the left
> the
any
> solution
> > Regards
> > Hi Mike
has
> to make
> geometry are
> would not
to
> scale
depending
> on the
> > Best regards
> ps.com] On
> > Behalf
> > Of Mike Arakilo
> > Hi Sylvain
> ones ?
> > Regards
> > Sent: Friday, March 14, 2008 8:58:30 AM
> > Hi Mike,
> > To add muscles and ligaments you first need to define the origin
> and
> > insertion (optionally via points) of each muscle. This must be
done
> > by adding AnyRefNode in the corresponding segment folder, foot
and
> > shank in your case located in Brep/Aalborg/ Leg3D/Seg. Then add
the
> > muscles in the files …/Leg3D/MusWithNames .
> > Concerning the coordinate system: there is a global reference
frame
> > but then each segment has is own local frame. You can visualize
> such
> > frame by adding an AnyDrawRefFrame in the segment folder. The
node
> of
> > a segment are defined in the local frame of the segment, so you
> have
> > to enter the origin and insertion point coordinates according to
> > local frame of the segment they belong.
> > And to visualize the reaction forces on a joint just go in the
> folder
> You
> > will find here a subfolder called Reaction, enter and click Pos,
> you
> > will now see the reaction forces in the joint.
> > Best regards,
> > Sylvain, AnyBody Support..
> > > Hi,
> > > Following the previous messages about foot model i decided to
try
> > the
> > > I investigated the Gait3D model in anybody and understood very
> well
> > > the code for it but i have some more questions on it.
> > > I want to add muscles and ligaments around the ankle and wanted
> to
> > ask
> > > you how can I do it ? and in which file ?
> > > What I didn't understand too, is how we are putting the x y z
> > > coordinates in modeling. I know we are defining a global
reference
> > > with coordinates { 0, 0, 0 } but i m not able to know how i
define
> > > exactly the muscles in that frame myself.
> > > One other thing, i have read that I can see the ankle joint
> forces.
> > I
> > > have found the folder Ankle joint when i m running the
simulation
> > but
> > > how can i see the forces? because inside this folder there is
> > > positions velocities and acceleration. Is there way to
> investigate
> > the
> > > forces in the ankle joint itself ?
> > > Thanks
> > > Mike
> > ..,._
> (2)
> > Reply (via web post) |
> > Start a new topic
> > Messages |
> Files |
> > Photos | Links |
> Database |
> > Polls | Members | Calendar
> > biomechanical models in the AnyScript language.
> > Change settings via the Web (Yahoo! ID required)
> > Change settings via email: Switch delivery to Daily Digest
> Switch
> > Visit Your Group
> > Yahoo! Groups Terms of Use |
> > Unsubscribe
> > Recent Activity
> > 3
> > New Members
> > 2
> > New Files
> > Visit Your Group
> > Yahoo! Search
> > Try a shortcut
> > Get local weather
> > faster.
> > Y! Messenger
> > Files to share?
> > Send up to 1GB of
> > files in an IM..
> > All-Bran
> > Day 10 Club
> > on Yahoo! Groups
> > Feel better with fiber.
> > #ygrp-mkp{
> 0px;padding: 0px
> > 14px;}
> > #ygrp-mkp hr{
> > border:1px solid #d8d8d8;}
> > #ygrp-mkp #hd{
> 122%;margin:
> > 10px
> > 0px;}
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
> > #ygrp-sponsor #ygrp-lc{
> > #ygrp-sponsor #ygrp-lc #hd{
> 122%;}
> > #ygrp-sponsor #ygrp-lc .ad{
> clean,
> > sans-serif;}
> > #ygrp-mlmsg select, input, textarea {font:99% arial, helvetica,
> clean,
> > sans-serif;}
> > #ygrp-mlmsg pre, code {font:115% monospace;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right;
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #ygrp-reco #reco-head {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
> 8px;}
> > #ygrp-vital #vithd{
> > text-transform
> > :uppercase;}
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> > #ygrp-vital ul li .ct{
> align:right;
> > paddin
> > g-right:.5em; }
> > #ygrp-vital ul li .cat{
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-vital a:hover{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #ov ul{
> > #ygrp-sponsor #ov li{
> > #ygrp-sponsor #ov li a{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> > #ygrp-sponsor .ad #hd1{
> 100%;line-
> > height:
> > 122%;}
> > #ygrp-sponsor .ad a{
> > #ygrp-sponsor .ad a:hover{
> > #ygrp-sponsor .ad p{
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> > ________
> > Looking for last minute shopping deals?
> > Find them fast with Yahoo! Search.
category=
> shopping
> biomechanical
> > Start a new topic
> > Messages |
> Files |
> > Photos | Links |
> Database |
> Switch
> > Visit Your Group
> > Unsubscribe
> > Recent Activity
> > 3
> > New Members
> > 3
> > New Files
> > Visit Your Group
> > Yahoo! Search
> > Find it faster
> > with Yahoo!
> > shortcuts.
> > Y! Messenger
> > Send pics quick
> > Share photos while
> > you IM friends..
> > Moderator Central
> > Yahoo! Groups
> > Get the latest news
> > from the team.
> > ,...,_
> > #ygrp-mkp{
> 0px;padding: 0px
> > 14px;}
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> 122%;margin:
> > 10px
> > 0px;}
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
> 122%;}
> clean,
> > sans-serif;}
> clean,
> > sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right;
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
> 8px;}
> > #ygrp-vital #vithd{
> > text-transform
> > :uppercase;}
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> align:right;
> > paddin
> > g-right:.5em; }
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> 100%;line-
> > height:
> > 122%;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> > ________
> > Be a better friend, newshound, and
> > know-it-all with Yahoo! Mobile. Try it now.
