Create Simple Macro
Hi again anybody community,
I was also using the anybody command prompt and successfully getting
data output for several files, and the tutorial mentioned using a
macro,in which the name of the macro could merely be entered and it
would execute the commands, my questions is there a format for this
macro, and how do you make it?
For instance if I wanted to make a macro for the example file in the
tutorial what would I do?
I created an .anymcr file containing:
load “C:\demo.outputfile.any”
operation Main.ArmStudy.InverseDynamicAnalysis
run
exit
And then entered the name of my macro file into the AnyBody Command
Prompt,with no avail
Hi William
The macro you have written looks ok.
If you write “AnyBodyCon YourMacroName.mcr” the macro should be
executed provided that the AnyBodyCon can be activated from the
location where you have the file.
I am a little unsure on your description of the problem, did nothing
happen? maybee it did run the macro without that you noticed it,
you will not see much it will take a few seconds and a new output
file will have be created.
getting
it
this
the
> run
> exit
Command
AnyBodyCon is an unrecognized command,
if i have the demo.outputfile located at c:\ and my macro called
macro.mcr what do i type into the anybodyconsole to execute it?
i’ve tried AnyBodyCon C:\macro.mcr
the tutorial mentions command line application can be given such a
file as its command line argument, and it will perform the commands
in it.
so i tried c:\macro.mcr (with and without parenthesis)so on,
everything unrecognized command,
wrote:
> Hi William
nothing
> Best regards
> getting
> it
> this
> the
> > run
> > exit
> Command
Hi William
This must be because AnyBodyCon.exe can not be found. Please try to
locate the AnyBodyCon.exe in the folder in which you installed
AnyBody, then copy the file to the directory where you want to
execute it in.
Søren AnyBody Support
commands
> in it.
> wrote:
> > Hi William
> nothing
it,
output
> > Best regards
> > getting
using a
and
> > it
> > this
in
> > the
> > > run
> > > exit
> > Command
Thanks Soren,
Thought the AnyBodyCon was a command for inside the AnyBody Console,
thats where I was trying to execute the macro. Just realized that
was for the command console, that solved the problem :slight_smile:
wrote:
> Hi William
to
> execute it in.
> Best regards
a
> commands
> > in it.
> > wrote:
> > > Hi William
be
the
> > nothing
> it,
> output
> > > Best regards
> > > getting
> using a
> and
> > > it
for
> > > this
file
> in
> > > the
> > > > run
> > > > exit
> > > Command
