AnyForceMomentMeasure2
I have a couple of questions regarding AnyForceMomentMeasure2. I’m trying to
calculate the hip moments in the GaitVaughn model. I’ve looked at post 2117 and
the code for finding the moment at the ankle. This is the code that Sebastian
gave:
AnyForceMomentMeasure2 AnkleJnt =
AnyRefNode &ref = Main.HumanModel.BodyModel.Right.Leg.Seg.Shank.AnkleJoint;
//pt of interest
AnySeg &ref1 = Main.HumanModel.BodyModel.Right.Leg.Seg.Shank;//all force
components acting on this segment will be considered
AnyForceBase &ref3 =
Main.HumanModel.BodyModel.Right.Leg.Jnt.Ankle.Constraints.Reaction;//force base
I know that this works for the ankle, but I can’t seem to get something similar
to work for the hip. I tried this code for the hip, but it results in a moment
that is really close to 0.
 AnyForceMomentMeasure2 HipJnt2 =
AnyRefNode &ref = Main.HumanModel.BodyModel.Right.Leg.Seg.Thigh.HipJoint;
//pt of interest
AnySeg &ref1 = Main.HumanModel.BodyModel.Right.Leg.Seg.Thigh;//all force
Main.HumanModel.BodyModel.Right.Leg.Jnt.Hip.Constraints.Reaction;//force base
I also tried including the pelvis segment and naming all of the muscles
individually instead of using the reaction force, and the result is better, but
the entire moment is positive, and I should be getting a flexor moment
mid-cycle.
Could anyone tell me where I am going wrong?
Abra
Hi Abra,
The mentioned code will actually give the moments created by the reaction
forces of the joint because no muscles are listed. I assume you want the
moment created by the muscles around the hip. So you have to list all the
leg muscles and also all the segments from the hip down to the foot : thigh,
shank and foot (it is actually a free body diagram where you have to list
all component on one side of the cut).
Hopefully the muscle list already exist (it is quite long) in
…\Body\AAUHuman\Leg\LegMuscleNames. Please notice that the psoas are not
listed yet and should be added for proper result. There is also a file
containing the definition of moment measures for the leg in
…\Body\AAUHuman\Leg\LegMoments that you can use.
The code looks like this:
AnyForceMomentMeasure2 HipNetMomentMuscle = {
AnyRefNode &ref = …HipNodeRef.RotNode;
AnySeg &seg1=…Seg.Shank;
AnySeg &seg2=…Seg.Foot;
AnySeg &seg3=…Seg.Thigh;
#include “…\Body\AAUHuman\Leg\LegMuscleNames.any”
Sylvain, AnyBody Support
Of ens.abra
Sent: 13. marts 2009 18:35
Subject: [AnyScript] AnyForceMomentMeasure2
and the code for finding the moment at the ankle. This is the code that
Sebastian gave:
//pt of interest
base
similar to work for the hip. I tried this code for the hip, but it results
in a moment that is really close to 0.
//pt of interest
base
but the entire moment is positive, and I should be getting a flexor moment
mid-cycle.
Abra
Hi Sylvain,
Thank you for clarifying the issue. I appreciate your help!
~Abra
— In anyscript@yahoogroups.com, AnyScript Support <anyscriptsup@…> wrote:
> Hi Abra,
> Best regards,
> _____
> Of ens.abra
> Hello,
> Sebastian gave:
> //pt of interest
> base
> //pt of interest
> base
> mid-cycle.
> Thanks,
> Abra
