Error Loading a file in GaitUniMiami
I was trying to load my own data into GaitUniMiami and i followed all
the steps as specified. I got to step 5 where i need to load my model
and i got the following error :
Loading Main : “C:\Documents and
Settings\marakilo\Desktop\MyRepository7\Application\Examples\GaitUniMiami\GaitUn
iMiami.main.any”
Scanning…
Parsing…
Constructing model tree…
Linking identifiers…
ERROR(SCR.PRS9) : C:\Documents and
Settings\marakilo\Desktop\MyRepository7\Application\Examples\GaitUniMiami\Enviro
nment.any(277)
: ‘FPBFx1_2’ : Unresolved object
Deleting last loaded model…Done.
Model loading skipped
I have no idea what does FPBFx1_2 file does and haven’t modified it.
Can i get help in it for i can load the model and able to continue to
the next steps ?
Please could you specify what is the problem and tell me waht i should
do to creect it.
I have uploaded GaitUniMiami in Mike Arakilo’s Files
thanks for your help
Regards
Hey Mike,
The error you get is in the Enviroment.any file, where the force plates are
created. However, it looks like your c3d data contains Analog data where the
forces are given different names, and possibly also that they are measured in a
different way (you can verify this by comparing the Trail13.Analog.any file and
your own new file). It is therefore always a good idea when you start a new
model with a different setup to open the Environment.any file, comment out
everything except the definition of the GlobalRef in the top. In one of the
later steps, you will have to re-create this file to reflect how your forces
were measured, but you can wait with that until after you have gotten the
kinematics running.
Michael Skipper Andersen
----- Original Message -----
Sent: Thursday, May 08, 2008 2:52 PM
Subject: [AnyScript] Error Loading a file in GaitUniMiami
Loading Main : "C:\Documents and
iMiami.main.any"
Scanning…
Parsing…
nment.any(277)
the next steps ?
do to creect it.
Regards
Hi Micheal
Thanks for your valuable reply.
The names looked different as on our vicon system it is giving us Fx1 Fx2 …
instead of FPBFx1_2 …
I understood that i need to recreate this environment file at a later stage and
i commented out everything in environment file except the global ref frame as
you mentioned.
I got another error just in the end before loading stating the following:
Loading Settings Script from : 'C:\Documents and Settings\marakilo\Local
Settings\Application Data\AnyBody Technology\AnyBody.3.x.x\Settings.anyst
Settings loaded
iMiami.main.any”
Scanning…
Parsing…
Evaluating constants…
Configuring model…
Evaluating model…
ERROR(OBJ1) : C:\Documents and
Settings\marakilo\Desktop\MyRepository7\Application\Examples\GaitUniMiami\Marker
Mover.any(68) : ‘LinDrv’ : Time, ‘t’, has an invalid value for this
interpolation
I didn’t understand either what this is about because i mention in the main file
that time starts at 2.24 and ends at 3.34 with 110 steps AS given my
MArakilo.main in the c3d2any conversion.
is there anyway to fix this ?
The file is still uploaded under my section area …
Thanks very much for your reply
Regarads
From: Michael Skipper Andersen <msandersen60@hotmail.com>
Sent: Thursday, May 8, 2008 3:46:10 PM
Subject: Re: [AnyScript] Error Loading a file in GaitUniMiami
Hey Mike,
different way (you can verify this by comparing the Trail13.Analog. any file and
model with a different setup to open the Environment. any file, comment out
kinematics running.
Settings\marakilo\ Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami
GaitUniMiami. main.any”
Scanning…
Parsing…
Linking identifiers. …
Environment. any(277)
the next steps ?
do to creect it.
Regards
________________________________________________________________________________\
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Hey Mike,
I actually think this is a problem that many people will see, but it has slipped
our minds in the documentation. So now I will take the opportunity to explain
the problem and also the solution - it is not so difficult.
The problem is that GaitApplication2 writes out the joint coordinates in a file
named output-euler.txt and these are used to drive the joint angles in the
AnyBody model. This file contains time as the first column. When you start a new
model, all you have is the old version of this file. Since it is most likely
that the start and end time in the old analysis does not match the analysis you
try to do now, this file will cause the error you see below.
Since you do not care what is in this file now and it will be overwritten later
on by GaitApplication2 anyway, you should simply modify the file such that the
first timestep (the number in the first column) is before or at least at the
timestep of your new tStart in AnyBody. Putting 0.0 instead of whatever number
is there already will normally do the trick.
I hope this helps you.
Michael
Sent: Thursday, May 08, 2008 5:09 PM
Hi Micheal
and i commented out everything in environment file except the global ref frame
as you mentioned.
Settings loaded
iMiami.main.any”
Scanning…
Parsing…
Configuring model…
Evaluating model…
interpolation
file that time starts at 2.24 and ends at 3.34 with 110 steps AS given my
Regarads
Hey Mike,
kinematics running.
Scanning…
Parsing…
the next steps ?
do to creect it.
Regards
Hi Micheal
I was checking the euler-output file as you mentioned for me that the time
starts at 2.69 and ends at 4.81.
My data has a tStart of 3.24 and a tEnd of 4.34 so it should not give me this
kind of error
Furthermore i opened the txt with excel and change the first number in the first
column to 0.0269 and i think something has been lost or something went wrong and
the file size got lesser maybe becuase it is a delimited file . so i got the
following error during compiling.
Evaluating model…
ERROR(OBJ.FILE1) : C:\Documents and
Settings\marakilo\Desktop\MyRepository7\Application\Examples\GaitUniMiami\Joints
AndDriversOptimized.any(179) : ‘Jntdriver.FileName’ : Problem with file :
C:\Documents and
Settings\marakilo\Desktop\MyRepository7\Application\Examples\GaitUniMiami\output
-euler.txt(line #: 29) : Too many values on line in data file.
C:\Documents and
-euler.txt : Too many values on multiple lines in data file.
AndDriversOptimized.any(171) : ‘Jntdriver’ : Parameter values are not
monotonically increasing.
To keep it on the safe side, i opened the file again in text and changed 2.69 to
0.0269 and during compiling i got the same error as before without changing the
file size.
The following error is
Evaluating model…
interpolation
What can i do to fix this ?
Regards
Sent: Thursday, May 8, 2008 4:22:14 PM
Hey Mike,
named output-euler. txt and these are used to drive the joint angles in the
Michael
Hi Micheal
you mentioned.
Loading Settings Script from : 'C:\Documents and Settings\marakilo\ Local
Settings\Applicatio n Data\AnyBody Technology\AnyBody. 3.x.x\Settings. anyst
Settings loaded
Loading Main : “C:\Documents and Settings\marakilo\ Desktop\MyReposi
tory7\Applicatio n\Examples\ GaitUniMiami\ GaitUniMiami. main.any”
Scanning…
Parsing…
Configuring model…
Evaluating model…
ERROR(OBJ1) : C:\Documents and Settings\marakilo\ Desktop\MyReposi
tory7\Applicatio n\Examples\ GaitUniMiami\ MarkerMover. any(68) : ‘LinDrv’ :
Time, ‘t’, has an invalid value for this interpolation
Regarads
From: Michael Skipper Andersen <msandersen60@ hotmail.com>
Hey Mike,
kinematics running.
