anyforce drawing question
Hi AnyBody guys and gals (and anyone else who wants to do some bug testing) -
This may be a bug…not quite sure. Let me tell you what is going ‘wrong’
(beyond what is
in my head).
I have been playing around with the Rowing Machine Microgravity ESA example in
Repository 7.0. For fun I decided to plot the forces that are being applied to
the hands
and the feet. I believe they are in the Loads folder in the Environment.any
file. I tried
plotting the forces quickly and I noticed they were pointing in the same
direction. That
seemed very weird as looking in the model heirarchy, they are clearly the
negatives of one
another.
I am copying the Load = { } (see below); folder that goes in the Environment.any
file that I
have been using. I have created 2 scenarios (see how Vec = {} is defined in
each of the
drawing functions). The first one (i.e. Vec = {1,0,0} and Vec = {-1,0,0}), for
me, produces
vectors pointing in the same direction. The second one (i.e. Vec = {0,1,0} and
Vec = {0,-
1,0}) produces vectors pointing in opposite directions. I changed the point of
application
to the same reference frame, and got the same result. It seems as if the x
coordinate in
the plot function is ignoring the sign??
Hopefully I am doing something wrong and you can show me the error in my ways.
If not,
we can talk about my compensation.
Here is the code:
AnyFolder Load ={
 AnyFunInterpol Force =
   Type = Bspline;
   BsplineOrder = 4;
   FileName = "ReacForcesCase1.txt";
 AnyForce PushPullUnitForce =
   F = .Force(t)*(-1);
   AnyPrismaticJoint &PushPullJoint =
Main.Model.ModelEnvironmentConnection.Joints.PushPullGuideJnt;
   //draw the force...
   AnyDrawVector drF = {
     //Vec = {.Fout[0]/500,0,0};   // Scale the length down
     Vec = {1,0,0};   // Does not point in the opposite direction as the
force below
// Vec = {0,1,0}; // Does point in the opposite direction as the force
below
     Line = {
       Style = Line3DStyleFull;
       Thickness = 0.01;
       RGB = {1, 0, 0};
       End = {
         Style = Line3DCapStyleArrow;  // This specifies the end to be an
arrowhead
RGB = {1, 0, 0};
Thickness = 0.02; // The head begins with twice the thickness of
the shaft
Length = 0.05;
     // attach the arrow to the hand
     //AnyRefFrame &Palm = Main.ArmModel.Segs.ForeArm.PalmNode;
     AnyRefFrame &Palm =
Main.Model.EnvironmentModel.Seg.GrabStickSeg.PushPullJtNode;
//AnyRefFrame &Palm = Main.Model.EnvironmentModel.GlobalRef;
 //force applied to a kinematic measure defined by a prismatic joint
 AnyForce FootRestForce =
   F = .Force(t)*(1);
   AnyPrismaticJoint &FootRestJoint =
Main.Model.ModelEnvironmentConnection.Joints.FootRestGuideJnt;
   //draw the force...
     Vec = {-1,0,0};   //does not point in the opposite direction as the
force above
//Vec = {0,-1,0}; //does point in the opposite direction as the force
above
     Line = {
       Thickness = 0.01;
       RGB = {0, 1, 0};
       End = {
arrowhead
RGB = {0, 1, 0};
the shaft
Length = 0.05;
     AnyRefFrame &Palm =
Main.Model.EnvironmentModel.Seg.FootRestSeg.FootRestLinearGuideNode;
}; //Load
Hey David,
You are right, this sound a little bit strange. I tried to replicate your
problem and I could not found anything suspicious.
The vectors are actually plotted in the opposite directions, so I’m not sure
how I can help you. Which version of the AMS are you using?
Sebastian
Of dww805
Sent: 23. oktober 2008 01:37
Subject: [AnyScript] anyforce drawing question
(beyond what is
in my head).
in
to the hands
file. I tried
direction. That
negatives of one
another.
