Climbing and descending stairs ground reaction forces
Good afternoon, I'm analyzing the ground reaction forces when climbing and descending stairs. However, I get the following error:
I've tried increasing the tolerance, but it reaches 2464 frames and stops.
Thank you for your attention.
Catarina Rocha
Hi Catarina,
That seems to be an error in kinematics and I am not sure why that is happening. It looks like the left leg is bent in a strange way, or maybe that's just my impression from the image. Can you check if the kinematics in the bvh file is reasonable at this frame. There could be something odd about this posture that is breaking the kinematics.
Good morning, I'm sorry I'm only replying now, I've been analyzing the bvh file and the left leg seems to be tilted, it may have been some sensor that perhaps wasn't placed correctly. I think it's best to discard this test.
Thank you very much for your help :slight_smile:
Catarina Rocha
Good morning,
I agree, it doesn't make sense to analyze incorrect motion.
I want to also point you to a previous post that discusses GRF prediction for stairs. It may be useful for you.
Good morning,
Yes, I was having the same problem, thank you very much for sharing.
Catarina Rocha
Good afternoon, I apologise for bothering you again, regarding the ascent and descent of stairs, I've been changing the minimum and maximum distance between the foot and the surface and it already detects the ground reaction forces. Regarding the following line (// See: #include "<ANYBODY_PATH_AMMR>/Tools/GRFPrediction/FootPlateConditionalContact.any" ), for ascending and descending stairs, is it necessary to uncomment or do I keep it the same, as shown in the attached image?
Catarina Rocha
Hi Catarina,
You can leave the line as it is. It is just a shortcut to take you to the definition of the class template, where you can read more about all the settings available.
Good morning, I understand, thank you very much.
Catarina Rocha