Scanning…
Parsing…
the next steps ?
do to creect it.
Regards
know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/
;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ
Hey Mike,
I checked your file last night and found that you have specified tStart and tEnd
in your AnyBody model to be 2.69 s and 3.69 s (as far as I remember). If you
check again in the main file you got after converting the c3d file to AnyScript,
you will see that you have data in the interval from 3.69 s to 4.69 s. If you
change this in the main file, the model will load (at least it did for me).
Michael
To: anyscript@yahoogroups.comFrom: marakilo@yahoo.comDate: Fri, 9 May 2008
02:34:19 -0700Subject: Re: [AnyScript] Error Loading a file in GaitUniMiami
Hi MichealI was checking the euler-output file as you mentioned for me that the
time starts at 2.69 and ends at 4.81.My data has a tStart of 3.24 and a tEnd of
4.34 so it should not give me this kind of errorFurthermore i opened the txt
with excel and change the first number in the first column to 0.0269 and i think
something has been lost or something went wrong and the file size got lesser
maybe becuase it is a delimited file . so i got the following error during
compiling.Evaluating model…ERROR(OBJ.FILE1) : C:\Documents and
C:\Documents and
-euler.txt(line #: 29) : Too many values on line in data file.ERROR(OBJ.FILE1) :
C:\Documents and
C:\Documents and
-euler.txt : Too many values on multiple lines in data file.ERROR(OBJ1) :
C:\Documents and
monotonically increasing.To keep it on the safe side, i opened the file again in
text and changed 2.69 to 0.0269 and during compiling i got the same error as
before without changing the file size.The following error isEvaluating
model…ERROR(OBJ1) : C:\Documents and
interpolationWhat can i do to fix this ?Regards----- Original Message ----From:
Michael Skipper Andersen <msandersen60@hotmail.com>To:
anyscript@yahoogroups.comSent: Thursday, May 8, 2008 4:22:14 PMSubject: Re:
[AnyScript] Error Loading a file in GaitUniMiamiHey Mike,I actually think this
is a problem that many people will see, but it has slipped our minds in the
documentation. So now I will take the opportunity to explain the problem and
also the solution - it is not so difficult.The problem is that GaitApplication2
writes out the joint coordinates in a file named output-euler. txt and these are
used to drive the joint angles in the AnyBody model. This file contains time as
the first column. When you start a new model, all you have is the old version of
this file. Since it is most likely that the start and end time in the old
analysis does not match the analysis you try to do now, this file will cause the
error you see below.Since you do not care what is in this file now and it will
be overwritten later on by GaitApplication2 anyway, you should simply modify the
file such that the first timestep (the number in the first column) is before or
at least at the timestep of your new tStart in AnyBody. Putting 0.0 instead of
whatever number is there already will normally do the trick.I hope this helps
you.Best regardsMichael----- Original Message ----- From: Mike Arakilo To:
anyscript@yahoogrou ps.com Sent: Thursday, May 08, 2008 5:09 PMSubject: Re:
[AnyScript] Error Loading a file in GaitUniMiamiHi MichealThanks for your
valuable reply.The names looked different as on our vicon system it is giving us
Fx1 Fx2 … instead of FPBFx1_2 …I understood that i need to recreate this
environment file at a later stage and i commented out everything in environment
file except the global ref frame as you mentioned.I got another error just in
the end before loading stating the following:Loading Settings Script from :
'C:\Documents and Settings\marakilo\ Local Settings\Applicatio n Data\AnyBody
Technology\AnyBody. 3.x.x\Settings. anystSettings loadedLoading Main :
"C:\Documents and Settings\marakilo\ Desktop\MyReposi tory7\Applicatio
main.any"Scanning…Parsing…Constructing model tree…Linking identifiers.
…Evaluating constants…Configuring model…Evaluating model…ERROR(OBJ1) :
n\Examples\ GaitUniMiami\ MarkerMover. any(68) : ‘LinDrv’ : Time, ‘t’, has an
invalid value for this interpolationDeleting last loaded model…Done.Model
loading skippedI didn’t understand either what this is about because i mention
in the main file that time starts at 2.24 and ends at 3.34 with 110 steps AS
given my MArakilo.main in the c3d2any conversion.is there anyway to fix this
?The file is still uploaded under my section area …Thanks very much for your
replyRegarads----- Original Message ----From: Michael Skipper Andersen
<msandersen60@ hotmail.com>To: anyscript@yahoogrou ps.comSent: Thursday, May 8,
2008 3:46:10 PMSubject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHey
Mike,The error you get is in the Enviroment.any file, where the force plates are
kinematics running.Best regardsMichael Skipper Andersen----- Original Message
----- From: marakilo To: anyscript@yahoogrou ps.com Sent: Thursday, May 08, 2008
2:52 PMSubject: [AnyScript] Error Loading a file in GaitUniMiamiHiI was trying
to load my own data into GaitUniMiami and i followed allthe steps as specified.
I got to step 5 where i need to load my modeland i got the following error
:Loading Main : "C:\Documents andSettings\marakilo\ Desktop\MyReposi
…ERROR(SCR.PRS9) : C:\Documents andSettings\marakilo\ Desktop\MyReposi
tory7\Applicatio n\Examples\ GaitUniMiami\ Environment. any(277): ‘FPBFx1_2’ :
Unresolved objectDeleting last loaded model…Done.Model loading skippedI have
no idea what does FPBFx1_2 file does and haven’t modified it.Can i get help in
it for i can load the model and able to continue tothe next steps ?Please could
you specify what is the problem and tell me waht i shoulddo to creect it.I have
uploaded GaitUniMiami in Mike Arakilo’s Filesthanks for your
helpRegards[Non-text portions of this message have been removed]____________
_________ _________ _________ _________ _________ _Be a better friend,
newshound, and know-it-all with Yahoo! Mobile. Try it now. http://mobile.
yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ[Non-text portions of this
message have been removed][Non-text portions of this message have been
removed]__________________________________________________________Be a better
friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ[Non-text portions of
Discover the new Windows Vista
http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE
Hey Micheal
Indeed there was this mistyped mistake i don’t know how i wrote it like this.
anyway the model was loaded successfully and i have changed the orientation
matrix to 2*pi,x becuase it was not accepting 0,x
I got to step 7 but i m not quite sure I understood what they mean by “In
comment the MarkerPlacementStudy again”
Can I get explanation for it please ?
