I'm running a simulation using motion capture, for that I started with the "FullBody_GRFPredition.main.any" model and just made some necessary modifications and up to this point everything worked as expected. Next, I want to collect angle variation data from the hip, knee, and ankle joints, how should I proceed?
You can plot the joint angles in the AnyBody Chart view or export them and then process them as per your needs. You can find some information about working with the chart view in this tutorial.
Instead, for exporting the output, you should look at the reference manual for AnyOutputFile. Actually, when you run the MarkerTracking operation, the joint angles are exported already (which are then used to provide the motion in inverse dynamics operation). You can find these output files in the Output folder for your model.
Thank you very much for the answer, it worked
But I have one remaining question. I generated the graph below, but I would like to check what exactly is the y-axis unit, what is "pos"? Meters, degrees...
