I'm just learning the program and I have a problem. I analyzed the tutorials but still do not understand the principle of the program. I have a problem moving the model and limiting the degrees of freedom.
Could I ask you to write a script that allows you to move the model as in the picture? Rotation of the leg in the hip by 40 degrees.
The Mannequin.any contains postural angles: starting joint angles in Posture folder, and angular velocities in PostureVel folder (below Posture). You can, for example, do this:
Posture = {
Right = {
HipFlexion = 0;
PostureVel = {
Right = {
HipFlexion = 40; // divide by tEnd in your study to ensure 40 as final angle
Is it possible to create a movement sequence? For example, returning the right leg to the starting position or delaying the movement so that it starts after a few seconds?
