I was attempting to change the weight of human as shown in the attached image. However, change of the human weight in this way does not effect on the results as expected. (also shown on the attached image - the graph remain same for different human weights). I assume the way I changed the weight is incorrect.
I applicate if you could let me know if there is another way to change the weight of the human.
This looks like a mocap example. In the main file of the mocap model, you can typically find the path to the SubjectSpecificData.any file. In this subject specific data file, you can find and change the body mass of the subject.
