i have difficulties in using AnyKinCoM. When i use it in the Study folder i get as result: Pos, Vel, and Acc. Furthermore there is “folder” containing the segments. But there is no mass summed up.
I have not checked the old versions of AMS yet.
But when I see the reference manual of AMS V5.3 regarding this AnyKinCoM object, there is an output value called ‘MassTotal’ which shows the total sum of masses in the AnyKinCoM object.
Of course you can use this feature in our latest AMS V6.0.1.
When i place the AnyKinCoM driver outside of the Study folder, then i have MassTotal, but then all values (Pos, Vel, Acc, … MassTotal) are zero even after analysis.
What is the mistake?
As I told already, you can find the MassTotal property in the AnyKinCoM object.
And I usually use this AnyKinCoM object inside my model folder.
Of course usually AnyBodyStudy object should have a reference of your model folder.
But even if your AnyKinCoM object is not inside your model folder, then you should create a separate reference of your AnyKinCoM object (or the reference of AnyFolder which contains your AnyKinCoM object) in your AnyBodyStudy object.
AnyBodyStudy object will only consider the objects which AnyBodyStudy object has their references.
thanks for your helpfulness.
I found the problem: The AnyKinCoM folder was accidentally placed in between Model and Study. It was neither in Model nor in Study. Now i placed it in the Model section and i now have non-zero values and a mass.
But is still don’t understand why there is no MassTotal in Study/Output/Model/CoMUpperExt neither now nor in the first version (see code in my first question). Is this what you mean with “AnyBodyStudy object will only consider the objects which AnyBodyStudy object has their references.”? What do you mean with this?
could you please have a look at my posting from Yesterday 09:20 AM, there i wrote that i have a MassTotal, i. e. i have a version which provides MassTotal. In fact i have exactly the version you recommended me, 5. 3. 1. 3556
I am afraid, another download wouldn’t help
The question was however, why the MassTotal is not always present.
Sorry again for not understanding your question very well.
In your picture you are looking the output folder of AnyBodyStudy object.
This output folder will show all time-varying values.
But this MassTotal will not be changed according to time.
That’s the reason why you could not find this value in the output folder of AnyBodyStudy object.
Instead, you should see where this object is actually defined in your model tree. Then you can find this MassTotal value.