> > Users of the AnyBody Modeling System help each other create
> biomechanical
> > models in the AnyScript language.Yahoo! Groups Links
> > #ygrp-mkp{
> 0px;padding: 0px
> > 14px;}
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> 122%;margin: 10px
> > 0px;}
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
> 122%;}
> clean,
> > sans-serif;}
> clean,
> > sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right; }
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
> 8px;}
> > #ygrp-vital #vithd{
color:#333;
> text-transform
> > :uppercase;}
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> align:right; paddin
> > g-right:.5em; }
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> 100%;line- height:
> > 122%;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> > ________
> biomechanical
> > #ygrp-mkp{
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
122%;}
> clean, sans-serif;}
> clean, sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right; }
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
8px;}
> > #ygrp-vital #vithd{
color:#333; text-
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> ____________ __
> #ygrp-mkp{
> border:1px solid #d8d8d8;font-family:Arial;margin:14px
0px;padding:0px 14px;}
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
> color:#628c2a;font-size:85%;font-weight:bold;line-
height:122%;margin:10px 0px;}
> #ygrp-mkp #ads{
> margin-bottom:10px;}
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
> color:#0000ff;text-decoration:none;}
> font-family:Arial;}
> margin:10px 0px;font-weight:bold;font-size:78%;line-height:122%;}
> margin-bottom:10px;padding:0 0;}
> #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica,
clean, sans-serif;}
> #ygrp-mlmsg table {font-size:inherit;font:100%;}
clean, sans-serif;}
> #ygrp-mlmsg * {line-height:1.22em;}
> #ygrp-text{
> font-family:Georgia;
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family:Arial;
> clear:both;}
> #ygrp-vitnav{
> padding-top:10px;font-family:Verdana;font-size:77%;margin:0;}
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
> clear:both;margin:25px 0;white-space:nowrap;color:#666;text-
align:right;}
> #ygrp-actbar .left{
> float:left;white-space:nowrap;}
> .bld{font-weight:bold;}
> #ygrp-grft{
> font-family:Verdana;font-size:77%;padding:15px 0;}
> #ygrp-ft{
> font-family:verdana;font-size:77%;border-top:1px solid #666;
> padding:5px 0;
> #ygrp-mlmsg #logo{
> padding-bottom:10px;}
> #ygrp-reco {
> margin-bottom:20px;padding:0px;}
> font-weight:bold;color:#ff7900;}
> #reco-grpname{
> font-weight:bold;margin-top:10px;}
> #reco-category{
> font-size:77%;}
> #reco-desc{
> font-size:77%;}
> #ygrp-vital{
> background-color:#e0ecee;margin-bottom:20px;padding:2px 0 8px 8px;}
> #ygrp-vital #vithd{
> font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-
> #ygrp-vital ul{
> padding:0;margin:2px 0;}
> #ygrp-vital ul li{
> list-style-type:none;clear:both;border:1px solid #e0ecee;
> font-weight:bold;color:#ff7900;float:right;width:2em;text-
> font-weight:bold;}
> #ygrp-vital a{
> text-decoration:underline;}
> #ygrp-sponsor #hd{
> color:#999;font-size:77%;}
> #ygrp-sponsor #ov{
> padding:6px 13px;background-color:#e0ecee;margin-bottom:20px;}
> padding:0 0 0 8px;margin:0;}
> list-style-type:square;padding:6px 0;font-size:77%;}
> text-decoration:none;font-size:130%;}
> #ygrp-sponsor #nc{
> background-color:#eee;margin-bottom:20px;padding:0 8px;}
> #ygrp-sponsor .ad{
> padding:8px 0;}
> font-family:Arial;font-weight:bold;color:#628c2a;font-
> margin:0;}
> o{font-size:0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120%;}
> blockquote{margin:0 0 0 4px;}
> .replbq{margin:4;}
I attached the files with the email and seems you didn't get them.
I am attaching now the files with this email and in case you will not see them,
i have created a folder in the files section in the anyscpit group.
The folder name is Mike Arakilo Files and there are 4 files inside.
Let me know
Thanks
Regards
To: anyscript@yahoogroups..com
Sent: Friday, March 28, 2008 11:13:05 AM
> Hi
> Seg
> Lig
> LigPar
> LegMus3E.root
> Regards
> To: anyscript@yahoogrou ps.com
> Hi Mike,
I
is
> write "AnyRefNode &Org = ..Seg.Shank.. CalcaneoFibularN ode;" should
be
require
those
> Best regards,
> > Hi
one
Mus.any
> > // Ligaments
> > AnyFolder Lig = {
> > #include "Lig.any"
statement:
> > AnyRefNode &Org
ode;
> > Thickness = 0.002;
> > RGB = {1,0,0};
> statement:
> = ...Scaling.. Strength Scaling.Thigh. StrengthScale;
> > L0 = 0.375;
> > eps1 = 0.053;
> > // a0 = 1;
> > // a1 = 1;
> Unresolved object
> > Regards
> > Subject: RE: [AnyScript] Re: Adding muscles to BodyModel_Mus3E
> > Hi Mike
> attach on the
that
> it will
> length change
> shank.
> sorry for
> for making
> means that
have
> be part of
another
> folder
> calibrate it
> > Best regards
> > -----Original Message-----
> ps.com] On Behalf
> > Of Mike Arakilo
> > Subject: Re: [AnyScript] Re: Adding muscles to BodyModel_Mus3E
> > Hi
> enough though
> are more
> > effective.
> and put
in
> the foot
> > folder:
> the
> > calcaneous
on
> the
> > Lateral Maleolous
0.025} );
{0,
> 0, 0};};
> > Thickness = 0.05;
> > RGB = {1,0,0};
statments
> > L0 = 0.375;
> > eps1 = 0..053;
> > // a0 = 1;
> > // a1 = 1;
> code. But i
> 51) :
> initialization of
> y1' :
> evaluation
> AnyVarRef
> > initialization.
> > Location of 'L0' :
21)
> (51) :
> initialization of
> y1' :
> evaluation
> AnyVarRef
> > initialization.
> > Location of 'L0' :
> > T:\AnyScripts\ Repository.. 6.1\BRep\ Aalborg\Leg3D\ MusPar.any(
21)
> ankle
folder
> for this
Forces.
ligaments
> at a
> > later stage?
ligament
> using
> warmings and
> > Regards
> > Hi Mike
using,
> do not
> thought that
this
> model.
> model.
add
> a new
> be placed
> > Best regards
> ps.com] On
> > Behalf
> > Of Mike Arakilo
> > Hi again
> > I was trying to follow the procedure on adding some ligaments to
> the model
> > I was trying to add calcaneofibular ligament as a beginning of
the
> process,
> > working on the right leg as usual i noticed that there is mistake
> with the
> > The bones are reverse side i.e fibula on the right leg should be
on
> the
on
> the left
> > I dont know the consequences of all the nodes present for example
> the
any
> solution
> > Sorry for any inconvenience ...