Regards
Sent: Friday, May 9, 2008 10:52:09 AM
Subject: RE: [AnyScript] Error Loading a file in GaitUniMiami
Hey Mike,
Michael
To: anyscript@yahoogrou ps.comFrom: marakilo@yahoo. comDate: Fri, 9 May 2008
compiling.Evaluatin g model…ERROR( OBJ.FILE1) : C:\Documents and
JointsAndDrivers Optimized. any(179) : 'Jntdriver.FileName ’ : Problem with file
: C:\Documents and Settings\marakilo\ Desktop\MyReposi tory7\Applicatio
n\Examples\ GaitUniMiami\ output-euler. txt(line #: 29) : Too many values on
line in data file.ERROR(OBJ. FILE1) : C:\Documents and Settings\marakilo
GaitUniMiami\ JointsAndDrivers Optimized. any(179) : 'Jntdriver.FileName ’ :
Problem with file : C:\Documents and Settings\marakilo\ Desktop\MyReposi
tory7\Applicatio n\Examples\ GaitUniMiami\ output-euler. txt : Too many values
on multiple lines in data file.ERROR(OBJ1) : C:\Documents and Settings\marakilo
Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami\ JointsAndDrivers
Optimized. any(171) : ‘Jntdriver’ : Parameter values are not monotonically
increasing.To keep it on the safe side, i opened the file again in text and
changed 2.69 to 0.0269 and during compiling i got the same error as before
without changing the file size.The following error isEvaluating model…ERROR(
OBJ1) : C:\Documents and Settings\marakilo\ Desktop\MyReposi tory7\Applicatio
invalid value for this interpolationWhat can i do to fix this ?Regards---- -
Andersen <msandersen60@ hotmail.com>To: anyscript@yahoogrou ps.comSent:
Thursday, May 8, 2008 4:22:14 PMSubject: Re: [AnyScript] Error Loading a file in
GaitUniMiamiHey Mike,I actually think this is a problem that many people will
see, but it has slipped our minds in the documentation. So now I will take the
opportunity to explain the problem and also the solution - it is not so
difficult.The problem is that GaitApplication2 writes out the joint coordinates
in a file named output-euler. txt and these are used to drive the joint angles
in the AnyBody model. This file contains time as the first column. When you
start a new model, all you have is the old version of this file. Since it is
most likely that the start and end time in the old analysis does not match the
analysis you try to do now, this file will cause the error you see below.Since
you do not care what is in this file now and it will be overwritten later on by
simply modify the file such that the first timestep (the number in the first
column) is before or at least at the timestep of your new tStart in AnyBody.
Putting 0.0 instead of whatever number is there already will normally do the
trick.I hope this helps you.Best regardsMichael- ---- Original Message -----
From: Mike Arakilo To: anyscript@yahoogrou ps.com Sent: Thursday, May 08, 2008
5:09 PMSubject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHi
MichealThanks for your valuable reply.The names looked different as on our vicon
system it is giving us Fx1 Fx2 … instead of FPBFx1_2 …I understood that i
need to recreate this environment file at a later stage and i commented out
everything in environment file except the global ref frame as you mentioned.I
got another error just in the end before loading stating the following:Loading
n\Examples\ GaitUniMiami\ GaitUniMiami. main.any"Scanning. …Parsing.
…Constructing model tree…Linking identifiers. …Evaluating constants…
Configuring model…Evaluating model…ERROR( OBJ1) : C:\Documents and
MarkerMover. any(68) : ‘LinDrv’ : Time, ‘t’, has an invalid value for this
interpolationDeleti ng last loaded model…Done. Model loading skippedI didn’t
understand either what this is about because i mention in the main file that
time starts at 2.24 and ends at 3.34 with 110 steps AS given my MArakilo.main in
the c3d2any conversion.is there anyway to fix this ?The file is still uploaded
under my section area …Thanks very much for your replyRegarads- ---- Original
Message ----From: Michael Skipper Andersen <msandersen60@
hotmail.com> To: anyscript@yahoogrou ps.comSent: Thursday, May 8, 2008 3:46:10
PMSubject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHey Mike,The
error you get is in the Enviroment.any file, where the force plates are created.
However, it looks like your c3d data contains Analog data where the forces are
given different names, and possibly also that they are measured in a different
way (you can verify this by comparing the Trail13.Analog. any file and your own
new file). It is therefore always a good idea when you start a new model with a
different setup to open the Environment. any file, comment out everything except
the definition of the GlobalRef in the top. In one of the later steps, you will
have to re-create this file to reflect how your forces were measured, but you
can wait with that until after you have gotten the kinematics running.Best
regardsMichael Skipper Andersen---- - Original Message ----- From: marakilo To:
anyscript@yahoogrou
ps.com Sent: Thursday, May 08, 2008 2:52 PMSubject: [AnyScript] Error Loading a
file in GaitUniMiamiHiI was trying to load my own data into GaitUniMiami and i
followed allthe steps as specified. I got to step 5 where i need to load my
modeland i got the following error :Loading Main : "C:\Documents andSettings
GaitUniMiami. main.any"Scanning. …Parsing. …Constructing model tree…Linking
identifiers. …ERROR(SCR. PRS9) : C:\Documents andSettings\ marakilo
Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami\ Environment.
any(277): ‘FPBFx1_2’ : Unresolved objectDeleting last loaded model…Done. Model
loading skippedI have no idea what does FPBFx1_2 file does and haven’t modified
it.Can i get help in it for i can load the model and able to continue tothe next
steps ?Please could you specify what is the problem and tell me waht i shoulddo
to creect it.I have uploaded
GaitUniMiami in Mike Arakilo’s Filesthanks for your helpRegards[ Non-text
portions of this message have been removed]____ ________ _________ _________
_________ _________ _________ Be a better friend, newshound, and know-it-all
with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/ ;ylt=Ahu06i62sR
8HDtDypao8Wcj9tA cJ[Non-text portions of this message have been removed][Non-
_________ _________ _________ _________ Be a better friend, newshound, and
;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ[Non-text portions of this message have been
removed]
http://search. msn.com/results. aspx?q=windows+ vista&mkt= en-US&form= QBRE
Hey Micheal
Sorry again for bothering you
In step 8 of the GaitUniMiami , i m not sure i am understanding what to do.
How am I gonna set the initial conditions ? Should I run GaitApplication2 first
Under what conditions i should adjust toe segment lengths in the
LocakMarkerCoordinateAndSize.any file ? Is there anyoutpurt file i m getting
first for i can rely on ?
Thanks for your reply
Sent: Friday, May 9, 2008 11:52:54 AM
Hey Micheal
comment the MarkerPlacementStud y again”
Regards
Hey Mike,
Michael
Andersen <msandersen60@ hotmail.com> To: anyscript@yahoogrou ps.comSent:
anyscript@yahoogrou
removed]
Hey Mike,
The reason you could not use 0,x is because AnyScript is very strict in its
typechecking on whether or not a number is a float (and 0 is treated as an
interger). If you write 0.0 it will work for you.
