I am trying to use the C3Dproject.main file for analyzing a C3D file with lower extremity markers and markers on the LSHO, RSHO, and C7. I know that a driver for the neck must be included since I don’t have markers on the head. Can you tell me how to create this driver and where it should be placed within the set of files?
I had a quick look at your post, and have some suggestions. The C3D project is divided into project steps. The drivers are located:
in the JointsAndDrivers for the Initial Position and Anthropometry Model
in the JointsAndDriversLocal for the Motion and Param Opt Model
in the JointsAndDriversOptimized for the InverseDynamics Model
to set up a driver, you can have a look here:
//This is an etsimation of the upper body motion it will enforce that the head is kept above the pelvis medial/laterally
AnyKinEqSimpleDriver LateralBendDriver ={
AnyKinLinear lin ={
AnySeg &ref1= …HumanModel.Trunk.SegmentsLumbar.PelvisSeg;
AnySeg &ref2= …HumanModel.Trunk.SegmentsThorax.SkullSeg;
DriverPos={0};
DriverVel={0};
MeasureOrganizer={1};
