Hi everyone,
is it possible to visualize the center of mass position in the model
view, similar to ‘AnyDrawNode’, for the whole body during inverse
dynamic analysis?
Thanks for your help,
Peter
Hi everyone,
dynamic analysis?
Peter
Hi Peter
Yes this is possible to do so but you need a few more lines and a dummy
segment.
AnyKinCoM massmeasure ={
Add here references to your segments…
AnySeg dummyseg={
Mass=0;
Jii={0,0,0};
AnyDrawNode drw={ ScaleXYZ={1,1,1}*0.2; RGB={0,0,1};};
AnyKinLinear lin={
AnyFixedRefFrame &ref=.GlobaRef;
AnySeg 6ref2=.dummyseg;
//this will drive the massmeasure and the lin measure to be identical
//which will ensure that the pos of the dummy seg is positioned at the CoM
AnyKinEq Driver ={
AnyKinLinComb lincomb={
AnyKinLinear &ref1 =…lin;
AnykinCoM &ref2 =…massmeasure;
Coef={{1,-1},{1,-1},{1,-1}}; //lin(x,y,z) = massmeasure(x,y,z) };
In addition the rotations of the dummyseg needs to be driven to zero…
Hope it works there might be minor errors… It was not testes
Of peter.belei
Sent: 02 October 2008 18:09
Subject: [AnyScript] Draw the Center of Mass position during Analysis
Hi everyone,
dynamic analysis?
Peter
Hi Søren,
Thanks a lot for your help. I finally corrected the minor errors ;)…
Here is my solution, and it works:
AnyKinCoM massmeasure= {
AnyFolder &Body = .HumanModel;
AnySeg dummyseg={
Mass=0;
Jii={0,0,0};
AnyDrawNode drw={ ScaleXYZ={1,1,1}*0.05; RGB={1,0,0};};
AnyKinLinear lin={
AnyFixedRefFrame &ref1=.Environment.GlobalRef;
AnySeg &ref2=.dummyseg;
the CoM
AnyKinEq Driver ={
AnyKinMeasureLinComb lincomb={
AnyKinLinear &ref1 =..lin;
AnyKinCoM &ref2 =..massmeasure;
Coef={{1,0,0,-1,0,0},{0,1,0,0,-1,0},{0,0,1,0,0,-1}};
AnyKinMeasureOrg DummySegRotX={
AnyKinRotational rot ={
AnySeg &ref =..dummyseg;
Type=RotAxesAngles;
MeasureOrganizer={0};
AnyKinMeasureOrg DummySegRotY ={
AnyKinRotational &ref=.DummySegRotX.rot;
MeasureOrganizer={1};
AnyKinMeasureOrg DummySegRotZ ={
MeasureOrganizer={2};
AnyKinEqSimpleDriver dummysegdriver =
AnyKinMeasureOrg &ref1 = .DummySegRotX;
AnyKinMeasureOrg &ref2 = .DummySegRotY;
AnyKinMeasureOrg &ref3 = .DummySegRotZ;
DriverPos = {0,0,0};
DriverVel = {0,0,0};
Peter
— In anyscript@yahoogroups.com, AnyScript Support <anyscriptsup@…>
wrote:
> Hi Peter
> segment.
> AnySeg dummyseg={
> Mass=0;
> Jii={0,0,0};
> AnyKinLinear lin={
the CoM
> AnyKinEq Driver ={
> Best regards
> _____
On Behalf
> Of peter.belei
> Hi everyone,
> dynamic analysis?
> Peter
