Thanks Moonki
Possibely i am not looking in the correct location for the PosInterpol code.
Sincerly thanks
Damon
Thanks Moonki
Sincerly thanks
Damon
Hi Moonki
The box is now moving with the hands,
thanks very much for your help to accomplish this.
Hi Moonki
The box is now moving with the hands :), thanks very much for your help to accomplish this. Here it is in youtube http://youtu.be/3LraFdNhG2Y
Now I’m trying to do the kinetic connection between the box to hands using AnyReacForce.
Q1 - Is there any lessons that are specific to AnyReacForce being used to connect hands to an object, or other helpful lessons?
Q2 - The initial location of the hand placement is always on the sides, but with each new trail the hands are not always in the same exact spot. So will AnyReacForce allow this flexibility in the location of hands on box?
Q3 - Would I only need AnyReacForce code as shown below, or do I need additional code for things like, nodes,
[SIZE=3]AnyReacForce <ObjectName> =
//Type = ;
//AnyKinMeasure &<Insert name0> = <Insert object reference (or full object definition)>; You can make any number of these objects!
[/SIZE]
Q4 - I tried running the Inverse Dynamic Model. I see the bones and muscles, but not the box. Do I need to add the box code into the muscle section of the main file?
Sincerely thanks
Damon
Hi Damon,
Thanks for the nice video on YouTube.
A1) There is no specific lessons for AnyReacForce.
A2) You don’t need to care the orientation of the hand.
A3) You can just define AnyReacForce objects like this:
AnyReacForce LeftHandForceToBox =
AnyKinLinear lin =
AnyRefFrame& ref1 = ... (somewhere).Hand;
AnyRefFrame& ref2 = ... (somewhere).Box;
AnyKinRotational rot =
Type = RotAxesAngles;
A4) You should include the reference of the box in your Model folder.
One more suggestion.
When I looked your video, the markers do not look fit very well. I recommend you to run the MotionAndParamterOptimization process again well.
Hi Moonki
How do I reference the box in the Model Folder?
The markers are closer in this last run of MotionAndParamterOptimization, http://youtu.be/17DrYW4WmtY
Sincerely thanks
Damon
Hi Damon,
You can just make the references of your box, marker drivers for the box in your model folder. Please read the following tutorial chapter about how to maker references:
http://www.anybodytech.com/fileadmin/AnyBody/Docs/Tutorials/chap7_Advanced_script_features/lesson1.html
If you want to know whether the weight of the box would be transferred to human, you can just try to run the inverse dynamics and try to see the shoulder joint reaction forces.
Hi Moonki
I was able to load successfully the box in InverseDynamicModel by replicating the same code in MotionAndParameterOPtimization, and with inserting the new object name for MyBox. I figure I can use referencing later on to improve the code, once I know the model is working.
For now I’m getting this error described below when trying to run the model. Can you please help with what I should do about this error?
[SIZE=1]ERROR(OBJ.MCH.KIN2)[/SIZE] : [SIZE=1]C:/U…s/d…l/D…s/+…l/1…l/1…y/1_DamonBoxLiftngModel.main.any[/SIZE] : [SIZE=1]InverseDynamicStudy[/SIZE] : Model is kinematically over-constrained : Position analysis failed : 6 unsolvable constraint(s) found
Sincerely Thanks
Damon
Hi Damon,
You can try to change the type of your constraints(markers) as soft constraints.
That might help.
