Equilibrium
Dear AnyBody team,
i did some static analyses with the standing model without muscles
with different thorax-pelvis flexion angles and found something strange:
the resultant forces on the T12L1 and the L5Sacrum joint are not
dependent on the flexion angle?! Shouldn’t the resultant forces
increase with increasing flexion angle? Even the components in the
global system don’t change. (Though the forces in the local systems
change.)
And another question: I want to find ALL loads acting on the lumbar
spine for a free body diagram (L1 to L5). Are there other forces than
the joint forces? (In a first step i disregard the muscle forces as i
used the model without muscles.) I wonder why the resultant forces at
T12L1 are different to L5Sacrum. Is this due to the lumbar mass? How
to obtain mass forces?
javed
Hi Javed,
Your question is quite surprising because the reaction force inT12L1
joint does change during flexion, both in global and local coordinate
system. So it sounds very strange when you tell me that the reaction
force is not depending on flexion angle.
You said you made several static analyses, you will not be able to
see the force changing during a static analysis. You have to compare
it with other static analyses with different postures.
The forces acting on a static free body diagram are the joint forces,
muscles forces and weight. As you run the model with no muscle the
muscle forces are replaced by artificial torques in the joints. Then
it is normal that the reaction forces are different in T12L1 and
L5Sacrum because T12L1 joint support the weight of the thorax whereas
L5Sacrum joint support the lumbar segments weight in addition to the
thorax. You can see the mass of a segment from the model tree or you
can measure it (one segment or a group of segment) using the
AnyForceMomentMeasure2.
Sylvain, AnyBody Support.
— In anyscript@yahoogroups.com, “javed377” <javed377@…> wrote:
> Dear AnyBody team,
strange:
> change.)
than
i
at
> Thanks,
> javed
Hi Sylvain,
Thanks for your qucik response. I let a colleague of mine check my
findings. He found the same: For the standing model(Repository6.1)
without muscles (the original StandingModel.Main.any but without the
10 N at the right hand) we did 3 separate kinematic analyses and found
the following local forces at T12L1 and L5Sacrum.Incase of model with
muscles you are right that forces do change, but please take a look in
case of StandingModel without muslces.
0 degree PelvisThoraxExtension:
T12L1 Reaction.Fout: {10.4; 311; 0} Axes[0][0]=0.999
L5Sacrum: Reaction.Fout: {13.8; 414; 0} Axes[0][0]=0.999
-50 degrees:
T12L1: Reaction.Fout {-159; 268; 0} Axes[0][0]=0.859
L5Sacrum: Reaction.Fout {41; 412;0} Axes[0][0]=0.995
-90 degrees:
T12L1: Reaction.Fout {-265; 164; 0} Axes[0][0]=0.526
L5Sacrum: Reaction.Fout {52; 411; 0} Axes[0][0]=0.992
Transforming the joint forces to the global system results in {0; 311;
0} and {0; 414; 0} for ALL three flexion angles. Have you got an idea
how to interpret these results?
Javed
> Hi Javed,
> Best regards,
> — In anyscript@yahoogroups.com, “javed377” <javed377@> wrote:
> > Dear AnyBody team,
> strange:
> > change.)
> than
> i
> at
> > Thanks,
> > javed
Hi Javed,
Sorry I was looking at the model with muscles. But yes you are right,
the reaction forces in T12L1 and L5Sacrum (and the others lumbar
joints) does not change during flexion when using the model without
muscles. And the reason is precisely because there are no muscles in
the model:
In the NoMuscle body model the forces acting on a segment are the
gravity, the joint reaction forces and the artificial torque in the
joint. The artificial torque replaces the muscles. So in this case
the reaction force of the joint Fout is only acting against the
weight of the segments (the moments are carried by the torque and
does not appear in Fout). And in global coordinates the weight is
always constant along the Y axis. That is why you can see that the
reaction force of T12l1 in global coordinates doesn’t change.
I hope this makes it clear.
> Hi Sylvain,
found
with
in
> -50 degrees:
=0.859
> -90 degrees:
=0.526
311;
idea
> Thanks,
> Javed
wrote:
> > Hi Javed,
inT12L1
coordinate
reaction
to
compare
forces,
the
Then
whereas
the
you
> > Best regards,
> > > Dear AnyBody team,
muscles
> > strange:
the
systems
> > > change.)
lumbar
forces
> > than
forces as
> > i
forces
> > at
mass? How
> > > Thanks,
> > > javed
Hi Sylvain,
Thanks for you nice response. But still one thing is not clear to me
how to find the artificial torque?