In the main file, you have three “AnyBodyStudy”: 1) MarkerModelStudy, 2)
MarkerPlacementStudy and 3) OptStudy. The two first of these are used to help
you write out the marker trajectories and the ModelGait.txt file that
GaitApplication2 needs as input. All step 7 is asking you to do is to make sure
that you have the MarkerPlacementStudy included (I am pretty sure it is
commented out in the original GaitUniMiami).
Michael
03:52:54 -0700Subject: Re: [AnyScript] Error Loading a file in GaitUniMiami
Hey MichealIndeed there was this mistyped mistake i don’t know how i wrote it
like this.anyway the model was loaded successfully and i have changed the
orientation matrix to 2*pi,x becuase it was not accepting 0,xI got to step 7 but
i m not quite sure I understood what they mean by "In comment the
MarkerPlacementStudy again"Can I get explanation for it please ?Regards-----
<msandersen60@hotmail.com>To: anyscript@yahoogroups.comSent: Friday, May 9, 2008
10:52:09 AMSubject: RE: [AnyScript] Error Loading a file in GaitUniMiamiHey
Mike,I checked your file last night and found that you have specified tStart and
tEnd in your AnyBody model to be 2.69 s and 3.69 s (as far as I remember). If
you check again in the main file you got after converting the c3d file to
AnyScript, you will see that you have data in the interval from 3.69 s to 4.69
s. If you change this in the main file, the model will load (at least it did for
me).I hope this helps you.Best regardsMichael To: anyscript@yahoogrou
ps.comFrom: marakilo@yahoo. comDate: Fri, 9 May 2008 02:34:19 -0700Subject: Re:
[AnyScript] Error Loading a file in GaitUniMiamiHi MichealI was checking the
euler-output file as you mentioned for me that the time starts at 2.69 and ends
at 4.81.My data has a tStart of 3.24 and a tEnd of 4.34 so it should not give me
this kind of errorFurthermore i opened the txt with excel and change the first
number in the first column to 0.0269 and i think something has been lost or
something went wrong and the file size got lesser maybe becuase it is a
delimited file . so i got the following error during compiling.Evaluatin g
model…ERROR( OBJ.FILE1) : C:\Documents and Settings\marakilo\ Desktop\MyReposi
tory7\Applicatio n\Examples\ GaitUniMiami\ JointsAndDrivers Optimized. any(179)
: 'Jntdriver.FileName ’ : Problem with file : C:\Documents and
output-euler. txt(line #: 29) : Too many values on line in data file.ERROR(OBJ.
FILE1) : C:\Documents and Settings\marakilo\ Desktop\MyReposi tory7\Applicatio
n\Examples\GaitUniMiami\ JointsAndDrivers Optimized. any(179) :
'Jntdriver.FileName ’ : Problem with file : C:\Documents and Settings\marakilo
Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami\ output-euler. txt :
Too many values on multiple lines in data file.ERROR(OBJ1) : C:\Documents and
JointsAndDrivers Optimized. any(171) : ‘Jntdriver’ : Parameter values are not
model…ERROR( OBJ1) : C:\Documents and Settings\marakilo\ Desktop\MyReposi
Time, ‘t’, has an invalid value for this interpolationWhat can i do to fix this
?Regards---- - Original Message ----From: Michael SkipperAndersen <msandersen60@
hotmail.com>To: anyscript@yahoogrou ps.comSent: Thursday, May 8, 2008 4:22:14
PMSubject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHey Mike,I
the problem and also the solution - it is not so difficult.The problem is that
GaitApplication2 writes out the joint coordinates in a file named output-euler.
txt and these are used to drive the joint angles in the AnyBody model. This file
contains time as the first column. When you start a new model, all you have is
the old version of this file. Since it is most likely that the start and end
time in the old analysis does not match the analysis you try to do now, this
file will cause the error you see below.Since you do not care what is in this
file now and it will be overwritten later on by GaitApplication2 anyway, you
shouldsimply modify the file such that the first timestep (the number in the
first column) is before or at least at the timestep of your new tStart in
AnyBody. Putting 0.0 instead of whatever number is there already will normally
do the trick.I hope this helps you.Best regardsMichael- ---- Original Message
----- From: Mike Arakilo To: anyscript@yahoogrou ps.com Sent: Thursday, May 08,
2008 5:09 PMSubject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHi
Settings\Applicatio n Data\AnyBodyTechnology\AnyBody. 3.x.x\Settings.
anystSettings loadedLoading Main : "C:\Documents and Settings\marakilo
Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami\ GaitUniMiami.
main.any"Scanning. …Parsing. …Constructing model tree…Linking identifiers.
…Evaluating constants… Configuring model…Evaluating model…ERROR( OBJ1) :
invalid value for this interpolationDeleti ng last loaded model…Done. Model
replyRegarads- ---- Original Message ----From: Michael Skipper Andersen
<msandersen60@hotmail.com> To: anyscript@yahoogrou ps.comSent: Thursday, May 8,
kinematics running.Best regardsMichael Skipper Andersen---- - Original Message
----- From: marakilo To: anyscript@yahoogroups.com Sent: Thursday, May 08, 2008
:Loading Main : "C:\Documents andSettings\ marakilo\ Desktop\MyReposi
tory7\Applicatio n\Examples\ GaitUniMiami\ GaitUniMiami. main.any"Scanning.
…Parsing. …Constructing model tree…Linking identifiers. …ERROR(SCR. PRS9) :
C:\Documents andSettings\ marakilo\ Desktop\MyReposi tory7\Applicatio
n\Examples\ GaitUniMiami\ Environment. any(277): ‘FPBFx1_2’ : Unresolved
objectDeleting last loaded model…Done. Model loading skippedI have no idea
what does FPBFx1_2 file does and haven’t modified it.Can i get help in it for i
can load the model and able to continue tothe next steps ?Please could you
uploadedGaitUniMiami in Mike Arakilo’s Filesthanks for your helpRegards[
Non-text portions of this message have been removed]____ ________ _________
;ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ[Non-text portions of this message have been
removed][Non- text portions of this message have been removed]
__ _________
_________ _________ _________ _________ _________ Be a better friend, newshound,
and know-it-all with Yahoo! Mobile. Try it now. http://mobile. yahoo.com/
removed] ____________ _________ _________ _________ _________ _________
_Discover the new Windows Vistahttp://search. msn.com/results. aspx?q=windows+
vista&mkt= en-US&form= QBRE[Non-text portions of this message have been
Invite your mail contacts to join your friends list with Windows Live Spaces.
It’s easy!
<a href=“http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us”>http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=
en-us</a>
Hey Mike,
What step 8 asks you to do is to prepare the initial guess for the local
optimization performed by GaitApplication2. In the Mannequin.any file, you will
find all the joint coordinates defined, and if you change these, you move the
model, you have in the MarkerPlacementStudy, around. So what you should do is to
move your model over such that it is “close” to the measured markers (the gray
dots in the model view). How well it has to be done depends on how much it will
take to get GaitApplication2 to find the solution. Therefore step, 8-12 is going
to be an interative process until you have gotten the result you want. It is a
good idea to first just move the man very roughly close to the measured markers
such he at least is not facing the wrong way and are not meters from the
markers. Then continue though step 9-12 and see how it goes. If GaitApplication2
fails, you will have to improve your guess(es).
