Hi, we are now working with musculo-skeletal simulation of swimming.
We already developed input data, that is, body motion and external
force acting on the human body during swimming.
However, the analysis stops due to the unknown error.
The error message says as follows:
ERROR(OBJ1) : \Repository.6\ARep\Aalborg\Butterfly-Mus1
\ButterflyMus1.Main.any(84) : ‘Study’ : Muscle recruitment
analysis failed, simplex solver reports that solution does not
satisfy all constraints.
Since which part induces this error is not shown, we can not
identify the part of the problem, and therefore can not eliminate
this error.
Could anyone please give us any suggestion for this error?
What a fantastic model. It is really impressive that you have been
able to define such a complex full-body movement. I think I have
partially soled your problem, but it may be instructive for you and
other members to know how to debug a model in a case like this, so I
will explain it in steps:
The error message means that the equilibrium equations do not have
a solution. This means that either there are not enough muscles
internally to carry the loads, or the model is not balanced against
the environment.
I first checked the external balance. In the joints and drivers
file, the pelvis is driven in six degrees of freedom with reactions
switched on. This should be enough.
Then I removed all the muscles by selecting the NoMuscles version
of the body model in the main file. I did this because I wanted a
model that loads and runs faster for debugging. The NoMuscles version
is equipped with joint torque providers on all degrees of freedom so
it should be able to do the InverDynamicAnalysis. I ran it, and it
failed, indicating that there is some other unbalanced element.
Then I ran the ModelInformation operation. This provides a review
list of segments and other stuff. I checked that the model did not
have any segments that did not belong to the body and therefore
needed its own support. There were none.
Then I went to the JointAndDrivers file and replaced all the
driver Reaction.Type to {On}. That made the model run, proving that
the problem is an internal degree of freedom that is not carried.
Then I went on to successively changing “On” to “Off” in these
drivers until the model failed. I noticed that you have introduced
two additional articulations in the knee, but you have not provided
joint torque muscles for these. Leaving the reactions “On” for the
two new degrees of freedom made the model run about half way through
the movement.
Further experiments revealed that there is a problem with the
right shoulder, where I had to leave two of the reactions “On”. I
have not found out why, but this makes the model run all the way in
InverseDynamicAnalysis without muscles.
I then switched the muscles back on to verify that that the model
can run. It does indeed run a few steps, but then one of the shoulder
muscles is causing a problem. I am sure you have had a few of these
with the very large shoulder rotations you are using. I think the
primary problem you will encounter is to get the shoulder muscles
working for these large articulations.
I shall upload the modified JointsAndDrivers file to the files
section of the group. Please do keep us posted on your progress with
this fantastic model.
John
— In anyscript@yahoogroups.com, “Motomu Nakashima”
> this error.
> our simulation data are located at
> http://www.hei.mei.titech.ac.jp/research/motomu/Repository.zip
> (6.34MB)
> and open ButterflyMus1.Main.any at Repository.6-Butterfly
> /Arep/Aalborg/Butterfly-Mus1 .
> In this case, the analysis stops at time step 6.
> Thank you in advance,
> Motomu
Thank you very much for your very instructive comments.
After your comment, we also found other suggestions to the problems
similar to ours in this newsgroup.
We are now testing all those things.
If things go well, I would like to present the results
at ISCSB conference in Taiwan.
Motomu Nakashima
wrote:
> Dear Motomu,
and
I
> 1. The error message means that the equilibrium equations do not
have
against
> the environment.
> 2. I first checked the external balance. In the joints and drivers
reactions
> 3. Then I removed all the muscles by selecting the NoMuscles
version
version
so
> 4. Then I ran the ModelInformation operation. This provides a
review
> 5. Then I went to the JointAndDrivers file and replaced all the
that
> 6. Then I went on to successively changing “On” to “Off” in these
provided
through
> the movement.
> 7. Further experiments revealed that there is a problem with the
in
> 8. I then switched the muscles back on to verify that that the
model
shoulder
these
with
> Best regards,
> John
swimming.
external
> > this error.
> > (6.34MB)
> > Motomu