> > Thanks for your reply
> > Regards
> > Sent: Tuesday, March 18, 2008 12:12:21 PM
> > Hi Mike
> > There are in principle no units definition in AnyBody, the user
has
> to make
> > sure that the units provided in the models fits with each other.
> > That said all models in the repository are based on SI units so
> geometry are
> > in meters, forces in newtons, moments in newtons meters etc, I
> would not
> > recommend to use any other units.
> > The .Scale which is put around all srel values makes it possible
to
> scale
> > these nodes. These nodes can be scaled in different ways,
depending
> on the
> > scaling law provided in the main file. Please take a look in the
> > Gait3D.main. any file to see an example on this. If you choose the
> > ScalingStandard. any file it will not scale the model.
> > Best regards
> ps.com] On
> > Behalf
> > Of Mike Arakilo
> > Sent: 18 March 2008 12:39
> > Hi Sylvain
> > Sorry for missing a part in my previous email.
> > I wanted to ask you how big is 1 unit in AnyBody ? Is it 1cm ?
> > Why we are making .Scale for the coordinates ? Are they the real
> ones ?
> > Regards
> > Hi Mike,
> and
done
and
the
frame
> such
node
> of
> have
> folder
> You
> you
> > Best regards,
> > > Hi,
try
> > the
> well
> to
> > ask
reference
define
> forces.
> > I
simulation
> > but
> investigate
> > the
> > > Thanks
> > > Mike
> > ..,._
> > Messages in this topic
> (2)
> > Start a new topic
> > Messages |
> Files |
> > Photos | Links |
> Database |
> Switch
> > format to Traditional
> > Visit Your Group
> > Unsubscribe
> > Recent Activity
> > 3
> > New Members
> > 2
> > New Files
> > Visit Your Group
> > Yahoo! Search
> > Try a shortcut
> > Get local weather
> > faster.
> > Y! Messenger
> > Files to share?
> > Send up to 1GB of
> > files in an IM..
> > All-Bran
> > Day 10 Club
> > on Yahoo! Groups
> > #ygrp-mkp{
> > border:1px solid #d8d8d8;font- family:Arial; margin:14px
> 0px;padding: 0px
> > 14px;}
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> > color:#628c2a; font-size: 85%;font- weight:bold; line-height:
> 122%;margin:
> > 10px
> > 0px;}
> > #ygrp-mkp #ads{
> > margin-bottom: 10px;}
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
> > color:#0000ff; text-decoration: none;}
> > font-family: Arial;}
> > margin:10px 0px;font-weight: bold;font- size:78%; line-height:
> 122%;}
> > margin-bottom: 10px;padding: 0 0;}
> > #ygrp-mlmsg {font-size:13px; font-family: arial, helvetica,
> clean,
> > sans-serif;}
> > #ygrp-mlmsg table {font-size:inherit; font:100% ;}
> clean,
> > sans-serif;}
> > #ygrp-mlmsg * {line-height: 1.22em;}
> > #ygrp-text{
> > font-family: Georgia;
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > padding-top: 10px;font- family:Verdana; font-size: 77%;margin: 0;}
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> > clear:both;margin: 25px 0;white-space: nowrap;color: #666;text-
> align:right;
> > #ygrp-actbar .left{
> > float:left;white- space:nowrap; }
> > .bld{font-weight: bold;}
> > #ygrp-grft{
> > font-family: Verdana;font- size:77%; padding:15px 0;}
> > #ygrp-ft{
> > font-family: verdana;font- size:77%; border-top: 1px solid #666;
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > padding-bottom: 10px;}
> > #ygrp-reco {
> > margin-bottom: 20px;padding: 0px;}
> > font-weight: bold;color: #ff7900;}
> > #reco-grpname{
> > font-weight: bold;margin- top:10px; }
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
> > background-color: #e0ecee;margin- bottom:20px; padding:2px 0 8px
> 8px;}
> > #ygrp-vital #vithd{
> > text-transform
> > :uppercase;}
> > #ygrp-vital ul{
> > padding:0;margin: 2px 0;}
> > #ygrp-vital ul li{
> > list-style-type: none;clear: both;border: 1px solid #e0ecee;
> > font-weight: bold;color: #ff7900;float: right;width: 2em;text-
> align:right;
> > paddin
> > g-right:.5em; }
> > font-weight: bold;}
> > #ygrp-vital a{
> > text-decoration: underline; }
> > #ygrp-sponsor #hd{
> > color:#999;font- size:77%; }
> > #ygrp-sponsor #ov{
> > padding:6px 13px;background- color:#e0ecee; margin-bottom: 20px;}
> > padding:0 0 0 8px;margin:0; }
> > list-style-type: square;padding: 6px 0;font-size: 77%;}
> > text-decoration: none;font- size:130% ;}
> > #ygrp-sponsor #nc{
> > background-color: #eee;margin- bottom:20px; padding:0 8px;}
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> > font-family: Arial;font- weight:bold; color:#628c2a; font-size:
> 100%;line-
> > height:
> > 122%;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > blockquote{margin: 0 0 0 4px;}
> > .replbq{margin: 4;}
> > ________
> > http://tools. search.yahoo. com/newsearch/ category. php?
category=
> shopping
> biomechanical
> > Messages in this topic (7)
> > Start a new topic
> > Messages |
> Files |
> > Photos | Links |
> Database |
> Switch
> > Visit Your Group
> > Unsubscribe
> > Recent Activity
> > 3
> > New Members
> > 3
> > New Files
> > Visit Your Group
> > Yahoo! Search
> > Find it faster
> > with Yahoo!
> > shortcuts.
> > Y! Messenger
> > Send pics quick
> > Share photos while
> > you IM friends..
> > Moderator Central
> > Yahoo! Groups
> > Get the latest news
> > from the team..