However, at this stage, when you load your model, the measured markers will not
be visble before you run SetInitialConditions in the MarkerPlacementStudy (this
is found in Operations->MarkerPlacementStudy->SetInitialConditions).It is also
very important to remember that this SetInitialConditions has to be run before
you save the ModelGait.txt file else GaitApplication2 will fail right at the
beginning.
Michael
05:20:18 -0700Subject: Re: [AnyScript] Error Loading a file in GaitUniMiami
Hey Micheal Sorry again for bothering you In step 8 of the GaitUniMiami , i m
not sure i am understanding what to do.How am I gonna set the initial conditions
? Should I run GaitApplication2 first ?Under what conditions i should adjust toe
segment lengths in the LocakMarkerCoordinateAndSize.any file ? Is there
anyoutpurt file i m getting first for i can rely on ?Thanks for your reply-----
Original Message ----From: Mike Arakilo <marakilo@yahoo.com>To:
anyscript@yahoogroups.comSent: Friday, May 9, 2008 11:52:54 AMSubject: Re:
[AnyScript] Error Loading a file in GaitUniMiamiHey MichealIndeed there was this
mistyped mistake i don’t know how i wrote it like this.anyway the model was
loaded successfully and i have changed the orientation matrix to 2*pi,x becuase
it was not accepting 0,xI got to step 7 but i m not quite sure I understood what
they mean by "In comment the MarkerPlacementStud y again"Can I get explanation
for it please ?Regards----- Original Message ----From: Michael Skipper Andersen
<msandersen60@ hotmail.com>To: anyscript@yahoogrou ps.comSent: Friday, May 9,
2008 10:52:09 AMSubject: RE: [AnyScript] Error Loading a file in GaitUniMiamiHey
hotmail.com> To: anyscript@yahoogrou ps.comSent: Thursday, May 8, 2008 4:22:14
__ _________
removed]
__________ _________ _________ _________ _________ _________ _Be a
better friend, newshound, and know-it-all with Yahoo! Mobile. Try it now.
http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ[Non-text portions
It’s easy!
en-us</a>
Hey Micheal
I have moved the model in the x direction by roughly close to the markers which
i cant see anymore since they are overlaping but i think there is some
difference in knee flexion. I can see the heel of the markers are a bit high
than the heel of the model ( slightly higher). Doest it make a difference or
GaitApplicaiton2 will fix it ?
Supposing I have the file ModelGait.txt and this is the <modelfile> for
GaitApplication2 , waht will be the <studyfile> ?
Regards
Sent: Friday, May 9, 2008 1:38:02 PM
Hey Mike,
model, you have in the MarkerPlacementStud y, around. So what you should do is
to move your model over such that it is “close” to the measured markers (the
gray dots in the model view). How well it has to be done depends on how much it
will take to get GaitApplication2 to find the solution. Therefore step, 8-12 is
going to be an interative process until you have gotten the result you want. It
is a good idea to first just move the man very roughly close to the measured
markers such he at least is not facing the wrong way and are not meters from the
be visble before you run SetInitialCondition s in the MarkerPlacementStud y
(this is found in Operations-> MarkerPlacementS tudy->SetInitial Conditions) .It
is also very important to remember that this SetInitialCondition s has to be run
before you save the ModelGait.txt file else GaitApplication2 will fail right at
the beginning.
Michael
segment lengths in the LocakMarkerCoordina teAndSize. any file ? Is there
Original Message ----From: Mike Arakilo <marakilo@yahoo. com>To:
anyscript@yahoogrou ps.comSent: Friday, May 9, 2008 11:52:54 AMSubject: Re:
for it please ?Regards---- -
Original Message ----From: Michael Skipper Andersen <msandersen60@ hotmail.com>
To: anyscript@yahoogrou ps.comSent: Friday, May 9, 2008 10:52:09 AMSubject: RE:
[AnyScript] Error Loading a file in GaitUniMiamiHey Mike,I checked your file
last night and found that you have specified tStart and tEnd in your AnyBody
model to be 2.69 s and 3.69 s (as far as I remember). If you check again in the
main file you got after converting the c3d file to AnyScript, you will see that
you have data in the interval from 3.69 s to 4.69 s. If you change this in the
main file, the model will load (at least it did for me).I hope this helps
you.Best regardsMichael To: anyscript@yahoogrou ps.comFrom: marakilo@yahoo.
comDate: Fri, 9 May 2008 02:34:19 -0700Subject: Re: [AnyScript] Error Loading a
file in GaitUniMiamiHi MichealI was checking the euler-output file as you
mentioned for me that the time starts at 2.69 and ends at 4.81.My data has a
so it should not give me this kind of errorFurthermore i opened the txt with
Desktop\MyReposi tory7\Applicatio n\Examples\GaitUniM iami\ JointsAndDrivers
Optimized. any(179) : 'Jntdriver.FileName ’ : Problem with file : C:\Documents
n\Examples\ GaitUniMiami\ output-euler. txt : Too many values on multiple lines
in data file.ERROR(OBJ1) : C:\Documents and Settings\marakilo\ Desktop\MyReposi
tory7\Applicatio n\Examples\ GaitUniMiami\ JointsAndDrivers Optimized. any(171)
: ‘Jntdriver’ : Parameter values are not monotonically increasing.To keep it on
the safe side, i opened the file again in text and changed 2.69 to 0.0269 and
during compiling i got the same error as before without changing the file
size.The following error isEvaluating model…ERROR( OBJ1) : C:\Documents and
interpolationWhat can i do to fix this ?Regards---- - Original Message ----From:
Michael SkipperAndersen <msandersen60@ hotmail.com> To: anyscript@yahoogrou
ps.comSent: Thursday, May 8, 2008 4:22:14 PMSubject: Re: [AnyScript] Error
Loading a file in
GaitApplication2 anyway, you shouldsimply modify the file such that the first
timestep (the number in the first column) is before or at least at the timestep
Settings\Applicatio n Data\AnyBodyTechnol ogy\AnyBody. 3.x.x\Settings.
