Hi all!
I just would like to make a coordinate transformation from points given in the global coordinate system to a local coordinate system (also defined in global CS by r and axes). Mathematically I would say:
Pglob = R * Ploc + t
with the rotation matrix R and the translation t.
R = {axes1, axes2, axes3};
t = r;
This will lead to:
Ploc = inv® * (Pglob - t)
How do I translate this into AnyScript or is there even a defined class? The formulation:
AnyVec3 Ploc = R’ * (Pglob - t)’;
Did not work for me.
Thanks a lot and I appreciate any help!
klabauterjunge
Dear Malte,
It will be easier for you if you can see the explanation of the ‘AnyRefFrame’ class in the AnyBody reference manual.
[i]Notice that AnyBodyâ„¢ stores all vectors in row format, so they must be transposed before the transformation and the expression must be turned around. In AnyScriptâ„¢ syntax this looks like
GlobalVector = (Axes * LocalVector’)’;
or
GlobalVector = LocalVector * Axes’; [/i]
I hope this may help you.
Dear Moonki,
thanks for your response! However, the described transformation is forward and does not take the translation into account. I discovered some bugs in my code (column format in the matrix). Finally the following equation worked:
AnyVec3 LocalVector = (Shank.Axes’*(GlobalVector-Shank.r)’)’;
Best wishes,
Malte
