Hi Soren,
my driver for toe is as follows;
AnyKinEqSimpleDriver MetatarsalYLDrv={
AnyKinLinear lin={
AnyRefFrame &ref1=Main.Model.HumanModel.Left.Leg.Seg.Foot.LTOE;
AnyRefFrame &ref2=Main.MarkerTopology.M14.FreeMarker;
Ref=0;
MeasureOrganizer={2};
DriverPos={0};
Reaction.Type={Off};
DriverVel={0};
All other markers are driving the model well appart from the foot. (measure
organiser is in the z coordinate for ankle plantar flexion and dorsiflexion.)
The Vaughan data looks very smooth and I could not find a Pointsmarker file, has
the data been processed before it was modeled?
By adding the ligaments I was hoping to add constriant for enverison/inversion,
are you saying this is not possible?
many thanks
Peter
AnyBody Support <support@anybodytech.com> wrote: Hi Peter
Adding ligaments to the ankle will not change the motion of the ankle in
anyway, this is inverse dynamics so the motion is always prescribed. Adding
the ligaments will of course help carry the load but that is another thing.
It should be possible to make the toe node follow the marker more or less,
but it can be difficult to control. One simple thing to check is if you are
using the local coordinate system on the toe marker as basis for you
kinematic measure?
So it should look like something like this
AnyKinEqSimpleDriver ToeMarker ={
AnyKinLinear lin ={
AnyRefNode &ref1=.Toemaker;
AnyFixedRefFrame &ref2=.GlobalRef;
Ref=0; //This will make this measure use the Toemarker coordinate system
for the measurements.
MeasureOrganizer={0}; //pick out the x direction I recall this to be
normal to the foot, please verify…
DriverPos={0};
DriverVel={0};
If you do not specify the Ref=0; line it will use the global coordinate
system and then the foot flexion can be difficult to control, I have seen
this on a early version of the gait model.
I do not understand what you mean by “manmade” all the dof in the Vaughan
model is driven by the marker data.
I hope this made things clearer, otherwise please write again.
Of peter.worsley
Sent: 08 April 2008 15:37
Subject: [AnyScript] Control of ankle plantar flexion
Hi AnyBody group,
I have recently been collecting some gait data sets and inputting
them into a modified freeposture model for analysis. I am currently
having difficulty with getting the toe node on the mannequin to follow
the marker coordinates. This is obviously giving abnormal results for
plantar and dorsiflexion, as well as eversion and inversion. Looking
at the Vaughan model, there seems to be a fair amount of restriction
on the ankle movements and i’m not sure if its data controlled or ‘man
made’. Looking at the previous post from Mike, it seems adding deltoid
and lateral collateral ligaments maybe a good way to help control the
ankles movements.
I have also played with the idea of adding extra markers to the foot
(over the cubiod) to drive the movement in the model.
Has anyone else shared my experience with inability to control the
ankle, are there any suggestions to help?
many thanks
Peter
Users of the AnyBody Modeling System help each other create biomechanical models
in the AnyScript language.Yahoo! Groups Links
Yahoo! for Good helps you make a difference