Environment.any file that I
each of the
for me, produces
and Vec = {0,-
of application
coordinate in
ways. If not,
Here is the code:
AnyFolder Load ={
Type = Bspline;
BsplineOrder = 4;
FileName = “ReacForcesCase1.txt”;
F = .Force(t)*(-1);
//draw the force…
Vec = {1,0,0}; // Does not point in the opposite direction as the force
below
// Vec = {0,1,0}; // Does point in the opposite direction as the force below
Line = {
Thickness = 0.01;
RGB = {1, 0, 0};
End = {
Style = Line3DCapStyleArrow; // This specifies the end to be an arrowhead
RGB = {1, 0, 0};
Thickness = 0.02; // The head begins with twice the thickness of the shaft
Length = 0.05;
AnyRefFrame &Palm =
F = .Force(t)*(1);
//draw the force…
Vec = {-1,0,0}; //does not point in the opposite direction as the force
above
//Vec = {0,-1,0}; //does point in the opposite direction as the force above
Line = {
Thickness = 0.01;
RGB = {0, 1, 0};
End = {
RGB = {0, 1, 0};
Length = 0.05;
AnyRefFrame &Palm =
}; //Load
Hey Sebastian,
Well it is good that you don’t have the problem (means it probably is something
wrong
only on my end). The AnyBody version I am using is:
AnyBody version : 3. 0. 3.
Build : 14070.26941
I am uploading a picture of what I am seeing (ESARowing_drawVecError.png). No
matter if
I use Vec = {-1,0,0}; or Vec = {1,0,0}, I get the vectors pointing in the same
direction (to
the left, in the positive global X direction).
Any other thoughts?
Best,
David
— In anyscript@yahoogroups.com, Sebastian Dendorfer <anyscriptsup@…> wrote:
> Hey David,
> Best regards,
> Sebastian
> _____
> Of dww805
> (beyond what is
> in my head).
> in
> to the hands
> file. I tried
> direction. That
> negatives of one
> another.
> each of the
> for me, produces
> and Vec = {0,-
> of application
> coordinate in
> ways. If not,
> Here is the code:
> AnyFolder Load ={
> Type = Bspline;
> BsplineOrder = 4;
> F = .Force(t)(-1);
> //draw the force…
> below
> Line = {
> Thickness = 0.01;
> RGB = {1, 0, 0};
> End = {
> RGB = {1, 0, 0};
> Length = 0.05;
> AnyRefFrame &Palm =
> F = .Force(t)
(1);
> //draw the force…
> above
> Line = {
> Thickness = 0.01;
> RGB = {0, 1, 0};
> End = {
> RGB = {0, 1, 0};
> Length = 0.05;
> AnyRefFrame &Palm =
> }; //Load
I have found something that may be the culprit. If I manually set ‘GlobalCoord’
to off (it
was by default set to ‘on’), I don’t seem to get the problem documented below.
Maybe this
will help with reproducing the issue on your end. And whether or not this is
actually a
problem.
Best,
David
— In anyscript@yahoogroups.com, “dww805” <dwwagner@…> wrote:
> Hey Sebastian,
something wrong
> Build : 14070.26941
matter
if
direction (to
> Any other thoughts?
> Best,
> David
> — In anyscript@yahoogroups.com, Sebastian Dendorfer <anyscriptsup@> wrote:
> > Hey David,
> > Best regards,
> > Sebastian
> > _____
> > Of dww805
> > (beyond what is
> > in my head).
> > in
> > to the hands
> > file. I tried
> > direction. That
> > negatives of one
> > another.
> > each of the
> > for me, produces
> > and Vec = {0,-
> > of application
> > coordinate in
> > ways. If not,
> > Here is the code:
> > AnyFolder Load ={
> > Type = Bspline;
> > BsplineOrder = 4;
> > F = .Force(t)(-1);
> > //draw the force…
> > below
> > Line = {
> > Thickness = 0.01;
> > RGB = {1, 0, 0};
> > End = {
> > RGB = {1, 0, 0};
> > Length = 0.05;
> > AnyRefFrame &Palm =
> > F = .Force(t)
(1);
> > //draw the force…
> > above
> > Line = {
> > Thickness = 0.01;
> > RGB = {0, 1, 0};
> > End = {
> > RGB = {0, 1, 0};
> > Length = 0.05;
> > AnyRefFrame &Palm =
> > }; //Load
Hi David,
We checked it again and there is no way to reproduce the error. I have
exactly the same version of Anybody (AnyBody version : 3. 0. 3. Build :
14070.26941) and I copy paste the exact code you send previously. But
everything is working fine, the vectors are pointing in opposite direction
as they should, regardless if the ‘GlobalCoord’ is On or Off.
Did you change anything in the model? Even if I can’t see what changes could
explain this behaviour.
So we did a small model displaying forces in opposite direction using the
same code (it works fine for us). Could you please try it so we can see if
the problem is coming from your model or from the software. The model is
bugvector.any.