> > ,...,_
> > #ygrp-mkp{
> 0px;padding: 0px
> > 14px;}
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> 122%;margin:
> > 10px
> > 0px;}
> > #ygrp-mkp #ads{
> > #ygrp-mkp ..ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
> 122%;}
> clean,
> > sans-serif;}
> clean,
> > sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right;
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
> 8px;}
> > #ygrp-vital #vithd{
> > text-transform
> > :uppercase;}
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> align:right;
> > paddin
> > g-right:.5em; }
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> 100%;line-
> > height:
> > 122%;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> > ________
> biomechanical
> > #ygrp-mkp{
> 0px;padding: 0px
> > 14px;}
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> 122%;margin: 10px
> > 0px;}
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
> 122%;}
> clean,
> > sans-serif;}
> clean,
> > sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right; }
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
> 8px;}
> > #ygrp-vital #vithd{
color:#333;
> text-transform
> > :uppercase;}
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> align:right; paddin
> > g-right:.5em; }
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> 100%;line- height:
> > 122%;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> > ________
> biomechanical
> > #ygrp-mkp{
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
122%;}
> clean, sans-serif;}
> clean, sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right; }
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
8px;}
> > #ygrp-vital #vithd{
color:#333; text-
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> ____________ __
> #ygrp-mkp{
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
> margin:10px 0px;font-weight: bold;font- size:78%; line-height: 122%;}
clean, sans-serif;}
clean, sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right; }
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
> background-color: #e0ecee;margin- bottom:20px; padding:2px 0 8px 8px;}
> #ygrp-vital #vithd{
> #ygrp-vital ul{
> #ygrp-vital ul li{
align:right; padding-right: ..5em;}
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
> Never miss a thing.. Make Yahoo your home page.
> http://www.yahoo. com/r/hs
#ygrp-mkp{
border:1px solid #d8d8d8;font-family:Arial;margin:14px 0px;padding:0px 14px;}
#ygrp-mkp hr{
#ygrp-mkp #hd{
color:#628c2a;font-size:85%;font-weight:bold;line-height:122%;margin:10px 0px;}
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
 #ygrp-mlmsg {font-size:13px;font-family:arial, helvetica, clean, sans-serif;}
#ygrp-mlmsg select, input, textarea {font:99% arial, helvetica, clean,
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
clear:both;margin:25px 0;white-space:nowrap;color:#666;text-align:right;}
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
font-size:77%;font-family:Verdana;font-weight:bold;color:#333;text-transform:upp
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
font-weight:bold;color:#ff7900;float:right;width:2em;text-align:right;padding-ri
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
font-family:Arial;font-weight:bold;color:#628c2a;font-size:100%;line-height:122%
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
________________________________________________________________________________\
http://tools.search.yahoo.com/newsearch/category.php?category=shopping
This is very confusing, I have tried the files you uploaded and they
are working perfectly! But there are still some possible problem I'm
thinking in.
Do you have more than one Seg file you are playing around with? In
that case make sure you are including the good one. Load your model
without the ligament, open you Seg file and verify that at the top of
the window after the file name you can see "...\Seg.any-Loaded". If
the window says "Not Loaded" then you are simply not including the
file, modify the code to include it.
Once that is checked, find in the model three the Seg folder and the
CalcaneoFibularNode in the foot and shank. Use this to insert the
node name directly from the three in the Lig file (Org and Ins), this
way you will have the full path and there are no mistakes possible.
Please notice that when you want to send a file you must upload it in
the file section, files in attachment with the message are removed
automatically and we don't receive them.
> Hi,
not see them, i have created a folder in the files section in the
anyscpit group.
> Let me know
> Thanks
> Regards
> To: anyscript@...
> Hi,
> Best regards,
> > Hi
again.
> > Seg
> > Lig
> > LigPar
> > LegMus3E.root
> > Regards
> > Hi Mike,
path.
> I
node
> is
spelling
should
> be
> require
what
> those
> > Best regards,
wrote:
> > > Hi
> one
> Mus.any
> > > // Ligaments
> > > AnyFolder Lig = {
> > > #include "Lig.any"
> statement:
> > > //Calcanefibular Ligament
> > > AnyViaPointLigament CalcaneoFibular = {
> > > AnyRefNode &Org
> ode;
> > > AnyDrawPLine drw = {
> > > Thickness = 0.002;
> > > RGB = {1,0,0};
> > statement:
> > > AnyLigamentModelPol CalcaneoFibularPar = {
> > > L0 = 0.375;
> > > eps1 = 0.053;
> > > // a0 = 1;
> > > // a1 = 1;
> > > // LinRegionOnOff = On;
> > Unresolved object
file.
some
> > > Regards
> > > Hi Mike
> > attach on the
> that
> > it will
> > length change
> > shank.
> > sorry for
thanks
> > for making
> > means that
> have
automatically
> > be part of
> another
> > folder
> > calibrate it
> > > Best regards
> > > From: anyscript@yahoogrou ps.com [mailto:anyscript@ yahoogrou
> > ps.com] On Behalf
> > > Of Mike Arakilo
> > > Hi
> > > I understood very well what you have meant and it sounds fair
> > enough though
nodes
> > are more
> > > effective.
> > > I followed the procedure you have told me but i got some errors.
> > > for the Calcaneo fibular ligament i made the following
statments
> > and put
statements
> in
> > the foot
> > > folder:
> > > // Drawing of the ORIGIN point of the calcaneofibular ligament
on
> > the
> > > calcaneous
> > > AnyDrawRefFrame drwRefFrameHeelNode = {RGB = {0, 0, 0};};
> > > // Drawing the INSERTION point of the calcaneofibular
ligament
> on
> > the
> > > Lateral Maleolous
0.025} );
> {0,
> > 0, 0};};
statements:
> > > //AnyRefNode &Via = .Arm.ViaNode;
> > > Thickness = 0.05;
> > > RGB = {1,0,0};
> statments
> > > // Ligament Parameter for CalcaneoFibular Ligament
> > > L0 = 0.375;
> > > eps1 = 0..053;
> > > // a0 = 1;
> > > // a1 = 1;
> > > The ligament parameters are set randomly just for I can test
the
> > code. But i
> > > I got the following warning during building the model.
> > > Configuring model...
