Hallo,
i simulated a static task with an armmodel, so that only three muscles
were taken into account. The task was to hold the almost 90degree
flexed lower arm against gravity. For better understandig which muscle
forces i estimate, i calculated the same task by hand with the law of
the lever. Although this method is very imprecise i could see, that
there a more muscle forces than needed to do this special task. How
could i understand this? Are there some internal tasks which increase
muscle force, tendon tension or joint friction for example?
Thank you very much, best regards, Maren.
Hi Maren
Could I ask you to upload your model to the file section?
Christian, AnyBody Support
> Hallo,
Hi Christian, i uploaded my model in the folder “Marens Armmodell”.
Good Luck
> Hi Maren
> Best regards
> — In anyscript@yahoogroups.com, “Maren” <anystarter@> wrote:
> > Hallo,
Hi Maren
Thank you, I am looking at it.
> Good Luck
> — In anyscript@yahoogroups.com, “AnyBody Support” <support@> wrote:
> > Hi Maren
> > Best regards
> > > Hallo,
muscles
muscle
law of
increase
Hi Maren
Have you made any changes to
BRep\Aalborg\BodyModels\SpineTwoArms\BodyModel_Mus3E.any?
If yes could you upload the file?
> Hi Maren
> Best regards
> > Good Luck
> > > Hi Maren
> > > Best regards
> > > > Hallo,
> muscles
> muscle
> law of
that
task. How
> increase
Hi Christian,
at this moment i am not sure wether i changed something in this file,
but i uploaded it in the folder “Marens Armmodell”. The origin model
from the repository was the gearstick model and i changed it to make a
static task: hold the lower arm against gravity with nearly maximum
supination so that as few as possible muscles were used. Best regards,
Maren
> Hi Maren
> Best regards
> > Hi Maren
> > Best regards
> > > Good Luck
wrote:
> > > > Hi Maren
> > > > Best regards
> > > > > Hallo,
> > muscles
90degree
> > muscle
> > law of
> that
> task. How
> > increase
Hi Maren
Thanks for the last file, it made it work:D
I am not sure why you see bigger muscle activity in the AnyBody model
then in the other one. Are you considering the passive elastic forces
from the elbow stretching muscles? This could be one of the reasons to
the difference. Maybe you could try using the AnySimpleMuscle model,
because they have no passive elastic properties.
Let me know what you think, I think it is an exciting discussion.
> Hi Christian,
> Maren
> > Hi Maren
> > Best regards
> > > Hi Maren
> > > Best regards
Armmodell”.
> > > > Good Luck
> wrote:
> > > > > Hi Maren
> > > > > Best regards
> > > > > > Hallo,
> > > muscles
> 90degree
which
> > > muscle
> > > law of
> > that
> > task. How
> > > increase
Hi Christian,
that is an interesting idea. I haven´t looked at the passive forces of
the antagonists yet. Thank you very much, i will try it out. Is it
possible for you to send me the formula how AnyBody calculates the
muscle forces? Best regards, Maren
> Hi Maren
> Best regards
> > Hi Christian,
> > Maren
> > > Hi Maren
> > > Best regards
wrote:
> > > > Hi Maren
> > > > Best regards
> Armmodell”.
> > > > > Good Luck
> > wrote:
> > > > > > Hi Maren
> > > > > > Best regards
> > > > > > > Hallo,
three
> > > > muscles
> > 90degree
> which
> > > > muscle
with the
> > > > law of
could see,
> > > that
> > > task. How
> > > > increase
I am also very interested in this too. I as well, have created an AnyBody
simple arm-curl model to compare to long-hand calculated muscle forces. When I
start adding too many muscles to the model (calculating long-hand), I run into
the problem of indeterminancy. However, if I set for example, the biceps breve
as a function of the biceps longum, and all of the triceps (ME_1 and 2, LA_1 and
2) as a function of each other based on PCSA, I can get the same results as
AnyBody. There are two things I am still curious about however.
