Hi, AnyBody support,
We plan to use Vicon’s motion analysis system with EMG to study the musculoskeletal loading during manually pushing/pulling two-wheeled carts on ramps. We will incorporate one or two force plates with a flat or ramped walkway.
We have interest in two independent variables: slope of the ramp (0 and 10 degrees), and the loaded weight on the cart (2 levels: 10 kg, 20 kg, for example).
Question 1:
What stl files that we need to import except one two-wheeled hand cart?
Is it necessary to import other stl files of floor (one is flat, the other is ramped), and two weights (Can I just change the cart’s weight to make the loaded weight differently)?
I guess the force plate data will be enough to tell AnyBody system the difference about the floor slope and loaded weight.
Question 2:
I noticed that the GaitFullBody model still used hard constraints for the sterno-clavicular joint rotation, besides driven by a plug-in-gait full body markers data.
What do you suggest if we want to drive my model only by the markers?
Question 3:
I plan to create 2 prismatic joints between the hand palms and cart’s handles. Is it necessary to apply reaction force to the joint here?
Question 4:
Probably we will put 4 markers on the cart. Is it good enough to get the markers data to drive the cart?
Question 5:
So, with the force plate data, full body Plug-in-gait and cart markers data, and the connection using prismatic joints, Will the AnyBody system really simulate the task of human body pushing/pulling the cart without any other problem?
I am not sure whether the AnyBody is able to simulate such a complicated task. Could you give me some advice?
Since we are in the step of designing the experiment, we need to think about all facets of the project in advance. The problems listed above are what I am worried about presently. We appreciate your generous suggestion and help!
Thank you!
Sincerely,
