Bike Model 3D
Hi every one in anybody group,
I’m new to this group and i am facing some confusion in understanding
the Bike Mode. Actually i have successfully run it but i needed to
understand more about the parameters used in this model the Mass
Inertia of the bone, Muscles, Length of it and the calculation of
joint forces and the joint tork against the trank???
Driving tork.
Thanks
Nina
Hi Nina
I think it will be a good idea to run some of the tutorials, you can
find them in the menu of AnyBody under “Help ->Contents”.
The “Getting started with AnyScript” will answer some of your
questions about mass, inertia etc.
The driving torque is defined in the file “BikeFramesAndWheel.any”,
the object named “CrankMoment” defines the variation of the
crankmoment as a function of the pedalangle.
Please ask again if you have further questions.
— In anyscript@yahoogroups.com, “nina_rama2002”
understanding
> Driving tork.
> Thanks
> Nina
Thank you for replying. but i found some of the terms in the script are not
clear such as RPM? in the bike model so can you guide a bit further please on
where i should find the abbreviations meanings. I have looked through the
“Getting started” but i could not find any thing to answer my question about the
mass inertia.
Thank you In Advance and appreciating your cooperation.
Nina
From: anyscript@yahoogroups.com on behalf of AnyBody Support
Sent: Mon 10/30/2006 11:46 AM
Subject: [anyscript] Re: Bike Model 3D
Hi Nina
— In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> ,
“nina_rama2002”
understanding
> Driving tork.
> Thanks
> Nina
Hi Nina
If you look in the Tutorial “Getting started with AnyScript”
(Not “Getting started”) Lesson 2 there is a description on how the
masses and inertia is defined. You can also look at the
tutorial “The Mechanical Elements” Lesson 1.
There is also a tutorial which is based on a 2d bike model, so you
might be able to find some of the abbrevations there this is in
the “Parameter studies and Optimization” Lesson 1.
RPM means rounds per min.
— In anyscript@yahoogroups.com, “Nesreen Aboulkhair”
script are not clear such as RPM? in the bike model so can you guide
a bit further please on where i should find the abbreviations
meanings. I have looked through the “Getting started” but i could
not find any thing to answer my question about the mass inertia.
> Nina
> ________________________________
> Hi Nina
can
> Best regards
40yahoogroups.com> , “nina_rama2002”
> understanding
to
of
> > Driving tork.
> > Thanks
> > Nina
