Hi ?
The gait model is driven by maker trajectories, so each marker have
a vector of time values and with corresponding recorded positions.
This setup means that the motion are parameterized in terms of
marker positions, so there are no easy way to make the gait faster.
The only way to do so would be to change the timevector of all the
markers and force plate data.
About the ground reaction forces:
You can run a model with or without measured reaction forces to the
enviroment around it. If you have measured forces these are applied
like for example in the Gait3D model. If the forces have not been
measured you need to apply the correct kind of boundary conditions
to the environment. A good example of this is the
PedalDemoConditonal here the model push a pedal with a predefined
load on and the reaction force between the foot and the pedal is
automatically determined.
We do not at the moment have a model walking on stairs but in
principle it can be made in the same way as the Gait3D model. You
will need marker data from a stair experiment to drive it.
Bergman has published the Hip98 CD you can download it from this
link
http://www.charite.de/bml/main.php?
action=literature&lc=30&li=t&ta=350#art350
I think there are some data there for walking on stairs, but i am
not sure.
Before attempting to make your own model i would recomend that you
carefully browse through the Gait3D model. Especially the
JointAndDrivers.any file, here it is essential to understand the
concept of the AnyKinLinear measures which can measure either in
global coordiantes of local coordinates by chaniging the Ref
property.
On www.anybodytech.com you will also be able to find a webcast on
the gait model which might be usefull.
Please ask again if you have further questions.
Søren AnyBody Support
— In anyscript@yahoogroups.com, “knox40” <knox40@…> wrote:
> Hallo,
> I’m a new user of the Anybody software. I’ve done already several
> tutorials to become familiar with the Anyscript language.
> But in my opinion it is a big step now, to do more complex models.
> First I wanted to get the joint reaction force and some muscle
> forces in the lower extremity during several activities:
> - gait, stairways etc.
> The gait model is already available, so I can change now the
walking
> speed under JointsandDrivers.any?
> Do I have to provide every full body model with ground reaction
> forces or only the version of the lower extremities?
> How can I simulate in the easiest way stairway walking? By
changing
> the gait model or do I have to build an own model bottom up?
> Where can I get driver informations for several activities (as
going
> stairways etc.)? (Bergmann etc?)
> I hope you can give me further advice as I’m only a beginner in
body
> modeling.
> Best regards
