Hello
standing model in this 2 versions of AnyBody results in diffrents numbers! may i ask you which one is more reliable??
the results of joint reaction force in V.5 or V.4 of AnyBody?
thanks alot
Hello
thanks alot
can you please be more precise!
Did you use the same models from the same repository?
You should use always the newest Repository. AMMRv1.3.1 and then there should not be differences between v4 or v5 of the AnyBody Modeling system!
If you have a specific example, you can upload the file here to check it.