With best regards.
Javed
> Hi Javed,
> the model:
> Best regards,
> > Hi Sylvain,
> found
> with
> in
> > -50 degrees:
> =0.859
> > -90 degrees:
> =0.526
> 311;
> idea
> > Thanks,
> > Javed
> wrote:
> > > Hi Javed,
> inT12L1
> coordinate
> reaction
> to
> compare
> forces,
> the
> Then
> whereas
> the
> you
> > > Best regards,
> > > > Dear AnyBody team,
> muscles
> > > strange:
> the
> systems
> > > > change.)
> lumbar
> forces
> > > than
> forces as
> > > i
> forces
> > > at
> mass? How
> > > > Thanks,
> > > > javed
Hi Javed,
You can visualize the force of the artificial torque in the chartFX
windows. More exactly those torque are created with
AnyGeneralMuscles, they are not real muscles and are acting exactly
like a pure moment applied to the joint.
Please find in the chartFX windows:
Main.Study.Output.Model.HumanModel.Trunk.JointMuscles.L1L2Jnt.Extensio
n.dof0.Muscle.PosMuscle.Fm
This is for example the torque acting for the positive thorax flexion
in T12L1 joint.
> Hi Sylvain,
> With best regards.
> Javed
wrote:
> > Hi Javed,
right,
without
in
> > the model:
the
case
the
> > Best regards,
> > > Hi Sylvain,
my
(Repository6.1)
without the
and
> > found
model
> > with
look
> > in
=0.999
> > > -50 degrees:
> > =0.859
> > > -90 degrees:
> > =0.526
{0;
> > 311;
an
> > idea
> > > Thanks,
> > > Javed
> > wrote:
> > > > Hi Javed,
> > inT12L1
> > coordinate
> > reaction
able
> > to
> > compare
> > forces,
muscle
> > the
joints.
> > Then
and
> > whereas
to
> > the
or
> > you
> > > > Best regards,
wrote:
> > > > > Dear AnyBody team,
> > muscles
something
> > > > strange:
are not
forces
in
> > the
> > systems
> > > > > change.)
the
> > lumbar
> > forces
> > > > than
> > forces as
> > > > i
> > forces
> > > > at
> > mass? How
> > > > > Thanks,
> > > > > javed
Hello Sylvian,
Many thanks for your replies. I need more to know that
does not exist in my model. Without “Extension” it exists. Have you
got repository ver. 7?
For flexion, i think DOF 2 is relevant?
I don’t understand the following: Why is the Fm proportional to the
gravity (always without muscles)? When there is physical no gravity, a
moment should nevertheless be necessary to deform the structure. When
i run the model with a zero gravity, zero moment comes out.
Have you got some hints, please?
Javed
> Hi Javed,
> in T12L1 joint.
> Best regards,
> > Hi Sylvain,
> > With best regards.
> > Javed
> wrote:
> > > Hi Javed,
> right,
> without
> in
> > > the model:
> the
> case
> the
> > > Best regards,
> > > > Hi Sylvain,
> my
> (Repository6.1)
> without the
> and
> > > found
> model
> > > with
> look
> > > in
> =0.999
> > > > -50 degrees:
> > > =0.859
> > > > -90 degrees:
> > > =0.526
> {0;
> > > 311;
> an
> > > idea
> > > > Thanks,
> > > > Javed
> > > wrote:
> > > > > Hi Javed,
> > > inT12L1
> > > coordinate
> > > reaction
> able
> > > to
> > > compare
> > > forces,
> muscle
> > > the
> joints.
> > > Then
> and
> > > whereas
> to
> > > the
> or
> > > you
> > > > > Best regards,
> wrote:
> > > > > > Dear AnyBody team,
> > > muscles
> something
> > > > > strange:
> are not
> forces
> in
> > > the
> > > systems
> > > > > > change.)
> the
> > > lumbar
> > > forces
> > > > > than
> > > forces as
> > > > > i
> > > forces
> > > > > at
> > > mass? How
> > > > > > Thanks,
> > > > > > javed
Hi Javed,
The path I gave you is for repository 7. If you use the repository 6
the path is a little different:
Main.Study.Output.Model.HumanModel.Trunk.JointMuscles.L1L2Jnt.dof0.Mus
cle.PosMuscle.Fm
As you noticed instead of Extension or LateralBending or Rotation you
have to pick directly dof0 or dof1 or dof2. The dof corresponding to
extension is dof0 (dof1 for lateral bending and dof2 for rotation).