Sylvain, AnyBody Support
Of dww805
Sent: 24. oktober 2008 00:27
Subject: [AnyScript] Re: anyforce drawing question
‘GlobalCoord’ to off (it
below. Maybe this
actually a
problem.
Best,
David
> Hey Sebastian,
something wrong
> Build : 14070.26941
No matter
if
same direction (to
> Any other thoughts?
> Best,
> David
> > Hey David,
your
sure
> > Best regards,
> > Sebastian
> > _____
> > From: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com
Behalf
> > Of dww805
> > To: anyscript@yahoogrou <mailto:anyscript%40yahoogroups.com> ps.com
testing)
‘wrong’
> > (beyond what is
> > in my head).
example
> > in
applied
> > to the hands
Environment.any
> > file. I tried
> > direction. That
the
> > negatives of one
> > another.
in
> > each of the
{-1,0,0}),
> > for me, produces
{0,1,0}
> > and Vec = {0,-
point
> > of application
x
> > coordinate in
> > ways. If not,
> > Here is the code:
> > AnyFolder Load ={
> > Type = Bspline;
> > BsplineOrder = 4;
> > F = .Force(t)(-1);
> > //draw the force…
> > below
below
> > Line = {
> > Thickness = 0.01;
> > RGB = {1, 0, 0};
> > End = {
arrowhead
> > RGB = {1, 0, 0};
shaft
> > Length = 0.05;
> > AnyRefFrame &Palm =
> > F = .Force(t)
(1);
> > //draw the force…
> > above
above
> > Line = {
> > Thickness = 0.01;
> > RGB = {0, 1, 0};
> > End = {
arrowhead
> > RGB = {0, 1, 0};
shaft
> > Length = 0.05;
> > AnyRefFrame &Palm =
> > }; //Load
Hi Sylvain,
I tried the bugvector code you wrote and I get the same error. I have uploaded
2 picture
of what I am seeing. bugvector_x.png is when:
Vec = {somevalueHere, 0,0} and
Vec = {-somevalueHere,0,0}
bugvector_y.png is when:
Vec = {0,somevalueHere,0} and
Vec = {0,-somevalueHere,0}
There is a clear difference. Any other ideas?
Best,
David
— In anyscript@yahoogroups.com, AnyScript Support <anyscriptsup@…> wrote:
> Hi David,
> bugvector.any.
> Best regards,
> _____
> Of dww805
> below. Maybe this
> actually a
> problem.
> Best,
> David
> “dww805” <dwwagner@> wrote:
> > Hey Sebastian,
> something wrong
> > Build : 14070.26941
> No matter
> if
> same direction (to
> > Any other thoughts?
> > Best,
> > David
> > > Hey David,
> your
> sure
> > > Best regards,
> > > Sebastian
> > > _____
> Behalf
> > > Of dww805
> testing)
> ‘wrong’
> > > (beyond what is
> > > in my head).
> example
> > > in
> applied
> > > to the hands
> Environment.any
> > > file. I tried
> > > direction. That
> the
> > > negatives of one
> > > another.
> in
> > > each of the
> {-1,0,0}),
> > > for me, produces
> {0,1,0}
> > > and Vec = {0,-
> point
> > > of application
> x
> > > coordinate in
> > > ways. If not,
> > > Here is the code:
> > > AnyFolder Load ={
> > > Type = Bspline;
> > > BsplineOrder = 4;
> > > F = .Force(t)(-1);
> > > //draw the force…
> > > below
> below
> > > Line = {
> > > Thickness = 0.01;
> > > RGB = {1, 0, 0};
> > > End = {
> arrowhead
> > > RGB = {1, 0, 0};
> shaft
> > > Length = 0.05;
> > > AnyRefFrame &Palm =
> > > F = .Force(t)
(1);
> > > //draw the force…
> > > above
> above
> > > Line = {
> > > Thickness = 0.01;
> > > RGB = {0, 1, 0};
> > > End = {
> arrowhead
> > > RGB = {0, 1, 0};
> shaft
> > > Length = 0.05;
> > > AnyRefFrame &Palm =
> > > }; //Load
Hi David
This is strange we do not see this error on our screens, so it must somehow
be related to a difference in hardware!
This is just a wild shoot: could you please try to compare the output from
doing a ctrl+PrtSc and the output from doing a right click +copy in the
modelview. I know these should be identical but at least for the text in the
ModelView, we have seen these to change color on some graphics adapters, so
maybe this could be something similar.
