I am trying adjusting anthropometric data of human in "Human Standing" template.
By the way, can I know where I can adjust the height and weight of human directly?
I adjusted "SubjectSpecificData.any" file when I used MOCAP application like below picture, but I cannot found similar file on Human Standing template.
What you do is that you define a file that contain all the scaling and anthropometry data of your model.
Its what we normally call a "AnyMan file" and you can find templates for the different scaling laws in your ammr directory at: ammr\Body\AAUHuman\Scaling\AnyFamily.
You take a copy of the file that matches the scaling law fit for your model and reference this file using: #path BM_SCALING_ANTHRO_FILE "path/to/new/AnyMan.any "
From default the standing template uses a 50th percentile scaling and unless you use that you must change the scaling law of the model with: #define BM_SCALING <scaling law identifier>
You can find all the scaling law identifiers here.
I see a typo on the line where you have #define BM_SCALING_SCALING_UNIFORM_
There should be a whitespace character between BM_SCALING and _SCALING_UNIFORM_
so it is: #define BM_SCALING _SCALING_UNIFORM
I noticed that you are making changes to your ammr repository files (the HumanModel.any) .
I would advice you to not do so as any change will affect all models you load with that repository.
Instead you can add you #define and #path statements to you model directory.
You could add the lines to the Model/BodyModelConfiguration.any file - that way it only affects the model you are working on.
