hello, I'm trying to use a bvh file from a mocap system to do some anybody modeling analysis. I noticed that the official template file of bvh has the rotation order of XYZ, while my bvh file has the oder of ZXY. I wonder if anymodeling can load this bvh file correctly (although there were no errors when loading ZXY bvh files)
Hi Tucker,
This is not a problem by itself, the BVH reader will handle this and use the sequence defined in the bvh file. If you are using a BVH with a different joint topology it is another story then you will need to make modifications to the MarkerProtocol file and the scaling of the model.