identifiers. …Evaluating constants… Configuring model…Evaluating
Time, ‘t’, has an invalid value for this interpolationDeleti ng last loaded
model…Done. Model loading skippedI didn’t understand either what this is about
because i mention in the main file that time starts at 2.24 and ends at 3.34
with 110 steps AS given my MArakilo.main in the c3d2any conversion.is there
anyway to fix this ?The file is still uploaded under my section area …Thanks
very much for your replyRegarads- ---- Original Message ----From: Michael
Skipper Andersen <msandersen60@ hotmail.com> To: anyscript@yahoogrou ps.comSent:
Thursday, May 8, 2008 3:46:10 PMSubject: Re: [AnyScript] Error Loading a file in
GaitUniMiamiHey Mike,The error you get
is in the Enviroment.any file, where the force plates are created. However, it
looks like your c3d data contains Analog data where the forces are given
different names, and possibly also that they are measured in a different way
(you can verify this by comparing the Trail13.Analog. any file and your own new
anyscript@yahoogrou ps.com Sent: Thursday, May 08, 2008 2:52 PMSubject:
[AnyScript] Error Loading a file in GaitUniMiamiHiI was trying to load my own
allthe steps as specified. I got to step 5 where i need to load my modeland i
got the following error :Loading Main : "C:\Documents andSettings\ marakilo
…ERROR(SCR. PRS9) : C:\Documents andSettings\ marakilo\ Desktop\MyReposi
Unresolved objectDeleting last loaded model…Done. Model loading skippedI have
uploadedGaitUniMiam i in Mike Arakilo’s Filesthanks for your helpRegards[
_________ Be a better friend, newshound, and know-it-all with Yahoo! Mobile.
Try it now. http://mobile. yahoo.com/ ;ylt=Ahu06i62sR 8HDtDypao8Wcj9tA
cJ[Non-text portions of this message have been removed][Non- text portions of
_________ _________ Be a better friend, newshound, and know-it-all with Yahoo!
Mobile. Try it now. http://mobile. yahoo.com/ ;ylt=Ahu06i62sR 8HDtDypao8Wcj9tA
cJ[Non-text portions of this message have been removed] ____________ _________
_________ _________ _________ _________ Discover the new Windows Vistahttp://
search. msn.com/results. aspx?q=windows+ vista&mkt= en-US&form= QBRE[Non-text
Mobile. Try it now. http://mobile. yahoo.com/ ;_ylt=Ahu06i62sR 8HDtDypao8Wcj9tA
It’s easy!
http://spaces. live.com/ spacesapi. aspx?wx_action= create&wx_ url=/friends.
aspx&mkt= en-us
Hey Micheal, in step 11 I am making ModelGait.txt File and then they are asking
me to open the StudyGait.txt.
StudyGait is the old file , shouldn’t I create StudyGait.txt same as I did for
the ModelGait for it can fit my data ?
Regards
Sent: Friday, May 9, 2008 2:22:00 PM
Hey Micheal
Regards
Hey Mike,
the beginning.
Michael
Loading a file in
It’s easy!
aspx&mkt= en-us
Hey Mike,
Yes, StudyGait.txt should reflect your new setup - i.e. tStart, tEnd, nStep
should match what you have in AnyBody. It is also in this file that you can
specify which type of analysis you want GaitApplication2 to perform.
Regarding if GaitApplication2 will fix the difference in the heel depends then
the answer is probably yes. But the heel marker is one of the few markers that
are excluded from the optimization of the local marker coordinates since some of
them have to be used to define coordinate systems, but if the markers are placed
correctly, then GaitApplication2 will find the motion that minimizes the errors
between your marker on the model and the marker you have measured. If you look
in the file DataForConfigFile.any, then you can see what the options are set to
  • this is the file that writes out the ModelGait.txt file by using various
    string operations. The explanation of all the keywords can be found in the
    documentation for GaitApplication2.
Michael
06:31:11 -0700Subject: Re: [AnyScript] Error Loading a file in GaitUniMiami
me to open the StudyGait.txt.StudyGait is the old file , shouldn’t I create
StudyGait.txt same as I did for the ModelGait for it can fit my data
?Regards----- Original Message ----From: Mike Arakilo <marakilo@yahoo.com>To:
anyscript@yahoogroups.comSent: Friday, May 9, 2008 2:22:00 PMSubject: Re:
[AnyScript] Error Loading a file in GaitUniMiamiHey MichealI have moved the
model in the x direction by roughly close to the markers which i cant see
anymore since they are overlaping but i think there is some difference in knee
flexion. I can see the heel of the markers are a bit high than the heel of the
model ( slightly higher). Doest it make a difference or GaitApplicaiton2 will
fix it ?Supposing I have the file ModelGait.txt and this is the <modelfile> for
GaitApplication2 , waht will be the <studyfile> ?Regards----- Original Message
----From: Michael Skipper Andersen <msandersen60@ hotmail.com>To:
anyscript@yahoogrou ps.comSent: Friday, May 9, 2008 1:38:02 PMSubject: RE:
[AnyScript] Error Loading a file in GaitUniMiamiHey Mike,What step 8 asks you to
do is to prepare the initial guess for the local optimization performed by
GaitApplication2. In the Mannequin.any file, you will find all the joint
coordinates defined, and if you change these, you move the model, you have in
the MarkerPlacementStud y, around. So what you should do is to move your model
over such that it is “close” to the measured markers (the gray dots in the model
view). How well it has to be done depends on how much it will take to get
GaitApplication2 to find the solution. Therefore step, 8-12 is going to be an
interative process until you have gotten the result you want. It is a good idea
to first just move the man very roughly close to the measured markers such he at
least is not facing the wrong way and are not meters from the markers. Then
continue though step 9-12 and see how it goes. If GaitApplication2 fails, you
will have to improve your guess(es).However, at this stage, when you load your
model, the measured markers will not be visble before you run
SetInitialCondition s in the MarkerPlacementStud y (this is found in
Operations-> MarkerPlacementS tudy->SetInitial Conditions) .It is also very
important to remember that this SetInitialCondition s has to be run before you
beginning. Best regardsMichaelTo: anyscript@yahoogrou ps.comFrom:
marakilo@yahoo. comDate: Fri, 9 May 2008 05:20:18 -0700Subject: Re: [AnyScript]
Error Loading a file in GaitUniMiamiHey Micheal Sorry again for bothering you In
step 8 of the GaitUniMiami , i m not sure i am understanding what to do.How am I
gonna set the initial conditions ? Should I run GaitApplication2 first ?Under
what conditions i should adjust toe segment lengths in the LocakMarkerCoordina
teAndSize. any file ? Is there anyoutpurt file i m getting first for i can rely
on ?Thanks for your reply----- Original Message ----From: Mike Arakilo
<marakilo@yahoo. com>To: anyscript@yahoogrou ps.comSent: Friday, May 9, 2008
11:52:54 AMSubject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHey
MichealIndeed there was this mistyped mistake i don’t know how i wrote it like
this.anyway the model was loaded successfully and i have changed the orientation
matrix to 2*pi,x becuase it was not accepting 0,xI got to step 7 but i m not
quite sure I understood what they mean by "In comment the MarkerPlacementStud y
again"Can I get explanation for it please ?Regards---- -Original Message
----From: Michael Skipper Andersen <msandersen60@ hotmail.com> To:
tStart of 3.24 and a tEnd of 4.34so it should not give me this kind of
errorFurthermore i opened the txt with excel and change the first number in the
first column to 0.0269 and i think something has been lost or something went
wrong and the file size got lesser maybe becuase it is a delimited file . so i
got the following error during compiling.Evaluatin g model…ERROR( OBJ.FILE1) :
n\Examples\ GaitUniMiami\ JointsAndDrivers Optimized. any(179) :
txt(line #: 29) : Too many values on line in data file.ERROR(OBJ. FILE1) :
n\Examples\GaitUniM iami\ JointsAndDrivers Optimized. any(179) :
Desktop\MyReposi tory7\Application\Examples\ GaitUniMiami\ output-euler. txt :
PMSubject: Re: [AnyScript] Error Loading a file inGaitUniMiamiHey Mike,I
AnyBody.Putting 0.0 instead of whatever number is there already will normally do
the trick.I hope this helps you.Best regardsMichael- ---- Original Message -----
Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami\GaitUniMiami.