Even without gravity there is a moment to move the body as you said
it. You can see it if you look at the good muscle. If you perform an
extension you will that the positive muscle of dof0 is active. If you
perform a flexion then it will be the negative muscle of dof0 that
will be active.
> Hello Sylvian,
gravity, a
When
> Thanks,
> Javed
> > Hi Javed,
chartFX
exactly
flexion
> > in T12L1 joint.
> > Best regards,
> > > Hi Sylvain,
to me
> > > With best regards.
> > > Javed
> > wrote:
> > > > Hi Javed,
are
> > right,
lumbar
> > without
muscles
> > in
> > > > the model:
the
in
> > the
> > case
the
and
weight is
that
> > the
> > > > Best regards,
wrote:
> > > > > Hi Sylvain,
check
> > my
> > (Repository6.1)
> > without the
analyses
> > and
> > > > found
> > model
> > > > with
take a
> > look
> > > > in
> > =0.999
=0.999
> > > > > -50 degrees:
[0][0]
> > > > =0.859
=0.995
> > > > > -90 degrees:
[0][0]
> > > > =0.526
=0.992
in
> > {0;
> > > > 311;
got
> > an
> > > > idea
> > > > > Thanks,
> > > > > Javed
<support@>
> > > > wrote:
> > > > > > Hi Javed,
force
> > > > inT12L1
local
> > > > coordinate
the
> > > > reaction
be
> > able
> > > > to
to
> > > > compare
joint
> > > > forces,
> > muscle
> > > > the
> > joints.
> > > > Then
T12L1
> > and
thorax
> > > > whereas
addition
> > to
> > > > the
tree
> > or
> > > > you
the
> > > > > > Best regards,
> > wrote:
> > > > > > > Dear AnyBody team,
without
> > > > muscles
> > something
> > > > > > strange:
joint
> > are not
resultant
> > forces
components
> > in
> > > > the
local
> > > > systems
> > > > > > > change.)
on
> > the
> > > > lumbar
other
> > > > forces
> > > > > > than
muscle
> > > > forces as
> > > > > > i
resultant
> > > > forces
> > > > > > at
lumbar
> > > > mass? How
> > > > > > > Thanks,
> > > > > > > javed
Hello Sylvian,
I am sorry…for asking again and again.
Actually you are so detailed, but your information that dof0 refers to
extension, dof1 to lateral bending and dof2 to rotation surprises me.
I found a moment in dof2 for extension (resp. flexion). This seems
logical as z faces to the right side of the body. Did i understand
something wrongly?
You said “Even without gravity there is a moment to move the body”.
That is not what i found! (Pleas remember that i use the model without
muscles) I found zero moment for zero gravity :frowning: (for dof0, dof1, and
dof2, negativ as well as positive).
What do you mean with “good muscle”?
It is absolutely not clear for me, why the moment is zero at zero
gravity. Could you please give me a clue?
Thanks, Javed
> Hi Javed,
> cle.PosMuscle.Fm
> will be active.
> Best regards,
> > Hello Sylvian,
> gravity, a
> When
> > Thanks,
> > Javed
> > > Hi Javed,
> chartFX
> exactly
> flexion
> > > in T12L1 joint.
> > > Best regards,
> > > > Hi Sylvain,
> to me
> > > > With best regards.
> > > > Javed
> > > wrote:
> > > > > Hi Javed,
> are
> > > right,
> lumbar
> > > without
> muscles
> > > in
> > > > > the model:
> the
> in
> > > the
> > > case
> the
> and
> weight is
> that
> > > the
> > > > > Best regards,
> wrote:
> > > > > > Hi Sylvain,
> check
> > > my
> > > (Repository6.1)
> > > without the
> analyses
> > > and
> > > > > found
> > > model
> > > > > with
> take a
> > > look
> > > > > in
> > > =0.999
> =0.999
> > > > > > -50 degrees:
> [0][0]
> > > > > =0.859
> =0.995
> > > > > > -90 degrees:
> [0][0]
> > > > > =0.526
> =0.992
> in
> > > {0;
> > > > > 311;
> got
> > > an
> > > > > idea
> > > > > > Thanks,
> > > > > > Javed
> <support@>
> > > > > wrote:
> > > > > > > Hi Javed,
> force
> > > > > inT12L1
> local
> > > > > coordinate
> the
> > > > > reaction
> be
> > > able
> > > > > to
> to
> > > > > compare
> joint
> > > > > forces,
> > > muscle
> > > > > the
> > > joints.
