firstly some scripting code:
Joint definition:
AnySphericalJoint Knee = {
Orientation.Type = RotAxesAngles;
Orientation.Axis1 = y;
Orientation.Axis2 = z;
Orientation.Axis3 = x;
AnyRefNode &femur = Main.RatModel.Seg.Femur.Knee;
AnyRefNode &tibia = Main.RatModel.Seg.Tibia.Knee;
}; // Knee joint
Measure:
AnyKinRotational LinKneeRot = {
Axis1 = y;
Axis2 = z;
Axis3 = x;
AnyRefFrame &femur = Main.RatModel.Seg.Femur;
AnyRefFrame &tibia = Main.RatModel.Seg.Tibia;
Drivers:
AnyKinEqInterPolDriver DriverKneeRotX = {
Type = Bspline;
BsplineOrder = 4;
FileName = "drivers\knee_rot_x.txt";
AnyKinMeasure &Lin = Main.RatModel.Drivers.LinKneeRot;
MeasureOrganizer = {2};
Reaction.Type = {On};
AnyKinEqInterPolDriver DriverKneeRotY = {
Type = Bspline;
BsplineOrder = 4;
FileName = "drivers\knee_rot_y.txt";
MeasureOrganizer = {0};
Reaction.Type = {Off};
AnyKinEqInterPolDriver DriverKneeRotZ = {
Type = Bspline;
BsplineOrder = 4;
FileName = "drivers\knee_rot_z.txt";
MeasureOrganizer = {1};
This is the way I’m determining the reaction forces in the knee joint:
AnyForceMomentMeasure Knee = {
AnyRefFrame &Pelvis_Femur = Main.RatModel.Seg.Femur2.Knee;
AnyReacForce &Knee_Loads =
Main.RatModel.Jnts.Knee.Constraints.Reaction;
AnyReacForce &KneeX_Loads =
Main.RatModel.Drivers.DriverKneeRotX.Reaction;
AnyReacForce &KneeY_Loads =
Main.RatModel.Drivers.DriverKneeRotY.Reaction;
AnyReacForce &KneeZ_Loads =
Main.RatModel.Drivers.DriverKneeRotZ.Reaction;
Now to my question: If I wanted to have the reaction forces in the
knee joint calculated referring to the local (anatomic)
co-ordinatesystem, is this the right way to do it? If so, do the
values in Main.MyStudy.Output.Knee.F[0], Main.MyStudy.Output.Knee.F[1]
and Main.MyStudy.Output.Hip.F[2] have the same order as defined in the
joint definition (Orientation.Axis1 = y complies with F[0],
Orientation.Axis2 = z complies with F[1] and Orientation.Axis3 = x
complies with F[2])?
Thanks a lot in advance.