Hi Moonki
Here is a video showing the unresolved constraints error, http://youtu.be/SeJBPgcBCbI , I was able to correct the unresolved constraint(s) error by adding this code:
AnyKinEqType ANY_CTYPE = Soft;
InitialConditions.SolverType = KinSolOverDeterminate;
Kinematics.SolverType = KinSolOverDeterminate;
I found this method at: http://www.anybodytech.com/fileadmin/AnyBody/Docs/Tutorials/chapX_SolidWork2AnyBody/lesson2.html
[COLOR=magenta][COLOR=black]Then somehow this new error showed up about, Time, ‘t’. [/COLOR][/COLOR]
[SIZE=1]ERROR(OBJ1)[/SIZE] : [SIZE=1]C:/U…s/d…l/D…s/+…l/1…l/1…y/JointsAndDriversOptimized.any[/SIZE] : [SIZE=1]JntDriverTrunk[/SIZE] : Time, ‘t’, has an invalid value for this interpolation
[COLOR=black]Which I solved by changing the number 2 to a number [COLOR=black]6 in this below code. I think this just means it starting and stopping the motion 6 steps earlier. Now its loading and running in InverseDynamics, but it is taking a very long time to complete dynamic processing of the muscles. So, I’m going to try the same C3D file without the box and see if there is a difference.[/COLOR][/COLOR]
tStart=Main.TrialSpecificData.tStart+6Kinematics.ApproxVelAccPerturb;
tEnd=Main.TrialSpecificData.tEnd-6Kinematics.ApproxVelAccPerturb;
I found the relation to Time, ‘t’ at:
http://www.anybodytech.com/fileadmin/AnyBody/Docs/Tutorials/Making_things_move/lesson2.html
Q1 - For the mass moment of inertia, I’ve seen in the lessons the values for Jii = { ?, ?, ?}; are small, 1, 0.01, 0.0001, etc. I tried doing calculations using the link you provided, but my numbers are much larger, and I get a giant object on the screen. So I’m wondering if in the AB lessons if the three Jii numbers are being divided by the larger number. Example: jii = {500, 500, 250}; would be jii = {500, 500, 250}/5000; which would be jii = {0.1,0.1,0.05}; Could you please help with how calculations are done for AB a rectangular solid box?
Q2 - I had these below notices, is there something I can do to improve the code to address these notices?
Evaluating constants…
[SIZE=1]NOTICE(OBJ1)[/SIZE] : [SIZE=1]C:/U…s/d…l/D…s/+…l/1…l/1…y/EnvironmentAutoDetection.any[/SIZE] : [SIZE=1]ForcePlateType2_Origin_Z_value_message[/SIZE] : The older AMTI origin has its Z value as positive. So this value is converted automatically. Please refer to www.c3d.org/HTML/type21.htm.
Configuring model…
Sincerely thanks
Damon
HI Moonki, have you seen my latest post, and are just trying to deterime the solution?
Do you think it would help if you were to look at what I have done so far with the model, so you can have a better picture of what I have in the model and to provide recommendations to fix the errors?
Sincerly thanks
Damon
HI Damon,
Now your questions became too complex for us to figure out at a glance.
I think you have to upload a zip file which contains your model.
Of course that model should work on our normal AMMR.
Please let us know the corresponding AMMR version related to your model.
Hi Moonki
Here is all the files needed to work in AMMRV 1.5.1. There are 2 additional AB files that have some differences that need switched in 1.5.1. Also included is the CAD file for the box.
So attached is:
-Main
-EnviromentAutoDetection
-ModelSetup
-UnitBox
Thank you for looking at this.
Also still need to check if the box forces are translating to the arms.
Sincerely thanks
Damon
Hi Moonki
… Here is all the correct files needed to work in AMMRV 1.5.1.
So attached is:
-Main
-ModelSetup
-UnitBox
Sincerely thanks
Damon
Hi Damon,
We can’t manage individual modified versions of AMMR for individual questioners.
I would suggest you to use a kind of cloud service such as DropBox or GoogleDrive.
Then you can make a zip file which contains both your model and the modified AMMR.
If you can write the link for that shared model then we will try to download it.
Hi Moonki
[SIZE=3][SIZE=2][COLOR=#000000]Were you able to access the model in google drive ok?[/SIZE][/COLOR][/SIZE]
[SIZE=2]https://drive.google.com/folderview?id=0ByKJo85n4mZOel9FMnd4d2YxTG8&usp=sharing
[/SIZE]
Sincerely
Damon
Hi Moonki
There are some other things id like to do to improve the model, that has to do with EMG. Should I start a new string for that or wait until you get done reviewing the model?
Sincerely thanks
Damon
Hi Damon,
I would recommend you to start a new post with your new model.
And your google drive link requires me to log in using my account.
Maybe providing a kind of public link which Dropbox may support would be better.
Hi Moonki
Thanks again for all your guidance to get the model to work, and teaching me about AB in the process.
Here is the link to dropbox. Hope this works better?https://www.dropbox.com/sh/swvv2ys9xdk8sdo/IetRVyBXsm
And, here is the link to the new thread for the University of Miami box lifting model, http://forum.anyscript.org/showthread.php?p=17826#post17826
Sincerely thanks
Damon
Hi Moonki
Here is the link to the new thread for the UM box lifting model, http://forum.anyscript.org/showthread.php?p=17826#post17826
Should I move the previous questions to the new thread, or will we complete these questions here in this thread?
Sincerely thanks
Damon
Hi Moonki
Q-1) Is the moment of inertia for Jii in these units kg/m2 ?
Sincerely thanks
Damon