> > > > > Then
> T12L1
> > > and
> thorax
> > > > > whereas
> addition
> > > to
> > > > > the
> tree
> > > or
> > > > > you
> the
> > > > > > > Best regards,
> > > wrote:
> > > > > > > > Dear AnyBody team,
> without
> > > > > muscles
> > > something
> > > > > > > strange:
> joint
> > > are not
> resultant
> > > forces
> components
> > > in
> > > > > the
> local
> > > > > systems
> > > > > > > > change.)
> on
> > > the
> > > > > lumbar
> other
> > > > > forces
> > > > > > > than
> muscle
> > > > > forces as
> > > > > > > i
> resultant
> > > > > forces
> > > > > > > at
> lumbar
> > > > > mass? How
> > > > > > > > Thanks,
> > > > > > > > javed
Hi Javed,
For the referring of the dof you are right, I wrote it in the wrong
order last time. I’m sorry about that. I think I was focused on the
sequence defined in the driver that is not the same as the real
sequence of the axis in the joint. The right references are dof0 /
lateral bending, dof1 / axial rotation and dof2 / extension.
Now regarding to the activity without gravity, I have just run the
standing model (without muscles and without gravity) and I do see a
moment on the lumbar joints. Of course the moment is small but it is
there. Here are the values I have for 30 degrees of flexion in the
negative muscle of L5Sacrum.
XY
Main.Study.Output.Model.HumanModel.Trunk.JointMuscles.L5Sacrum
Jnt.dof2.Muscle.NegMuscle.Fm
0,00 0,00e+000
0,11 0,00e+000
0,22 0,00e+000
0,33 0,00e+000
0,44 6,88e-002
0,56 2,72e-001
0,67 4,75e-001
0,78 6,77e-001
0,89 8,77e-001
1,00 1,07e+000
By “good muscle” I mean the appropriate muscle, in this case the
negative muscle for dof2. Please look for this same output after
performing a flexion. You should not found zero moment.
> Hello Sylvian,
to
me.
> something wrongly?
without
and
> Thanks, Javed
wrote:
> > Hi Javed,
repository 6
> > cle.PosMuscle.Fm
you
to
rotation).
an
you
that
> > will be active.
> > Best regards,
> > > Hello Sylvian,
you
the
> > gravity, a
structure.
> > When
> > > Thanks,
> > > Javed
> > > > Hi Javed,
> > chartFX
> > exactly
> > flexion
> > > > in T12L1 joint.
> > > > Best regards,
wrote:
> > > > > Hi Sylvain,
clear
> > to me
> > > > > With best regards.
> > > > > Javed
<support@>
> > > > wrote:
> > > > > > Hi Javed,
you
> > are
> > > > right,
> > lumbar
model
> > > > without
> > muscles
> > > > in
> > > > > > the model:
are
> > the
torque
> > in
> > > > the
this
> > > > case
against
> > the
torque
> > and
> > weight is
> > that
> > > > the
change.
> > > > > > Best regards,
> > wrote:
> > > > > > > Hi Sylvain,
mine
> > check
> > > > my
> > > > (Repository6.1)
but
> > > > without the
> > analyses
> > > > and
> > > > > > found
of
> > > > model
> > > > > > with
> > take a
> > > > look
> > > > > > in
[0][0]
> > > > =0.999
> > =0.999
> > > > > > > -50 degrees:
> > [0][0]
> > > > > > =0.859
> > =0.995
> > > > > > > -90 degrees:
> > [0][0]
> > > > > > =0.526
> > =0.992
results
> > in
> > > > {0;
> > > > > > 311;
you
> > got
> > > > an
> > > > > > idea
> > > > > > > Thanks,
> > > > > > > Javed
> > <support@>
> > > > > > wrote:
> > > > > > > > Hi Javed,
reaction
> > force
> > > > > > inT12L1
> > local
> > > > > > coordinate
that
> > the
> > > > > > reaction
not
> > be
> > > > able
> > > > > > to
have
> > to
> > > > > > compare
the
> > joint
> > > > > > forces,
no
> > > > muscle
> > > > > > the
the
> > > > joints.