1.) First off, the Triceps_LH 1 & 2 always demonstrate a Fm of 0. The same
goes for both the Brachialis_1 & 2, and Brachioradialis_1 & 2. Why is it that
these muscles exert no force on the system while the biceps breve and longum
clearly do. I’m assuming it comes down to the mathematics within the software
(and I am interested, like Maren, to find out more on this) and the fact that to
minimize the maximal muscle effort, computationally it makes sense to avoid
these muscles because when calculated, their input is greater than with the
biceps alone. However does this make sense physiologically? I’m just trying to
reason this out…
2.) And along these lines, does the software perhaps group flexors and
extensors somehow based on PCSA like I did for the biceps and triceps?
Thank you for your time and help on this,
Sarah
-----Original Message-----
> Date: Fri Feb 09 03:01:04 EST 2007
> From: “Maren” <anystarter@yahoo.de>
> Subject: [anyscript] Re: Calculation of muscle forces
> Hi Christian,
> that is an interesting idea. I haven?t looked at the passive forces of
> > Hi Maren
> > Best regards
> > > Hi Christian,
> > > Maren
> > > > Hi Maren
> > > > Best regards
> wrote:
> > > > > Hi Maren
> > > > > Best regards
> > Armmodell”.
> > > > > > Good Luck
> > > wrote:
> > > > > > > Hi Maren
> > > > > > > Best regards
> > > > > > > > Hallo,
> three
> > > > > muscles
> > > 90degree
> > which
> > > > > muscle
> with the
> > > > > law of
> could see,
> > > > that
> > > > task. How
> > > > > increase
Hi Maren
I don’t know if you took a look at the tutorial on muscle modeling?
You can find it here: http://www.anybodytech.com/507.0.html
A formulation of the strength and what parameters that are considered
in the three element muscle model. Is this enough info or do you need
anything more? let me know.
> Hi Christian,
> that is an interesting idea. I haven�t looked at the passive forces of
> > Hi Maren
> > Best regards
> > > Hi Christian,
file,
make a
regards,
> > > Maren
wrote:
> > > > Hi Maren
> > > > Best regards
> wrote:
> > > > > Hi Maren
> > > > > Best regards
> > Armmodell”.
> > > > > > Good Luck
> > > wrote:
> > > > > > > Hi Maren
> > > > > > > Best regards
wrote:
> > > > > > > > Hallo,
> three
> > > > > muscles
> > > 90degree
> > which
> > > > > muscle
> with the
> > > > > law of
> could see,
> > > > that
> > > > task. How
which
> > > > > increase
example?
Hi Sarah
I will try to give you some answers:
First of all, here are some references to papers which describes the
recruitment of the muscles, as you know the forces are distributed
among the muscles using a min/max optimization criteria.
Michael Damsgaard, John Rasmussen, Søren Tørholm Christensen,
Egidijus Surma, and Mark de Zee (2006): Analysis of musculoskeletal
systems in the AnyBody Modeling System. Simulation Modelling Practice
and Theory. Volume 14, Issue 8 , November 2006, Pages 1100-1111.
Elsevier, ISSN: 1569-190X.
M. Damsgaard, J. Rasmussen & S.T. Christensen (2001): Inverse
dynamics of musculo-skeletal systems using an efficient min/max
muscle recruitment model. Proceedings of IDETC: 18-th Biennial
Conference on Mechanical Vibration and Noise, Pittsburgh, September 9-
13, 2001.
The algorithm do not group the muscles in any way, all muscels are
treated in the same way. The algorithm will try to lower the
activity in the maximal activated muscles of the model (provided you
do not make use of any penalties, then the explanation is longer).
I can not give a simple answer on why tricpes_longhead 1 & 2 are not
active in the given situation, the same goes for the other two
muscles you mention. The activity of Brachioradialis could be related
to the pronation of the forarm have you tried to change this?.
It is certain though, that if these muscles became active it would
increase the activity of some of the other muscles in the model. So
one thing you could do, was to add a constant force to one of the
muscles you are interested in, in order to see the effect it would
have on the other muscles, if the particular muscles became active.
In practice this can be done be creating an AnyForce and then refer
to the Line measure in the particular muscle. If you then add a force
(negative) and closely inspect which muscles then become more active
you can get an idea about which mechanisms are dominat in the model.
