Hi Ali
I have searched this group for messages related to this topis please
try to follow the following threads
1072 , 309 and 211
In these messages you will the this link
http://www.fbw.vu.nl/research/Lijn_A4/shoulder/isg/proposal/protocol.
htm
which is a explanation to the coordinates system we have used in the
shoulder, it is different for the article you mentioned in some
joints, but not all of them, according to the previous messages the
GH should be similar whereas SC is different.
So if you would like to drive the model using the coordinate system
of the ISB recommendations for upper extremity (Wu et al, 2005);
You will need to create new rotational measures which will replicate
the measures used in the article. It will be too detailed to give
you a step by step procedure to follow on how to do this i am
afraid.
So here is a sketch …
1 create a node in the SC joint on both clavicula and thorax which
has the desired orientation. The ARel property of the nodes can be
used to change the orientation of the nodes.
2 Create an AnyKinRotational based on these nodes, be sure that the
rotation sequence is correct this can be controlled by the sequence
listed in the Axis1 Axis2 and Axis3 properties.
3 If you have measured data and you would like to drive the model
you can use an AnyKinEqinterpolDriver for this purpose.
I would recommend to create the model using the FrePostureMove model
as the basis. Then replace the bodymodel FullBodyModel listed by the
SpineRightArm model. Trying to load this model will give you
multiple errors you will need to get rid of drivers for the
bodyparts which was removed, and so on.
Once the model is running you should starts following the three
steps for each joint. The file Jnt.any contains the current joint of
the model and possible you can use some of them without change.
I hope this helps you move on, otherwise please write again.
The above steps requires some knowledge of AnyScript, if needed
please follow some of the initial tutorials available on
www.anybodytech.com
Søren , AnyBody support
— In anyscript@yahoogroups.com, “Ali” <aliniku@…> wrote:
> Hi,
> I asked later a question about how to import kinematic data to
> AnyBody model, and received the answers but they didn’t help much.
> Now, let me explain my questions in more detail:
> My final aim is to calculate muscle forces in shoulder and arm
region
> using the in vivo measurements.
> First thing I want to know is that if I should use the ‘Arm3D’ in
> the ‘Brep’ repository or something else in the ‘Arep’ directory?
> Second, I recorded the marker data during different movements
(e.g.
> abduction, flexion, etc) for each time step during the subject
> movement; then, for each movement, I calculated the Cardan (or
Euler)
> angles at each joint (e.g. SC joint, AC joint, Elbow joint, etc)
> based on ISB recommendations for upper extremity (Wu et al, 2005);
> please kindly explain me step by step (or guide me to some
> references) how to apply these joint angles to drive the model and
to
> calculate the muscle forces?
> Thanks in advance for your kind attention and collaborations.
> Best regards,
> Ali