> > > > > > Then
in
> > T12L1
> > > > and
the
> > thorax
> > > > > > whereas
> > addition
> > > > to
> > > > > > the
model
> > tree
> > > > or
> > > > > > you
using
> > the
> > > > > > > > Best regards,
<javed377@>
> > > > wrote:
> > > > > > > > > Dear AnyBody team,
> > without
> > > > > > muscles
found
> > > > something
> > > > > > > > strange:
> > joint
> > > > are not
> > resultant
> > > > forces
> > components
> > > > in
> > > > > > the
the
> > local
> > > > > > systems
> > > > > > > > > change.)
acting
> > on
> > > > the
> > > > > > lumbar
> > other
> > > > > > forces
> > > > > > > > than
> > muscle
> > > > > > forces as
> > > > > > > > i
> > resultant
> > > > > > forces
> > > > > > > > at
> > lumbar
> > > > > > mass? How
> > > > > > > > > Thanks,
> > > > > > > > > javed
Hello Sylvian,
Now i am completely confused. At first i was wondering why there is
(nearly) no moment in the model without muscles and without gravity.
Now i changed my mind because i remember that there is no stiffness in
the lumbar spine(in one of previous postings). Now i think there
should not be any moment necessary to deform a completely elastic
structure.
BUT now you say there is a moment (for the model without muscles and
without gravity).
That’s why i have to nodes in my brain:
Why do your results give a moment of 1 Nm?
(I found only 0.002 Nm for 30 degrees at L5SacrumJnt)
And:
Why do you think this is normal?
Could you please let me know what the first column represents in your
findings?
Hope i don’t bother you too much.
> Hello Sylvian,
> something wrongly?
> Thanks, Javed
> — In anyscript@yahoogroups.com, “AnyBody Support” <support@> wrote:
> > Hi Javed,
> > cle.PosMuscle.Fm
> > will be active.
> > Best regards,
> > > Hello Sylvian,
> > gravity, a
> > When
> > > Thanks,
> > > Javed
> > > > Hi Javed,
> > chartFX
> > exactly
> > flexion
> > > > in T12L1 joint.
> > > > Best regards,
> > > > > Hi Sylvain,
> > to me
> > > > > With best regards.
> > > > > Javed
> > > > wrote:
> > > > > > Hi Javed,
> > are
> > > > right,
> > lumbar
> > > > without
> > muscles
> > > > in
> > > > > > the model:
> > the
> > in
> > > > the
> > > > case
> > the
> > and
> > weight is
> > that
> > > > the
> > > > > > Best regards,
> > wrote:
> > > > > > > Hi Sylvain,
> > check
> > > > my
> > > > (Repository6.1)
> > > > without the
> > analyses
> > > > and
> > > > > > found
> > > > model
> > > > > > with
> > take a
> > > > look
> > > > > > in
> > > > =0.999
> > =0.999
> > > > > > > -50 degrees:
> > [0][0]
> > > > > > =0.859
> > =0.995
> > > > > > > -90 degrees:
> > [0][0]
> > > > > > =0.526
> > =0.992
> > in
> > > > {0;
> > > > > > 311;
> > got
> > > > an
> > > > > > idea
> > > > > > > Thanks,
> > > > > > > Javed
> > <support@>
> > > > > > wrote:
> > > > > > > > Hi Javed,
> > force
> > > > > > inT12L1
> > local
> > > > > > coordinate
> > the
> > > > > > reaction
> > be
> > > > able
> > > > > > to
> > to
> > > > > > compare
> > joint
> > > > > > forces,
> > > > muscle
> > > > > > the
> > > > joints.
> > > > > > Then
> > T12L1
> > > > and
> > thorax
> > > > > > whereas
> > addition
> > > > to
> > > > > > the
> > tree
> > > > or
> > > > > > you
> > the
> > > > > > > > Best regards,
> > > > wrote:
> > > > > > > > > Dear AnyBody team,
> > without
> > > > > > muscles
> > > > something
> > > > > > > > strange:
> > joint
> > > > are not
> > resultant
> > > > forces
> > components
> > > > in
> > > > > > the
> > local
> > > > > > systems
> > > > > > > > > change.)
> > on
> > > > the
> > > > > > lumbar
> > other
> > > > > > forces
> > > > > > > > than
> > muscle
> > > > > > forces as
> > > > > > > > i
> > resultant
> > > > > > forces
> > > > > > > > at
> > lumbar
> > > > > > mass? How
> > > > > > > > > Thanks,
> > > > > > > > > javed
Hi Javed,
It is right there is no stiffness in the spine. But remember that all
segments have a mass, so when you switch of the gravity the weight is
not present anymore but inertia forces will remain. You need energy
to move a mass from its static position even with no gravity. So the
presence of the moment is normal.