I hope this answers your questions otherwise please write again.
AnyBody simple arm-curl model to compare to long-hand calculated
muscle forces. When I start adding too many muscles to the model
(calculating long-hand), I run into the problem of indeterminancy.
However, if I set for example, the biceps breve as a function of the
biceps longum, and all of the triceps (ME_1 and 2, LA_1 and 2) as a
The same goes for both the Brachialis_1 & 2, and Brachioradialis_1 &
2. Why is it that these muscles exert no force on the system while
the biceps breve and longum clearly do. I’m assuming it comes down
to the mathematics within the software (and I am interested, like
Maren, to find out more on this) and the fact that to minimize the
maximal muscle effort, computationally it makes sense to avoid these
just trying to reason this out…
and extensors somehow based on PCSA like I did for the biceps and
triceps?
> Sarah
> > From: “Maren” <anystarter@…>
> > Hi Christian,
forces of
wrote:
> > > Hi Maren
model
forces
reasons to
model,
discussion.
> > > Best regards
> > > > Hi Christian,
this file,
origin model
to make a
maximum
regards,
> > > > Maren
<support@> wrote:
> > > > > Hi Maren
> > > > > Best regards
<support@>
> > wrote:
> > > > > > Hi Maren
> > > > > > Best regards
> > > Armmodell”.
> > > > > > > Good Luck
<support@>
> > > > wrote:
> > > > > > > > Hi Maren
section?
> > > > > > > > Best regards
> > > > > > > > > Hallo,
only
> > three
> > > > > > muscles
almost
> > > > 90degree
understandig
> > > which
> > > > > > muscle
hand
> > with the
> > > > > > law of
> > could see,
> > > > > that
special
> > > > > task. How
tasks which
> > > > > > increase
example?
Hi Soren,
The recent November 2006 article is VERY helpful - thank you for the information
on it. Is there anyway I can get a .pdf for the 2nd article - the 2001
Proceedings of IDETC article? I can’t find it anywhere and to get it I will
have to buy the entire proceedings (just for the article). Is it posted on the
AnyBody website as a publication? The proceedings here are about $150 US.
Thank you,
Sarah
> Date: Mon Feb 12 05:31:53 EST 2007
> From: “AnyBody Support” <support@anybodytech.com>
> Hi Sarah
> Michael Damsgaard, John Rasmussen, S?ren T?rholm Christensen,
> 13, 2001.
> Best regards
> S?ren
> triceps?
> > Sarah
> > > Hi Christian,
> forces of
> wrote:
> > > > Hi Maren
> model
> forces
> reasons to
> model,
> discussion.
> > > > Best regards
> > > > > Hi Christian,
> this file,
> origin model
> to make a
> maximum
> regards,
> > > > > Maren
> <support@> wrote:
> > > > > > Hi Maren
> > > > > > Best regards
> <support@>
> > > wrote:
> > > > > > > Hi Maren
> > > > > > > Best regards
> > > > Armmodell”.
> > > > > > > > Good Luck
> <support@>
> > > > > wrote:
> > > > > > > > > Hi Maren
> section?
> > > > > > > > > Best regards
> > > > > > > > > > Hallo,
> only
> > > three
> > > > > > > muscles
> almost
> > > > > 90degree
> understandig
> > > > which
> > > > > > > muscle
> hand
> > > with the
> > > > > > > law of
> > > could see,
> > > > > > that
> special
> > > > > > task. How
> tasks which
> > > > > > > increase
> example?
Hi Sarah
If you have got the first paper i think you are ok, and will not find
much more information in the second paper. I primarily gave two
options so you had a choice.
Unfortunately it is not possible to get the .pdf file for the second
paper due to copyright issues, this is also why it is not online,
sorry.
wrote:
> Hi Soren,
the information on it. Is there anyway I can get a .pdf for the 2nd
article - the 2001 Proceedings of IDETC article? I can’t find it
anywhere and to get it I will have to buy the entire proceedings
(just for the article). Is it posted on the AnyBody website as a
> Thank you,
> Sarah
> > From: “AnyBody Support” <support@…>
> > Hi Sarah
the
distributed
musculoskeletal
Practice
September 9-
> > 13, 2001.
are
you
not
related
would
So
would
active.
refer
force
active
model.
