When one uses the AnyForceMomentMeasure2 class to calculate moments, the output values are M(0), M(1) and M(2). Do these correspond to moments in the x,y and z directions? It is not clear in the Anybody Modelling system. I am using the global reference frame.
Vic.
toerholm
(Søren Tørholm)
November 20, 2018, 9:49am
2
Hi Victor,
Short answer is yes.
The manual says: M OutputVar Equivalent point moment/torque vector in global coordinates.
If in doubt about such things, it can be a good idea to make a simple one segment model and ensure you understand the output from it.
See also https://github.com/AnyBody/support/wiki/All-about-Kinetics#measure-the-moment-created-by-the-muscles-around-a-joint-degree-of-freedom-in-a-certain-coordinate-system
Hi Soren,
Thank you, I have checked the manual as well. I was getting unusually high values and had some doubts.
Best Regards,
Victor
system
(system)
Closed
March 26, 2019, 6:00am
4
