Hi everyone,
In the AAUHuman/LegTLEM/Seg.any there's a DesignVar named VarusValgusRotation that, from what I understood, introduces a fixed rotation of the knee joint axis, determined by the two epicondyles, in the frontal plane (around the x axis). Is that correct?
There's a comment saying that the name of this variable is deprecated. Is there any reason why it shouldn't be used?
When such alignment measurements are available, from a static pose analysis such EOS or even from a clinical evaluation, they are probably more representative of the whole stance phase leg alignment rather than the default "0°" alignment.
Similarly, a TibialTorsionOffset is defined for the ankle but this one is not marked as deprecated.
If you think that these rotational offsets can still be used for such applications, it might make sense to add a note in the AMMR Documentation of the leg parameters?
And on a more technical note, how can I modify its value directly in AnyScript when using the default root version of the AMMR? I am running a bunch of AnyMoCap models from the console, and rather than setting its value through class operations (right click --> set value in the GUI, or through the class operations in AnyPyTools), I'd prefer to assign the value directly in the SubjectSpecificData.any file for each subject, as it would be a bit more handy for my pipeline.
Thanks!
Enrico