> > 51) :
> > initialization of
> > y1' :
> > > Dependency (Right-hand side or internal dependency) has
earlier
> > evaluation
> > > moment than this AnyVarRef object, which is not allowed for
> > AnyVarRef
> > > initialization.
> > > Location of 'L0' :
> 21)
any
> > (51) :
> > initialization of
> > y1' :
earlier
> > evaluation
> > AnyVarRef
> > > initialization.
> > > Location of 'L0' :
> 21)
> > > I beleive they are the same warming but for right and left.
> > > and then i got a strange ligament model so big and round all
the
> > ankle
> > > I have run muscle calibration and Inverse Dynamics and got a
> folder
> > for this
> > > ligament with postion velocity and acceleration without any
> Forces.
> > > What can I do to enhance this model for i can add further
> ligaments
> > at a
> > > later stage?
> > > I have tried to put a muscle model on the calcaneofibular
> ligament
> > using
> > > AnyMuscleModel3E and AnyViaPointMuscle and it worked without
> > warmings and
> > > Can i get further help in this ?
> > > Regards
> > > Sent: Tuesday, March 25, 2008 11:09:25 AM
> > > Hi Mike
> > > The Leg3D model of the repository which the Gait3D model is
> using,
> > do not
> > > include the Fibula bone, so I am little confused, but maybe you
> > thought that
> > > the Tibia and Fibula bone geometry file was somehow merged in
> this
> > model.
> > > I have double checked and the Tibia bone looks ok in the Gait3D
> > model.
> > > In order to add the Calcaneo fibular ligament you will need to
> add
> > a new
> > > node on Tibia for this at the Malleolus lateralis. This node
will
> > be placed
> > > in free air since the Fibula is not there.
> > > I hope it made things clearer, otherwise please write again
> > > Best regards
> > ps.com] On
> > > Behalf
> > > Of Mike Arakilo
> > > Sent: 20 March 2008 14:50
> > > Hi again
to
> > the model
> > > in Gait3D and i have noticed a mistake in the model itself.
> the
> > process,
mistake
> > with the
> > > model on the fibula.
be
> on
> > the
> > > right and pointing outwards the body whereas in this model it
is
> on
> > the left
> > > and pointing inside.
example
> > the
> > > lateral malleolus is strictly affected by the fibula. Is there
> any
> > solution
> > > for correcting the model ?
> > > Regards
> > > Hi Mike
> has
> > to make
other.
> > geometry are
> > would not
possible
> to
> > scale
> depending
> > on the
the
> > > Best regards
> > ps.com] On
> > > Behalf
> > > Of Mike Arakilo
> > > Hi Sylvain
real
> > ones ?
> > > Regards
> > > Hi Mike,
origin
> > and
> done
> and
> the
> frame
> > such
> node
> > of
> > have
to
> > folder
simulation.
> > You
Pos,
> > you
> > > Best regards,
wrote:
> > > > Hi,
> try
> > > the
need..
very
> > well
wanted
> > to
> > > ask
> reference
> define
> > forces.
> > > I
> simulation
> > > but
> > investigate
> > > the
> > > > Thanks
> > > > Mike
> > > ..,._
> > (2)
> > > Start a new topic
> > > Messages |
> > Files |
> > > Photos | Links |
> > Database |
Digest
> > Switch
> > > Visit Your Group
> > > Unsubscribe
> > > Recent Activity
> > > 3
> > > New Members
> > > 2
> > > New Files
> > > Visit Your Group
> > > Yahoo! Search
> > > Try a shortcut
> > > Get local weather
> > > faster.
> > > Y! Messenger
> > > Files to share?
> > > Send up to 1GB of
> > > files in an IM..
> > > All-Bran
> > > Day 10 Club
> > > on Yahoo! Groups
> > > #ygrp-mkp{
> > 0px;padding: 0px
> > > 14px;}
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > 122%;margin:
> > > 10px
> > > 0px;}
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp .ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> > 122%;}
> > clean,
> > > sans-serif;}
> > clean,
> > > sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right;
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> > 8px;}
> > > #ygrp-vital #vithd{
color:#333;
> > > text-transform
> > > :uppercase;}
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > align:right;
> > > paddin
> > > g-right:.5em; }
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > 100%;line-
> > > height:
> > > 122%;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > > ________
> category=
> > shopping
> > biomechanical
> > > Start a new topic
> > > Messages |
> > Files |
> > > Photos | Links |
> > Database |
Digest
> > Switch
> > > Visit Your Group
> > > Unsubscribe
> > > Recent Activity
> > > 3
> > > New Members
> > > 3
> > > New Files
> > > Visit Your Group
> > > Yahoo! Search
> > > Find it faster
> > > with Yahoo!
> > > shortcuts.
> > > Y! Messenger
> > > Send pics quick
> > > Share photos while
> > > you IM friends..
> > > Moderator Central
> > > Yahoo! Groups
> > > Get the latest news
> > > from the team..
> > > ,...,_
> > > #ygrp-mkp{
> > 0px;padding: 0px
> > > 14px;}
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > 122%;margin:
> > > 10px
> > > 0px;}
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp ..ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> > 122%;}
> > clean,
> > > sans-serif;}
> > clean,
> > > sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right;
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> > 8px;}
> > > #ygrp-vital #vithd{
color:#333;
> > > text-transform
> > > :uppercase;}
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > align:right;
> > > paddin
> > > g-right:.5em; }
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > 100%;line-
> > > height:
> > > 122%;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > > ________
> > > http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
> > biomechanical
> > > #ygrp-mkp{
> > 0px;padding: 0px
> > > 14px;}
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > 122%;margin: 10px
> > > 0px;}
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp .ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> > 122%;}
> > clean,
> > > sans-serif;}
> > clean,
> > > sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right; }
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> > 8px;}
> > > #ygrp-vital #vithd{
> color:#333;
> > text-transform
> > > :uppercase;}
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > align:right; paddin
> > > g-right:.5em; }
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > 100%;line- height:
> > > 122%;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > > ________
> > biomechanical
> > > #ygrp-mkp{
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp .ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> 122%;}
> > clean, sans-serif;}
> > clean, sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right; }
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> 8px;}
> > > #ygrp-vital #vithd{
> color:#333; text-
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > ____________ __
> > #ygrp-mkp{
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
122%;}
> clean, sans-serif;}
> clean, sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right; }
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
8px;}
> > #ygrp-vital #vithd{
color:#333; text-
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> ____________ __
> #ygrp-mkp{
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
> font-family:Arial;}
clean, sans-serif;}
clean, sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family:Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right;}
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77%;}
> #reco-desc{
> font-size:77%;}
> #ygrp-vital{
> #ygrp-vital #vithd{
> #ygrp-vital ul{
> #ygrp-vital ul li{
> font-weight:bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
> margin:0;}
> o{font-size:0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120%;}
> .replbq{margin:4;}
I am getting confused right now of what is going on here.
