AnyForceContactSurface depth function
Could anyone explain what represents the f(dv) in the formula of the pressure module, when we use our own penetration function ? From my point of view, f(dv) represents the pressure (N/m^2) that depends on the vertex penetration (m). However, I’m not 100% sure of it.
Also, would it be possible to use a AnyParamFun with an exponential term varying in term of the penetration depth instead of in term of time (t) ?
Thank you.
Pierre
Hi Pierre,
I have reviewed the formulas and i think you are correct in your description.
For the second question, please have a look at the sample file associated with the AnyForceSurfaceContact object in the manual, it displays how to use interpolation functions
Hi Soren,
Ok thank you. When I checked the examples, I did not see any example that used an exponential function that replaced the time by the penetration depth. I will check again.
Regards.
Pierre
