Axes - "rotational transformation matrix"
Hi All,
I am still working on driving an humerus-radius-ulna-hand model by
Vicon markers, and I have run into a problem setting up the initial
conditions. How can I calculate the Axes value for each segment from
the data I have? Can someone explain to me in easy-to-understand
steps how to transform the matrix of the segment to be relative to the
global reference, or recommend a paper that will help me?
Any help would be appreciated!
Thanks in advance,
Sarah
Hi Sarah,
The new version 2.0 has a feature which was actually already
available in version 1.3 but was not documented. It is a function for
calculation of rotation matrices such as the Axis variable. Here’s an
example from a tutorial we are working on:
 AnySeg Arm = {
   r = {0.500000, 0.000000, 0.000000};
   Mass = 1.000000;
   Jii = {0.100000, 1.000000, 1.000000}*0.1;
   Axes = RotMat(20*pi/180,z);
   AnyDrawSeg drw = {};
The RotMat function rotates the position of the Arm segment 20
degrees about the z axis at load time. You can use the same function
for ARel specifications and other places where you may need a
rotation matrix.
AnyBody Support
— In anyscript@yahoogroups.com, “Sarah R. Sullivan” <sarsulli@e…>
wrote:
> Hi All,
from
the
> Thanks in advance,
> Sarah
