Hello Jerome,
First, let me welcome you to the group.
To enable/see joint moments:
I had a fairly detailed discussion of this matter on the group. You can look
at this post:
HYPERLINK
"http://tech.groups.yahoo.com/group/anyscript/message/1202"http://tech.group
In short:
Make sure you use the NoMuscles.any model of the lower limb.
In the LegNoMuscles.root.any files (included in the
BodyModel_NoMuscles.any file), make sure you include JointMuscles.any and
not JointReactions.any.
To view these moments:
Once you’ve done that, you can run an InverseDynamicAnalysis and use the
AnyChart 2D/3D to navigate to those JointMuscles. Depending on your model,
they should be somewhere like
Main.Study.Output.Model.HumanModel.(Left/Right).Leg.JointMuscles.(HipJnt/Kne
eJnt/AnkleJnt).(dofX).(PosMuscle/NegMuscle)
There are two muscles (one negative, one positive), because muscles can only
pull. These muscles are using the AnyMuscleModel class, so they are constant
strength, with no passive components. Therefore, they give you what you are
looking for.
Hope this answers all of your questions.
If you need more detailed explanations, or you have more questions, don’t
hesitate,
Jean-Olivier Racine
HYPERLINK "mailto:joracine@humancad.com"joracine@humancad.com
HumanCAD development team
Nexgen Ergonomics Inc.
HYPERLINK "http://www.nexgenergo.com/"http://www.nexgenergo.com/
Of Jerome
Sent: Monday, April 21, 2008 11:45 PM
Subject: [AnyScript] Calculate moments
Hi there,
I’m new to forum and to Anybody. I’m seeking some help in figuring
out how calculate and plot the joint moments of the ankle, knee, and
hip. Currently, I have a lower body model on which I’ve run the
kinematic analysis and inverse dynamic analysis. The model is driven
by marker motion data extracted from the c3d motion file.
I’ve read on the message board some mention of turning ‘on’ the
reaction.type function in the driver folder and of the use of the
AnyForceMomentMeasure function. Most of what I’ve seen on the message
board has either not been detailed enough for me to go and try to
implement myself or obsolete due to the explanation being for much
older versions of Anybody.
Is there a tutorial somewhere that explains how the get the
calculated joint moments from the program, starting with what code to
add where though to being able to see the torques plotted on the
ChartFX? If not, could you please give me some direction. Your help
will be greatly appreciated.
Also, I’d like to know how to view the joint angle data of the ankle,
knee, and hip through time after running the InverseDynamicAnalysis.
Thanks again.
Jerome
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.524 / Virus Database: 269.23.3/1391 - Release Date: 4/22/2008
8:15 AM
No virus found in this outgoing message.
Checked by AVG.
8:15 AM