> > Best regards
> > S?ren
> > — In anyscript@yahoogroups.com, “Sarah R. Sullivan” <sarsulli@>
an
indeterminancy.
the
a
as
0.
Brachioradialis_1 &
while
down
the
these
the
flexors
> > triceps?
> > > Sarah
> > > > From: “Maren” <anystarter@>
> > > > Hi Christian,
> > forces of
Is it
calculates the
<support@>
> > wrote:
> > > > > Hi Maren
AnyBody
> > model
elastic
> > forces
> > reasons to
AnySimpleMuscle
> > model,
> > discussion.
> > > > > Best regards
wrote:
> > > > > > Hi Christian,
in
> > this file,
> > origin model
it
> > to make a
nearly
> > maximum
Best
> > regards,
> > > > > > Maren
> > <support@> wrote:
> > > > > > > Hi Maren
> > > > > > > Best regards
> > <support@>
> > > > wrote:
> > > > > > > > Hi Maren
> > > > > > > > Best regards
<anystarter@>
folder “Marens
> > > > > Armmodell”.
> > > > > > > > > Good Luck
> > <support@>
> > > > > > wrote:
> > > > > > > > > > Hi Maren
> > section?
> > > > > > > > > > Best regards
> > > > > > > > > > > Hallo,
that
> > only
> > > > three
> > > > > > > > muscles
the
> > almost
> > > > > > 90degree
> > understandig
> > > > > which
> > > > > > > > muscle
by
> > hand
> > > > with the
> > > > > > > > law of
imprecise i
> > > > could see,
> > > > > > > that
this
> > special
> > > > > > > task. How
internal
> > tasks which
> > > > > > > > increase
for
> > example?
Not a problem, thank you for getting back to me. I may have more questions once
I get through the paper - sifting through the math is taking a while but it is
very helpful!
> Date: Tue Feb 13 03:35:59 EST 2007
> Hi Sarah
> sorry.
> Best regards
> S?ren
> wrote:
> > Hi Soren,
> > Thank you,
> > Sarah
> > > Hi Sarah
> the
> distributed
> musculoskeletal
> Practice
> September 9-
> > > 13, 2001.
> are
> you
> not
> related
> would
> So
> would
> active.
> refer
> force
> active
> model.
> > > Best regards
> > > S?ren
> an
> indeterminancy.
> the
> a
> as
> 0.
> Brachioradialis_1 &
> while
> down
> the
> these
> the
> flexors
> > > triceps?
> > > > Sarah
> > > > > Hi Christian,
> > > forces of
> Is it
> calculates the
> <support@>
> > > wrote:
> > > > > > Hi Maren
> AnyBody
> > > model
> elastic
> > > forces
> > > reasons to
> AnySimpleMuscle
> > > model,
> > > discussion.
> > > > > > Best regards
> wrote:
> > > > > > > Hi Christian,
> in
> > > this file,
> > > origin model
> it
> > > to make a
> nearly
> > > maximum
> Best
> > > regards,
> > > > > > > Maren
> > > <support@> wrote:
> > > > > > > > Hi Maren
> > > > > > > > Best regards
> > > <support@>
> > > > > wrote:
> > > > > > > > > Hi Maren
> > > > > > > > > Best regards
> <anystarter@>
> folder “Marens
> > > > > > Armmodell”.
> > > > > > > > > > Good Luck
> > > <support@>
> > > > > > > wrote:
> > > > > > > > > > > Hi Maren
> > > section?
> > > > > > > > > > > Best regards
> > > > > > > > > > > > Hallo,
> that
> > > only
> > > > > three
> > > > > > > > > muscles
> the
> > > almost
> > > > > > > 90degree
> > > understandig
> > > > > > which
> > > > > > > > > muscle
> by
> > > hand
> > > > > with the
> > > > > > > > > law of
> imprecise i
> > > > > could see,
> > > > > > > > that
> this
> > > special
> > > > > > > > task. How
> internal
> > > tasks which
> > > > > > > > > increase
> for
> > > example?