<msandersen60@ hotmail.com> To: anyscript@yahoogrou ps.comSent: Thursday, May 8,
Mike,The error you getis in the Enviroment.any file, where the force plates are
to load my own data into GaitUniMiami and i followedallthe steps as specified. I
_________ _________ __________________ Be a better friend, newshound, and
__ _________
Discover the new Windows Vistahttp:// search. msn.com/results. aspx?q=windows+
removed]
__ ________ _________ _________ _________ _________ _________ Be a
http://mobile. yahoo.com/ ;ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ[Non-text
portionsof this message have been removed]
____________ _________ _________ _________ _________ _________ Invite your mail
contacts to join your friends list with Windows Live Spaces. It’s
easyhttp://spaces. live.com/ spacesapi. aspx?wx_action= create&wx
url=/friends. aspx&mkt= en-us[Non-text portions of this message have been
removed]
___________ _________ _________ _________ _________ _________ _Be a
Connect to the next generation of MSN MessengerÂ
<a href=“http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&source=wlmailtagline”>http://imagine-msn.com/messenger/launch80/default.aspx?locale=en-us&source=wlmai
ltagline</a>
Hey Micheal
GaitApplication2 is giivn me eorr loading StudyGait
It is saying Faile to open the study configuration file
Shall the files be on specific location?
I am location in command prompt the GaitApplication2 and writing the following
GaitApplication2 ModelFile StudyFile
I tried the following also
GaitApplicaiton2 “ModelFile.txt” “StudyFile.txt” and gave the same error about
StudyFile
ModelFile and StudyFile are not in the same location as GaitApplication.
Shall I specify the path for each also for example
GiatApplicaiton2 “T:/…/ModelFile.txt” “T:/…/StudyFile.txt” ?
Thanks for you reply
Regards
Sent: Friday, May 9, 2008 2:59:04 PM
Hey Mike,
in the file DataForConfigFile. any, then you can see what the options are set to
Michael
me to open the StudyGait.txt. StudyGait is the old file , shouldn’t I create
?Regards---- - Original Message ----From: Mike Arakilo <marakilo@yahoo. com>To:
anyscript@yahoogrou ps.comSent: Friday, May 9, 2008 2:22:00 PMSubject: Re:
GaitApplication2 , waht will be the <studyfile> ?Regards---- - Original Message
<msandersen60@ hotmail.com> To: anyscript@yahoogrou ps.comSent: Friday, May 9,
2008 1:38:02 PMSubject: RE: [AnyScript] Error Loading a file in GaitUniMiamiHey
Mike,What step 8 asks you to do is to prepare the initial guess for the local
markers. Then
LocakMarkerCoordina teAndSize. any file ? Is there anyoutpurt file i m getting
first for i can rely on ?Thanks for your reply----- Original Message ----From:
Mike Arakilo <marakilo@yahoo. com>To: anyscript@yahoogrou ps.comSent: Friday,
May 9, 2008 11:52:54 AMSubject: Re: [AnyScript] Error Loading a file in
GaitUniMiamiHey MichealIndeed there was this mistyped mistake i don’t know how i
wrote it like this.anyway the model was loaded successfully and i have changed
the orientation matrix to 2*pi,x becuase it was not accepting 0,xI got to step 7
but i m not quite sure I understood what they mean by "In comment the
MarkerPlacementStud y again"Can I get explanation for it please ?Regards----
-Original Message ----From: Michael Skipper Andersen <msandersen60@ hotmail.com>
have specified tStart and tEnd in your AnyBody model to be 2.69 s and 3.69 s
(as far as I remember). If you check again in the main file you got after
converting the c3d file to AnyScript, you will see that you have data in the
interval from 3.69 s to 4.69 s. If you change this in the main file, the model
will load (at least it did for me).I hope this helps you.Best regardsMichael To:
02:34:19 -0700Subject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHi
4.34so it should not give me this kind of errorFurthermore i opened the txt with
. so i got the following error during compiling.Evaluatin g model…ERROR(
Desktop\MyReposi tory7\Application\ Examples\ GaitUniMiami\ output-euler. txt :
values are not monotonically increasing.To keep it on the safe side, i opened
the file again in text and changed 2.69 to 0.0269 and during compiling i got the
same error as before without changing the file size.The following error
isEvaluating model…ERROR( OBJ1) : C:\Documents and Settings\marakilo
Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami\ MarkerMover. any(68)
: ‘LinDrv’ : Time, ‘t’, has an invalid value for this interpolationWhat can i do
to fix this ?Regards---- - Original Message ----From: Michael SkipperAndersen
2008 4:22:14 PMSubject: Re: [AnyScript] Error Loading a file inGaitUniMiamiHey
Mike,I actually think this is a problem that many people will see, but it has
slipped our minds in the documentation. So now I will take the opportunity to
explain the problem and also the solution - it is not so difficult.The problem
are used to drive the joint angles in the AnyBody model. This file contains time
as the first column. When you start a new model, all you have is the old version
of this file. Since it is most likely that the start and end time in the old
be overwritten later on by GaitApplication2 anyway, you shouldsimply modify the
at least at the timestep of your new tStart in AnyBody.Putting 0.0 instead of
you.Best regardsMichael- ---- Original Message ----- From: Mike Arakilo To:
[AnyScript] Error
Loading a file in GaitUniMiamiHi MichealThanks for your valuable reply.The
instead of FPBFx1_2 …I understood that i need to recreate this environment
file at a later stage and i commented out everything in environment file except
the global ref frame as you mentioned.I got another error just in the end before
loading stating the following:Loading Settings Script from : 'C:\Documents and
Settings\marakilo\ Local Settings\Applicatio n Data\AnyBodyTechnol ogy\AnyBody.
