cannot run the simulation
ERROR(OBJ.MCH.KIN3) : ‘ObjectName’ : Kinematic analysis failed in time step ‘integer’
Explanation:
This error may arise when the kinematical analysis fails to complete. This implies that the kinematic constraints does not have a solution or simply that the solution was not be found with under the given numerical circumstances.
In the latter case, more appropriate settings of the kinematic solver may allow for a solution.Additionally, a better choice of initial positions will improve the solver ability to solve the constraints.
How to solve problems related to this type of error ? this error happened when i changed the scaling anthro file values