I have tried the files on another computer and it gave me the same error, I
really dont know why is that.
Just to mention that i have 1 seg file and i m just modifying the existing files
in the repository without creating copies so there will not be problem of
duplicate files.
I have followed your advide by putting the whole path.
It worked for that line and went with error to the other line.
I have put again the whole path for Ins and gave me the same error but now with
another file.
I have me unresolved object in the LegMus3E.root pointing to AnyVar
StressIndex=.StrengthRef.StrengthIndexLeg in
Can you imagine this ?
there is just up this instruction
AnyFolder MusPar = {
#include "MusPar.any"
and didint give any error,
So i have put this statment #include "LigPar.any" in the MusPar to solve this
object and finnally i got everything compiled and it showed me the ligament. But
this is not the way I want to work, Why i m going the hard way while i can't use
the easy way ?
Surprisingly after running i have found the folder Lig in MassSummation and not
under Mus and Seg,
Fin was 0 and Fout was 0 but position was variable ....
How are we gonna solve this issue ?
Regards
Sent: Friday, March 28, 2008 1:48:37 PM
thinking in.
the window after the file name you can see "...\Seg.any- Loaded". If
> Hi,
anyscpit group.
> Let me know
> Thanks
> Regards
> To: anyscript@.. .
> Hi,
> Best regards,
> > Hi
again.
> > Seg
> > Lig
> > LigPar
> > LegMus3E.root
> > Regards
> > Hi Mike,
path.
> I
node
> is
spelling
> > write "AnyRefNode &Org = ..Seg.Shank. . CalcaneoFibularN ode;"
should
> be
> require
what
> those
> > Best regards,
> > --- In anyscript@yahoogrou ps.com, Mike Arakilo <marakilo@ ..>
wrote:
> > > Hi
> > > I have followed your advice and have put one node in shank and
> one
> > > I have also made an include file called Lig.any
> > > Another include file called LigPar.any
> > > I was searching in the BodyModel_Mus3E where we do call the
> Mus.any
> > > So, i have made two folders there next to them as follows
> > > // Ligaments
> > > AnyFolder Lig = {
> > > #include "Lig.any"
> > > // LigamentParameters
> > > AnyFolder LigPar = {
> > > In the include file Lig.any i have included the following
> statement:
> > > AnyRefNode &Org
> ode;
> > THIS IS LINE 14 WHERE I AM GETTING THE ERROR !
> > > Thickness = 0.002;
> > > RGB = {1,0,0};
> > > In the include file LigPar.any i have included teh following
> > statement:
> > > AnyVar StrengthScaleShank
> > > AnyVar StrengthScaleThigh
> > > AnyVar StrengthScalePelvis
> > > //Ligament Parameter for CalcaneoFibular Ligament
> > > L0 = 0.375;
> > > eps1 = 0.053;
> > > // a0 = 1;
> > > // a1 = 1;
> > > Running the Model back again I am getting a silly error from a
> > Unresolved object
> > > As I can see, it didn't have any problem with the LigPar,any
file.
> > > I tried to swap the insertion and origin points but i am still
some
> > call somewhere else..
> > > I do beleive that it will be difficult always to put the first
> > > Regards
> > > Hi Mike
> > > As I read your script the ligament originates on the foot and
> > attach on the
> > > foot, and it do not have connection to other nodes. This means
> that
> > it will
> > > not have any effect on the model at all since there will be no
> > length change
> > > for any movement. I guess one of these nodes should be on the
> > shank.
> > > About the error message, this is a bug in the system, I am very
> > sorry for
> > > this. We will fix this for the next release of the system,
thanks
> > for making
> > > us aware of this. L0 is by mistake set to be a Constant, which
> > means that
> > > the calibration study is not allowed to calibrate it. Since you
> have
> > > inserted the ligament in the muscles folder it will
automatically
> > be part of
> > > the calibration study with the muscles.
> > > The best way for you to fix it, is to place the ligament in
> another
> > folder
> > > than the muscles so that it will not be calibrated and then
> > calibrate it
> > > manually, by adjusting the parameters like L0.
> > > There is a tutorial about the ligaments if you have not seen it
> > > http://www.anybodyt ech.com/682. 0.html it might be helpful.
> > > Best regards
> > ps.com] On Behalf
> > > Of Mike Arakilo
> > > Sent: 25 March 2008 15:02
> > > Hi
> > enough though
> > > i understand that the bones are for visual purposes and the
nodes
> > are more
> > > effective.
statments
> > and put
> > > them in the specific file:
> > > In BRep/Aalborg/ Leg3D/Seg i have added the following
statements
> in
> > the foot
> > > folder:
on
> > the
> > > calcaneous
> > > AnyRefNode CalcaneoFibularOrig in = {
> > > sRel = .Scale({0.012, 0.075, ....Sign0.022} );
ligament
> on
> > the
> > > Lateral Maleolous
> > > AnyRefNode CalcaneofubularInse rtion = {
> > > sRel = .Scale({0.065, 0...053, ...Sign
0.025} );
> > > AnyDrawRefFrame drwRefFrameLateralM aleolouusNode = {RGB =
> {0,
> > 0, 0};};
> > > In BRep/Aalborg/ Leg3D/Mus i have added the following
statements:
> > > AnyLigamentModelPol &LigMdl = ..MusPar.CalcaneoFi bularPar;
> > > AnyRefNode &Ori = ..Seg.Foot.Calcaneo FibularOrigin;
> > > AnyRefNode &Ins = ..Seg.Foot.Calcaneo fubularInsertion ;
> > > Thickness = 0.05;
> > > RGB = {1,0,0};
> > > In BRep/Aalborg/ Leg3D/MusPar i have added the following
> statments
> > > L0 = 0.375;
> > > eps1 = 0..053;
> > > F1 = .StrengthScaleShank .StressIndex 1000;
> > > // a0 = 1;
> > > // a1 = 1;
the
> > code. But i
> > > got a strange drawing of that ligament with some warmings.
