Addendum:
You might have to add a "exit" at the end of your script in order
for the console to close after the script.
I've had problems using this syntax when I did not add an empty
line at the end of the script (because it would not do the “enter” on the
exit line)
Just to make sure it was clear, you have to use the word "type" in
the command, so in your example, it would be:
type temp.anymcr | anybodycon
Good luck
Jean-Olivier
Of Jean-Olivier Racine
Sent: Thursday, November 01, 2007 8:34 AM
Subject: RE: [AnyScript] Re: calling a macro from the command line, change
from v2 to v3?
Importance: High
Hello David,
I’d like to suggest a workaround for your problem. Instead of typing
“anybodycon <scriptname>”, try using the redirection pipe and use the
following syntax: “type <scriptname> | anybodycon”. This should yield the
exact same result.
Hope it helps,
Jean-Olivier
From: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
[mailto:anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com> ] On
Behalf
Of AnyBody Support
Sent: Wednesday, October 31, 2007 8:50 AM
To: anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
Subject: [AnyScript] Re: calling a macro from the command line, change from
v2 to v3?
Importance: High
Dear David,
You are perfectly right that something is wrong. It is simply a bug.
It has been located and fixed. I am embarrased that this slipped
through our testing procedures.
We shall release the fix as soon as possible. Let us know if you need
the fix very urgently, then I can upload a temporary fix here on the
group.
Michael
AnyBody Support
— In anyscript@yahoogroups.com <mailto:anyscript%40yahoogroups.com>
<mailto:anyscript%40yahoogroups.com> ,
“dww805” <dwwagner@…> wrote:
> I was using anybody v2 with the following command:
> anybodycon temp.anymcr
> where temp.anymcr is an anybody macro.
> However, I have ugraded to v3, and when I make the same call, the
macro does not get
> loaded in (and run) but I get put straight into the user interface
(command line) where I can
> type in commands like ‘run’, ‘load’, and even
‘runmacro(“temp.anymcr”)’ => in which case the
> macro does run.
> Have you encountered this problem before? Am I doing something
wrong here?
> Thank you in advance.
> -David
