Hi, I’ve recently been given a c3d file from some VICON + force plate
gait analysis. I’ve then used the recently updated c3d2any converter
to convert to anyscript. But each time I try to run c3d2any in Command
Prompt it comes up with . .
Error: Failed to copy the marker mover file
Aborting.
Can I send the c3d file to you, to help determine the problem?
I think I know why this is the case. If you choose your output directory to be
the one where you installed the converter, the marker mover file will already
be in the directory, and the converter will skip copying it because it is
already there. In this case, if you choose a different output directory,
everything should be fine.
However, this is the very last thing that happens in the conversion, so you
should be able to open the generated Main.any file and run it.
If this is not the case, I would like some more details about how you called the
converter etc. because then you might have located a bug.
Michael Skipper Andersen
The AnyBody Research Project.
----- Original Message -----
Sent: Wednesday, December 05, 2007 4:44 PM
Subject: [AnyScript] c3d file
Aborting.
Many thanks
Peter