> > > WARNING(OBJ. DES1) :
> > > T:\AnyScripts\ Repository. 6.1\BRep\ Aalborg\Leg3D\ LegCal1.any
> > 51) :
> > > 'LegCalibrationStud y1.Internal_ dependency' : Wrong
> > initialization of
> > > 'AnyVarRef' linking to value 'L0' in study 'LegCalibrationStud
> > y1' :
earlier
> > evaluation
> > AnyVarRef
> > > initialization.
> > > Location of 'L0' :
> > > T:\AnyScripts\ Repository. 6.1\BRep\ Aalborg\Leg3D\ MusPar.any(
> 21)
> > > T:\AnyScripts\ Repository. 6.1\BRep\ Aalborg\Leg3D\ LegCal1...
any
> > (51) :
> > initialization of
> > y1' :
earlier
> > evaluation
> > AnyVarRef
> > > initialization.
> > > Location of 'L0' :
> 21)
the
> > ankle
> folder
> > for this
> Forces.
> ligaments
> > at a
> > > later stage?
> ligament
> > using
> > warmings and
> > > gave me all the forces and muscle activity.
> > > Regards
> > > Hi Mike
> using,
> > do not
> > thought that
> this
> > model.
> > model..
> add
> > a new
will
> > be placed
> > > Best regards
> > ps.com] On
> > > Behalf
> > > Of Mike Arakilo
> > > Hi again
to
> > the model
> the
> > process,
mistake
> > with the
be
> on
> > the
is
> on
> > the left
example
> > the
> any
> > solution
> > > Regards
> > > Hi Mike
> has
> > to make
other.
> > geometry are
> > would not
possible
> to
> > scale
> depending
> > on the
the
> > > Best regards
> > ps.com] On
> > > Behalf
> > > Of Mike Arakilo
> > > Hi Sylvain
real
> > ones ?
> > > Regards
> > > Hi Mike,
origin
> > and
> done
> and
> the
> frame
> > such
> node
> > of
> > have
to
> > folder
> > > you already found (..../Jnt/Ankle) after running the
simulation.
> > You
Pos,
> > you
> > > Best regards,
wrote:
> > > > Hi,
> try
> > > the
> > > > one segment model in anybody and see if i can get data i
need..
very
> > well
wanted
> > to
> > > ask
> reference
> define
> > forces.
> > > I
> simulation
> > > but
> > investigate
> > > the
> > > > Thanks
> > > > Mike
> > > ..,._
> > (2)
> > > Start a new topic
> > > Messages |
> > Files |
> > > Photos | Links |
> > Database |
Digest
> > Switch
> > > Visit Your Group
> > > Unsubscribe
> > > Recent Activity
> > > 3
> > > New Members
> > > 2
> > > New Files
> > > Visit Your Group
> > > Yahoo! Search
> > > Try a shortcut
> > > Get local weather
> > > faster.
> > > Y! Messenger
> > > Files to share?
> > > Send up to 1GB of
> > > files in an IM..
> > > All-Bran
> > > Day 10 Club
> > > on Yahoo! Groups
> > > #ygrp-mkp{
> > 0px;padding: 0px
> > > 14px;}
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > 122%;margin:
> > > 10px
> > > 0px;}
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp .ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> > 122%;}
> > clean,
> > > sans-serif;}
> > clean,
> > > sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right;
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> > 8px;}
> > > #ygrp-vital #vithd{
color:#333;
> > > text-transform
> > > :uppercase;}
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > align:right;
> > > paddin
> > > g-right:.5em; }
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > 100%;line-
> > > height:
> > > 122%;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > > ________
> category=
> > shopping
> > biomechanical
> > > Start a new topic
> > > Messages |
> > Files |
> > > Photos | Links |
> > Database |
Digest
> > Switch
> > > Visit Your Group
> > > Unsubscribe
> > > Recent Activity
> > > 3
> > > New Members
> > > 3
> > > New Files
> > > Visit Your Group
> > > Yahoo! Search
> > > Find it faster
> > > with Yahoo!
> > > shortcuts.
> > > Y! Messenger
> > > Send pics quick
> > > Share photos while
> > > you IM friends..
> > > Moderator Central
> > > Yahoo! Groups
> > > Get the latest news
> > > from the team..
