I encountered a problem of simulating a seated model.
I used local anthropometric scaling to analyse the seated model.
However, it produce errors.
The errors are as follows e.g.:
For your information, I adjusted the value for mass and height for the model. But when I changed the value below 180 cm, the model seem to have errors when I do the analysis.
However, when i changed the value more than 180cm, I can do the analysis without any problem.
Why the errors occur? Is the any relation with the ratio of the segment length?
I hope any member from this forum can help me to solve this problem. I am really appreciate any reply from members in this forum.
Then you can change the mass and the height of the subject in your AnyManUniform.any file.
The biggest reason why you model may fail during the kinematics analysis when human’s height is less that 180cm may be that the leg becomes shorter than before. So I would rather to adjust a parameter of the chair for shorter legs:
AnyFolder DrvPos = {
AnyVar PelvisSeatLinXPos = 0.05; ///< Position of the pelvis on the seat
AnyVar SeatGlobalLinYPos = 0; ///< Seat Height
AnyVar SeatGlobalZRot = 0; ///< Forward seat inclination
AnyVar BackRestHeadResRotZPos = 0; ///< Rotation of the head rest wrt the back rest
AnyVar GlobalLegRestRotZPos = 30; ///< Inclination of the leg rest
AnyVar GlobalBackRestRotZPos = 0; ///< Back rest inclination
AnyVar [b]LegRestFootRestLinYPos [/b]= 0.1 + 0.1 + 0.05 ; ///< Position of the footrest along the leg rest
}; // DrvPos
Attached please find a modified version of your model which includes all the changes that I mentioned above.
