Anygait
I find a foot app in youtube, I wonder if it can input the data from F-scan or X-scan or other pressure mat. Thank you!
https://www.youtube.com/watch?v=50I6YdTWhso
Dear Wenhao Li,
The file format is quite simple - if you cannot be used directly, then you could convert the output of those systems into the right one. It might be quite easy to do in Matlab/Python/C++ or whatever is easiest for you.
Please check the BareFootWalk-PressureData.txt in Applications\Beta\MoCap-GMFoot.
Here is also a useful link on MoCap_GMFoot model: wiki link
