I am using a model based on BVH-data in "On hands and knees"-Position so far.
Now I want to modify the script for other BVH-data to simulate the Dorsal position as well. I think I just have to change contacts to the ground so I thought about it. In my opinion the necessary contacts are the following: Head, both feet, maybe one or both hands, pelvis and back.
I've implemented everything except pelvis and back because I'm not sure, wich contact nodes will exactly get in touch with the ground.
Can you help be in this deliberation?
Thank you very much in advance!
Alicia
Please have a look in the file BackRestSupport.any in the SeatedHumanModel of the repository. In this file a number of nodes are defined on the spine to be used for contact.
The definition of these points can be re-used and then you can create the contact object in the way you have already using some of these points. (The contact definition in the seatedhuman model is outdated in the way it is implemented, but the points defined you can used)
Hi Søren,
Thank you very much for your fast reply. I think I'm now done with implementing the contacts my model will have.
When I run the analysis I get an error message: ERROR(OBJ.MCH.MUS4): AnyMocap.any(63): InverseDynamicStudy.InverseDynamics: Muscle recruitment solver: solver aborted due to singular KKT matrix.
Can you help me finding out what the problem could be? I think it deals with muscle and joint lists etc. of my model, isn't it?
Alicia
This error means the model failed to resolved the muscle recruitment, so there was no way to do the balance.
In you case i would look carefully again at the contact you have defined and check they are all valid.
Try to increase the limitlow+ high and the radius to ensure the contact is possible.
Additionally you could try to add more contact elements.
On the picture it might look like the right foot is somehow flipped but it is hard to see on image. If this is the case it could also cause the issue.
To resolve this try to obtain a better starting guess on the posture, this you can do in the TrialSpecific.any file. So try to get it closer to the markers. I think this might solve the problem.
Hi Soren,
Thanks for your message. So by chanching the radius the model is running.
I have another question due to shoulder contacts in dorsal position. I would like to imlement one contact on each shoulder plate so therfore I will need a refnode to implement the ConditionalContactClass ShoulderContacts. My question is how do I get the vector defined in sRel? Is there any possibility to find a spot on the scapula and get the coordinates to define sRel?
Best reagrds
Alicia