Now about the magnitude of the moment: the first column in the
results I send is time (from 0 to 1 second). Inertia forces are
dependent of the velocity, so a reason why you don’t have the same
value can be that we didn’t use the same velocity during the
analysis. But the difference is quite important and there might be
another reason. Some parameters must be different. Did you change any
mass properties? Scaled the model or any other modification?
> Hello Sylvian,
in
> structure.
> without gravity).
> And:
your
> findings?
> > Hello Sylvian,
refers to
me.
> > something wrongly?
body”.
without
dof1, and
> > Thanks, Javed
wrote:
> > > Hi Javed,
repository 6
> > > cle.PosMuscle.Fm
Rotation you
corresponding to
rotation).
perform an
If you
that
> > > will be active.
> > > Best regards,
> > > > Hello Sylvian,
Have you
to the
> > > gravity, a
structure.
> > > When
> > > > Thanks,
> > > > Javed
> > > > > Hi Javed,
> > > chartFX
> > > exactly
thorax
> > > flexion
> > > > > in T12L1 joint.
> > > > > Best regards,
wrote:
> > > > > > Hi Sylvain,
clear
> > > to me
> > > > > > With best regards.
> > > > > > Javed
<support@>
> > > > > wrote:
> > > > > > > Hi Javed,
you
> > > are
> > > > > right,
others
> > > lumbar
model
> > > > > without
no
> > > muscles
> > > > > in
> > > > > > > the model:
segment are
> > > the
torque
> > > in
> > > > > the
in this
> > > > > case
against
> > > the
torque
> > > and
> > > weight is
see
> > > that
> > > > > the
change.
> > > > > > > Best regards,
<javed377@>
> > > wrote:
> > > > > > > > Hi Sylvain,
mine
> > > check
> > > > > my
> > > > > (Repository6.1)
but
> > > > > without the
> > > analyses
> > > > > and
> > > > > > > found
L5Sacrum.Incase of
> > > > > model
> > > > > > > with
please
> > > take a
> > > > > look
> > > > > > > in
[0][0]
> > > > > =0.999
[0][0]
> > > =0.999
> > > > > > > > -50 degrees:
> > > [0][0]
> > > > > > > =0.859
[0][0]
> > > =0.995
> > > > > > > > -90 degrees:
> > > [0][0]
> > > > > > > =0.526
[0][0]
> > > =0.992
results
> > > in
> > > > > {0;
> > > > > > > 311;
you
> > > got
> > > > > an
> > > > > > > idea
> > > > > > > > Thanks,
> > > > > > > > Javed
> > > <support@>
> > > > > > > wrote:
> > > > > > > > > Hi Javed,
reaction
> > > force
> > > > > > > inT12L1
and
> > > local
> > > > > > > coordinate
that
> > > the
> > > > > > > reaction
not
> > > be
> > > > > able
> > > > > > > to
You have
> > > to
> > > > > > > compare
postures.
the
> > > joint
> > > > > > > forces,
with no
> > > > > muscle
> > > > > > > the
the
> > > > > joints.
> > > > > > > Then
in
> > > T12L1
> > > > > and
the
> > > thorax
> > > > > > > whereas
in
> > > addition
> > > > > to
> > > > > > > the
model
> > > tree
> > > > > or
> > > > > > > you
using
> > > the
> > > > > > > > > Best regards,
<javed377@>
> > > > > wrote:
> > > > > > > > > > Dear AnyBody team,
model
> > > without
> > > > > > > muscles
found
> > > > > something
> > > > > > > > > strange:
L5Sacrum
> > > joint
> > > > > are not
> > > resultant
> > > > > forces
> > > components
> > > > > in
> > > > > > > the
the
> > > local
> > > > > > > systems
> > > > > > > > > > change.)
acting
> > > on
> > > > > the
> > > > > > > lumbar
there
> > > other
> > > > > > > forces
> > > > > > > > > than
the
> > > muscle
> > > > > > > forces as
> > > > > > > > > i
> > > resultant
> > > > > > > forces
> > > > > > > > > at
the
> > > lumbar
> > > > > > > mass? How
> > > > > > > > > > Thanks,
> > > > > > > > > > javed