> > > ,...,_
> > > #ygrp-mkp{
> > 0px;padding: 0px
> > > 14px;}
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > 122%;margin:
> > > 10px
> > > 0px;}
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp ..ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> > 122%;}
> > clean,
> > > sans-serif;}
> > clean,
> > > sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right;
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> > 8px;}
> > > #ygrp-vital #vithd{
color:#333;
> > > text-transform
> > > :uppercase;}
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > align:right;
> > > paddin
> > > g-right:.5em; }
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > 100%;line-
> > > height:
> > > 122%;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > > ________
> > biomechanical
> > > #ygrp-mkp{
> > 0px;padding: 0px
> > > 14px;}
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > 122%;margin: 10px
> > > 0px;}
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp .ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> > 122%;}
> > clean,
> > > sans-serif;}
> > clean,
> > > sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right; }
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> > 8px;}
> > > #ygrp-vital #vithd{
> color:#333;
> > text-transform
> > > :uppercase;}
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > align:right; paddin
> > > g-right:.5em; }
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > 100%;line- height:
> > > 122%;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > > ________
> > biomechanical
> > > #ygrp-mkp{
> > > #ygrp-mkp hr{
> > > #ygrp-mkp #hd{
> > > #ygrp-mkp #ads{
> > > #ygrp-mkp .ad{
> > > padding:0 0;}
> > > #ygrp-mkp .ad a{
> 122%;}
> > clean, sans-serif;}
> > clean, sans-serif;}
> > > #ygrp-text{
> > > #ygrp-text p{
> > > margin:0 0 1em 0;}
> > > #ygrp-tpmsgs{
> > > font-family: Arial;
> > > clear:both;}
> > > #ygrp-vitnav{
0;}
> > > #ygrp-vitnav a{
> > > padding:0 1px;}
> > > #ygrp-actbar{
> > align:right; }
> > > #ygrp-actbar .left{
> > > #ygrp-grft{
> > > #ygrp-ft{
> > > padding:5px 0;
> > > #ygrp-mlmsg #logo{
> > > #ygrp-reco {
> > > #reco-grpname{
> > > #reco-category{
> > > font-size:77% ;}
> > > #reco-desc{
> > > font-size:77% ;}
> > > #ygrp-vital{
8px
> 8px;}
> > > #ygrp-vital #vithd{
> color:#333; text-
> > > #ygrp-vital ul{
> > > #ygrp-vital ul li{
> > > #ygrp-vital ul li ..cat{
> > > font-weight: bold;}
> > > #ygrp-vital a{
> > > #ygrp-sponsor #hd{
> > > #ygrp-sponsor #ov{
20px;}
> > > #ygrp-sponsor #nc{
> > > #ygrp-sponsor .ad{
> > > padding:8px 0;}
> > > margin:0;}
> > > o{font-size: 0;}
> > > .MsoNormal{
> > > margin:0 0 0 0;}
> > > #ygrp-text tt{
> > > font-size:120% ;}
> > > .replbq{margin: 4;}
> > ____________ __
> > #ygrp-mkp{
> > #ygrp-mkp hr{
> > #ygrp-mkp #hd{
> > #ygrp-mkp #ads{
> > #ygrp-mkp .ad{
> > padding:0 0;}
> > #ygrp-mkp .ad a{
122%;}
> clean, sans-serif;}
> clean, sans-serif;}
> > #ygrp-text{
> > #ygrp-text p{
> > margin:0 0 1em 0;}
> > #ygrp-tpmsgs{
> > font-family: Arial;
> > clear:both;}
> > #ygrp-vitnav{
> > #ygrp-vitnav a{
> > padding:0 1px;}
> > #ygrp-actbar{
> align:right; }
> > #ygrp-actbar .left{
> > #ygrp-grft{
> > #ygrp-ft{
> > padding:5px 0;
> > #ygrp-mlmsg #logo{
> > #ygrp-reco {
> > #reco-grpname{
> > #reco-category{
> > font-size:77% ;}
> > #reco-desc{
> > font-size:77% ;}
> > #ygrp-vital{
8px;}
> > #ygrp-vital #vithd{
color:#333; text-
> > #ygrp-vital ul{
> > #ygrp-vital ul li{
> > font-weight: bold;}
> > #ygrp-vital a{
> > #ygrp-sponsor #hd{
> > #ygrp-sponsor #ov{
> > #ygrp-sponsor #nc{
> > #ygrp-sponsor .ad{
> > padding:8px 0;}
> > margin:0;}
> > o{font-size: 0;}
> > .MsoNormal{
> > margin:0 0 0 0;}
> > #ygrp-text tt{
> > font-size:120% ;}
> > .replbq{margin: 4;}
> ____________ __
> #ygrp-mkp{
> #ygrp-mkp hr{
> #ygrp-mkp #hd{
> #ygrp-mkp #ads{
> #ygrp-mkp .ad{
> padding:0 0;}
> #ygrp-mkp .ad a{
clean, sans-serif;}
clean, sans-serif;}
> #ygrp-text{
> #ygrp-text p{
> margin:0 0 1em 0;}
> #ygrp-tpmsgs{
> font-family: Arial;
> clear:both;}
> #ygrp-vitnav{
> #ygrp-vitnav a{
> padding:0 1px;}
> #ygrp-actbar{
align:right; }
> #ygrp-actbar .left{
> #ygrp-grft{
> #ygrp-ft{
> padding:5px 0;
> #ygrp-mlmsg #logo{
> #ygrp-reco {
> #reco-grpname{
> #reco-category{
> font-size:77% ;}
> #reco-desc{
> font-size:77% ;}
> #ygrp-vital{
> #ygrp-vital #vithd{
> #ygrp-vital ul{
> #ygrp-vital ul li{
> font-weight: bold;}
> #ygrp-vital a{
> #ygrp-sponsor #hd{
> #ygrp-sponsor #ov{
> #ygrp-sponsor #nc{
> #ygrp-sponsor .ad{
> padding:8px 0;}
> margin:0;}
> o{font-size: 0;}
> .MsoNormal{
> margin:0 0 0 0;}
> #ygrp-text tt{
> font-size:120% ;}
> .replbq{margin: 4;}
http://tools. search.yahoo. com/newsearch/ category. php?category= shopping
#ygrp-mkp{
#ygrp-mkp hr{
#ygrp-mkp #hd{
#ygrp-mkp #ads{
#ygrp-mkp .ad{
padding:0 0;}
#ygrp-mkp .ad a{
font-family:Arial;}
sans-serif;}
#ygrp-text{
#ygrp-text p{
margin:0 0 1em 0;}
#ygrp-tpmsgs{
font-family:Arial;
clear:both;}
#ygrp-vitnav{
#ygrp-vitnav a{
padding:0 1px;}
#ygrp-actbar{
#ygrp-actbar .left{
#ygrp-grft{
#ygrp-ft{
padding:5px 0;
#ygrp-mlmsg #logo{
#ygrp-reco {
#reco-grpname{
#reco-category{
font-size:77%;}
#reco-desc{
font-size:77%;}
#ygrp-vital{
#ygrp-vital #vithd{
ercase;}
#ygrp-vital ul{
#ygrp-vital ul li{
ght:.5em;}
font-weight:bold;}
#ygrp-vital a{
#ygrp-sponsor #hd{
#ygrp-sponsor #ov{
#ygrp-sponsor #nc{
#ygrp-sponsor .ad{
padding:8px 0;}
margin:0;}
o{font-size:0;}
.MsoNormal{
margin:0 0 0 0;}
#ygrp-text tt{
font-size:120%;}
.replbq{margin:4;}
OMG, Sweet deal for Yahoo! users/friends:Get A Month of Blockbuster Total
Access, No Cost. W00t
http://tc..deals.yahoo.com/tc/blockbuster/text2.com