I think we will need some hardware details to resolve this issue; we will
contact you outside the group to exchange these.
Of dww805
Sent: 24 October 2008 17:52
Hi Sylvain,
uploaded 2 picture
Best,
David
> Hi David,
could
> bugvector.any.
> Best regards,
> _____
Behalf
> Of dww805
> below. Maybe this
is
> actually a
> problem.
> Best,
> David
> > Hey Sebastian,
> something wrong
> > Build : 14070.26941
> No matter
> if
the
> same direction (to
> > Any other thoughts?
> > Best,
> > David
> > > Hey David,
> your
not
> sure
> > > Best regards,
> > > Sebastian
> > > _____
On
> Behalf
> > > Of dww805
> testing)
> ‘wrong’
> > > (beyond what is
> > > in my head).
> example
> > > in
> applied
> > > to the hands
> Environment.any
> > > file. I tried
same
> > > direction. That
> the
> > > negatives of one
> > > another.
defined
> in
> > > each of the
> {-1,0,0}),
> > > for me, produces
> {0,1,0}
> > > and Vec = {0,-
> point
> > > of application
the
> x
> > > coordinate in
my
> > > ways. If not,
> > > Here is the code:
> > > AnyFolder Load ={
> > > Type = Bspline;
> > > BsplineOrder = 4;
> > > F = .Force(t)(-1);
> > > //draw the force…
force
> > > below
> below
> > > Line = {
> > > Thickness = 0.01;
> > > RGB = {1, 0, 0};
> > > End = {
> arrowhead
> > > RGB = {1, 0, 0};
> shaft
> > > Length = 0.05;
> > > AnyRefFrame &Palm =
> > > F = .Force(t)
(1);
> > > //draw the force…
force
> > > above
> above
> > > Line = {
> > > Thickness = 0.01;
> > > RGB = {0, 1, 0};
> > > End = {
> arrowhead
> > > RGB = {0, 1, 0};
> shaft
> > > Length = 0.05;
> > > AnyRefFrame &Palm =
> > > }; //Load
Hi Søren,
I did the right click + copy and that picture seems to be correct! I will reply
to your offline
email, but thought I would post here as well for anyone else that may encounter
something similar.
Best,
David
> Hi David
> Best regards
> _____
> Of dww805
> Hi Sylvain,
> uploaded 2 picture
> Best,
> David
> AnyScript Support <anyscriptsup@> wrote:
> > Hi David,
> could
> > bugvector.any.
> > Best regards,
> > _____
> Behalf
> > Of dww805
> > below. Maybe this
> is
> > actually a
> > problem.
> > Best,
> > David
> > > Hey Sebastian,
> > something wrong
> > > Build : 14070.26941
> > No matter
> > if
> the
> > same direction (to
> > > Any other thoughts?
> > > Best,
> > > David
> > > > Hey David,
> > your
> not
> > sure
> > > > Best regards,
> > > > Sebastian
> > > > _____
> On
> > Behalf
> > > > Of dww805
> > testing)
> > ‘wrong’
> > > > (beyond what is
> > > > in my head).
> > example
> > > > in
> > applied
> > > > to the hands
> > Environment.any
> > > > file. I tried
> same
> > > > direction. That
> > the
> > > > negatives of one
> > > > another.
> defined
> > in
> > > > each of the
> > {-1,0,0}),
> > > > for me, produces
> > {0,1,0}
> > > > and Vec = {0,-
> > point
> > > > of application
> the
> > x
> > > > coordinate in
> my
> > > > ways. If not,
> > > > Here is the code:
> > > > AnyFolder Load ={
> > > > Type = Bspline;
> > > > BsplineOrder = 4;
> > > > F = .Force(t)(-1);
> > > > //draw the force…
> force
> > > > below
> > below
> > > > Line = {
> > > > Thickness = 0.01;
> > > > RGB = {1, 0, 0};
> > > > End = {
> > arrowhead
> > > > RGB = {1, 0, 0};
> > shaft
> > > > Length = 0.05;
> > > > AnyRefFrame &Palm =
> > > > F = .Force(t)
(1);
> > > > //draw the force…
> force
> > > > above
> > above
> > > > Line = {
> > > > Thickness = 0.01;
> > > > RGB = {0, 1, 0};
> > > > End = {
> > arrowhead
> > > > RGB = {0, 1, 0};
> > shaft
> > > > Length = 0.05;
> > > > AnyRefFrame &Palm =
> > > > }; //Load
