I have a question regarding to the AnyBody Command Line Application.
I writed a program in C++ who should be able to start the AnyBodyCon.exe and open a macro file in it to load a model.
I did this with the C++ Funktion ShellExecute() and gave the function the path to the .exe-File and as parameter the string " runmacro “filename.anymcr” ".
When I compile and start my program there is no problem. Also the .exe-File openes directly but then AnyBodyCon.exe says that can`t open the macro file.
If I include the same command directly into the AnyBodyCon.exe out of my menu the macrofile runs without a problem.
I hope you can help me with my problem.
Dear, Anja.
The ”runmacro” is not a program argument for AnyBodyCon. It is a command for the macro language.
You find the program arguments by calling AnyBodyCon.exe /?. This gives the following
AnyBodyCon.exe <arguments>:
This starts the AnyBody console application
in interactive modes.
AnyBodyCon.exe MacroFile.anymcr <arguments>:
and executes the macro script in the file MacroFile.anymcr.
ARGUMENTS :
/?, -?, --help
Help
/d <dirname>, -d <dirname>, --dir=<dirname>
Sets current directory to ‘dirname’.
/m <macrofile>, -m <macrofile>, --macro=<macrofile>
Specifies the macro file to execute to ‘macrofile’.
The solution should be “/m “filename.anymcr”” as argument to ShellExecute(…)
Equivalent is “-m “filename.anymcr”” or “–macro=“filename.anymcr””
Thank you for your reply.
I tried your solution before I made this posting.
Now I tried it again and I will shor your the error:
Current path: xxx
Error: " : runmacro: string parameter with file name expected
Error: : command expected
Warning: AnyBody.anymcr: has no effect.
My ShellExecute looks like this:
ShellExecute(NULL, “open”, tempString.c_str(),ex.c_str(),NULL,SW_SHOWNORMAL);
with the parameters:
//For the macro file
string ex = “/m “D:\Dokumente und Einstellungen\ajk$\Desktop\Thesis\Thesis\AnyBody.anymcr””;
//For the exe file
string tempString = “C:\Programme\AnyBody Technology\AnyBody.4.1\AnyBodyCon.exe”;
Jap, that’s no problem.
Here’s the file AnyBody.anymcr:
load “Z:\300\330obs\MA\Studenten\Anja Krauss\AnyBody\Tutorial_C3D\C3DTest.any”
operation Main.MyStudy.InverseDynamics
run
exit
I tried a little bit playing with my code and now I get a new error
My code looks like this:
Hi Anja,
the problem seems to be in the /m option. Without the option it works, at least in my machine. This is obviously a bug. Again, sorry for the inconvenience. It’s already forwarded to the development and will be included in the next release. Sorry for the trouble you experience in using the command line options.
Sebastian
