Hi Damon,
Could you please make a zip file which contains all of your files instead of several files and upload it on your Dropbox again?
Hi Damon,
Hi Moonki
I removed the files, and uploaded a zip file with the latest model.
Sincerely thanks
Damon
Hi Damon,
Please write a new post with your new model Dropbox link.
I can’t find it.
This should be the link to the folder.
https://www.dropbox.com/s/7vcefbyfp1bz9nw/AMMR.v1.5.1_1_1_UniversityOfMiamiBoxLiftingModel_SentToABMoonki_DropBox_2.zip
See this trail where the markers are not aligning.
https://www.dropbox.com/s/e3oisoo060migpg/AMMR.v1.5.1_1_1_UniversityOfMiamiBoxLiftingModel_SentToABMoonki_DropBox_3.zip
Sincerely
Damon
Hi Damon,
Finally I could make your model working!
Please check here:
http://goo.gl/KODjIC
Hi Moonki
Thanks for looking at the model.
It does take a long time to run. Possibly it is the way the markers are weighted in the ModelSetup.
The box looks better in the InverseDynamic model, I think this is due to removing AnyRefNode, and AnyDrawSeg.
Sincerely
Damon
Hi Damon,
Regarding the running time, it is not related to the markers.
It is just because you are running the inverse dynamics with the full muscle model. So I hope that you can just have enough time to run this model on your machine.
Basically in the MotionAndParameterOptimization process, you don’t need to consider the kinematics of the box.
The code for box is only meaningful(necessary) when you run the InverseDynamics analysis.
Basically your models was not too bad.
I only tried to change the locations of the box.
Good Luck. Now you are very close to the final.
Thank you for the encouragement.
Sincerely thanks
Damon
