Hi everyone,
I am working on the standing model. In JointsAndDrivers.any I defined
some conditions in order to simulate a knee bending. I wonder if there
is a possibility to drive the rotation (.Axes) of a Segment in
relation to the global reference. I would like to define the rotation
of the pelvis segment in order to simulate different pelvis
inclination angles. Till now I realized the pelvis tilt by defining
the x-value of three segment nodes (.r) in relation to the global
reference .
But this constrains three dof (rotation around x and y, translation in
x) of the pelvis segment in relation to the global reference. I would
like to get rid of the translation in x constraint.
You can easily drive the pelvis rotation in the global reference frame.
This is done in the FreePosture model. You can have a look (in the
JointAndDrivers file) at the PelvisGroundDriver. You can use exactly
the same syntax and set the value of the angle in the Mannequin file.
Sylvain, AnyBody Support
— In anyscript@yahoogroups.com, “peter.belei” <peter@…> wrote:
> Hi everyone,
> reference .
> Thanks for your help,
> peter
