Thanks to you
I can next step thanks for your adjustment
//Another problem occurred
//(my test file frame have 200 frame but AMS output is 10~20 frame ,
//I performed 2step gait but AMS data have first one step(half))
//solved this problem
In addition I would like to know the difference between the sent filefolder(GaitLowerExtremity_KKU) and original filefolder(GaitLowerExtremity)
and you pointed out, forceplate is reverse mean? or other problem?
The main differences are ‘ModelSetup.any’ and ‘ExtraDrivers.any’ files.
Because you didn’t use enough markers in the upper body, you should modify ‘ModelSetup.any’ file. You can check it in the first capture file.
And also because there is not enough information in your C3D about how to drive the upper body, so in the ‘ExtraDrivers.any’ file you should use some drivers for Pelvis-Thorax rotations.
If you can see the second capture file, you can see that the local coordinate system of your force plate is flipped.
If you can see the following information about C3D file for force plate, then the local Z axis of the force plate coordinate system should go into the ground. http://www.c3d.org/HTML/default.htm?turl=corners.htm
But in your C3D file, the direction of Z axis is wrong.
You should ask to your lab technical support about how you can generate the correct C3D file, maybe Motion Analysis Corp…
If you want to use AnyBody with your laboratory environment, you should correct this problem as soon as possible.
When I looked your C3D file very quickly, there are two problems.
The RTHI marker in your C3D file is almost dropped-out.
This may the reason of the kinematic error.
Both left and right feet are on the same single force plate.
Of course this second issue is not related to the kinematics.
But if you want to perform the inverse dynamics, then I would recommend you to use one more force plate.
If you still can’t figure out how to solve your problem, then please upload your full AnyBody model here as a zip compressed file.
I’m the beginner in the use of AnyBody. It would be great if you could help me. I have some problems with C3D file too. Please, find enclosed file. I would like to use this data for GaitFullBody model. When I load it I get this error message:
ERROR(SCR.PRS9) : D:/U…s/L…a/r…y/A…x/A…o/A…n/E…s/G…y/ModelSetup.any : Defined At : D:/U…s/L…a/r…y/A…x/A…o/Body/A…n/T…x/M…p/CreateMarkerClassTD.any : ‘PosInterpol’ : Unresolved object
I tried to compare the marker names in AnyBody and used in C3D files. Two of them weren’t the same. Thus I changed the names in ModelSetup.any. Nevertheless it didn’t help…