3.x.x\Settings. anystSettings loadedLoading Main : "C:\Documents and
Message ----From: Michael Skipper Andersen <msandersen60@ hotmail.com> To:
anyscript@yahoogrou ps.comSent: Thursday, May 8, 2008 3:46:10 PMSubject: Re:
[AnyScript] Error Loading a file in GaitUniMiamiHey Mike,The error you getis in
the Enviroment.any file, where the force plates are created. However, it looks
like your c3d data contains Analog data where the forces are given different
names, and possibly also that they are measured in a different way (you can
Trail13.Analog. any file and your own new file). It is therefore always a good
idea when you start a new model with a different setup to open the Environment.
any file, comment out everything except the definition of the GlobalRef in the
top. In one of the later steps, you will have to re-create this file to reflect
how your forces were measured, but you can wait with that until after you have
gotten the kinematics running.Best regardsMichael Skipper Andersen---- -
Original Message ----- From: marakilo To: anyscript@yahoogrou ps.com Sent:
Thursday, May 08, 2008 2:52 PMSubject: [AnyScript] Error Loading a file in
followedallthe steps as specified. I got to step 5 where i need to load my
_________ _________ ____________ ______ Be a better friend, newshound, and
__
_________ _________ _________ _________ _________ _________ Be a better friend,
yahoo.com/ ;ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ[Non-text portions of this
message have been removed] ____________ _________ _________ _________ _________
_________ Discover the new Windows Vistahttp:// search. msn.com/results.
aspx?q=windows+ vista&mkt= en-US&form= QBRE[Non-text portions of this message
have been removed]
cJ[Non-text portionsof this message have been removed]
this message have been removed] ____________ _________ _________ _________
_________ _________ Invite your mail contacts to join your friends list with
Windows Live Spaces. It’s easyhttp://spaces. live.com/ spacesapi.
___ ________ _________ _________ _________
removed]
http://imagine- msn.com/messenge r/launch80/ default.aspx? locale=en- us&source=
wlmailtagline
Hey,
If you call GaitApplication2 with no arguments, it assumes that the two files
(ModelGait.txt and StudyGait.txt) are found in the current directory. So the
easiest thing to do is to copy the GaitApplication2.exe in next to your model
(in the GaitUniMiami or whatever you have called your model folder). Then you
won’t have to worry about paths or copying files.
Michael
07:18:41 -0700Subject: Re: [AnyScript] Error Loading a file in GaitUniMiami
Hey MichealGaitApplication2 is giivn me eorr loading StudyGaitIt is saying Faile
to open the study configuration fileShall the files be on specific location?I am
followingGaitApplication2 ModelFile StudyFileI tried the following
alsoGaitApplicaiton2 “ModelFile.txt” “StudyFile.txt” and gave the same error
about StudyFileModelFile and StudyFile are not in the same location as
GaitApplication.Shall I specify the path for each also for
exampleGiatApplicaiton2 “T:/…/ModelFile.txt” “T:/…/StudyFile.txt” ?Thanks
for you replyRegards----- Original Message ----From: Michael Skipper Andersen
2:59:04 PMSubject: RE: [AnyScript] Error Loading a file in GaitUniMiamiHey
Mike,Yes, StudyGait.txt should reflect your new setup - i.e. tStart, tEnd, nStep
specify which type of analysis you want GaitApplication2 to perform.Regarding if
GaitApplication2 will fix the difference in the heel depends then the answer is
probably yes. But the heel marker is one of the few markers that are excluded
from the optimization of the local marker coordinates since some of them have to
be used to define coordinate systems, but if the markers are placed correctly,
then GaitApplication2 will find the motion that minimizes the errors between
your marker on the model and the marker you have measured. If you look in the
file DataForConfigFile. any, then you can see what the options are set to - this
is the file that writes out the ModelGait.txt file by using various string
documentation for GaitApplication2.Best regardsMichaelTo: anyscript@yahoogrou
ps.comFrom: marakilo@yahoo. comDate: Fri, 9 May 2008 06:31:11 -0700Subject: Re:
[AnyScript] Error Loading a file in GaitUniMiamiHey Micheal, in step 11 I am
making ModelGait.txt File and then they are asking me to open the StudyGait.txt.
the ModelGait for it can fit my data ?Regards---- - Original Message ----From:
May 9, 2008 2:22:00 PMSubject: Re: [AnyScript] Error Loading a file in
GaitUniMiamiHey MichealI have moved the model in the x direction by roughly
close to the markers which i cant see anymore since they are overlaping but i
think there is some difference in knee flexion. I can see the heel of the
markers are a bit high than the heel of the model ( slightly higher). Doest it
make a difference or GaitApplicaiton2 will fix it ?Supposing I have the file
ModelGait.txt and this is the <modelfile> for GaitApplication2 , waht will be
the <studyfile> ?Regards---- - Original Message ----From: Michael Skipper
Andersen<msandersen60@ hotmail.com> To: anyscript@yahoogrou ps.comSent: Friday,
May 9, 2008 1:38:02 PMSubject: RE: [AnyScript] Error Loading a file in
GaitUniMiamiHey Mike,What step 8 asks you to do is to prepare the initial guess
for the local optimization performed by GaitApplication2. In the Mannequin.any
file, you will find all the joint coordinates defined, and if you change these,
you move the model, you have in the MarkerPlacementStud y, around. So what you
should do is to move your model over such that it is “close” to the measured
markers (the gray dots in the model view). How well it has to be done depends on
how much it will take to get GaitApplication2 to find the solution. Therefore
step, 8-12 is going to be an interative process until you have gotten the result
you want. It is a good idea to first just move the man very roughly close to the
measured markers such he at least is not facing the wrong way and are not meters
from the markers. Thencontinue though step 9-12 and see how it goes. If
GaitApplication2 fails, you will have to improve your guess(es).However, at this
stage, when you load your model, the measured markers will not be visble before
you run SetInitialCondition s in the MarkerPlacementStud y (this is found in
what conditions i should adjust toe segment lengths in theLocakMarkerCoordina
last night and found that youhave specified tStart and tEnd in your AnyBody
wrong and the file size got lesser maybe becuase it is a delimited file. so i
JointsAndDrivers Optimized. any(171) : ‘Jntdriver’ : Parametervalues are not
GaitApplication2writes out the joint coordinates in a file named output-euler.
5:09 PMSubject: Re: [AnyScript] ErrorLoading a file in GaitUniMiamiHi
n\Examples\ GaitUniMiami\MarkerMover. any(68) : ‘LinDrv’ : Time, ‘t’, has an
different way (you can verify this by comparing theTrail13.Analog. any file and
…Parsing…Constructing model tree…Linking identifiers. …ERROR(SCR. PRS9) :
___________
removed]
8HDtDypao8Wcj9tA cJ[Non-text portions ofthis message have been removed]
removed]
___ ________ _________ _________ _________ _________ _________ Be a
http://mobile. yahoo.com/ ;ylt=Ahu06i62sR 8HDtDypao8Wcj9tA cJ[Non-text portions
_________ _________ _________ _________ _Connect to the next generation of MSN
Messenger http://imagine- msn.com/messenge r/launch80/ default.aspx? locale=en-
us&source= wlmailtagline[Non-text portions of this message have been
Explore the seven wonders of the world
http://search.msn.com/results.aspx?q=7+wonders+world&mkt=en-US&form=QBRE
Hey Micheal
I was glad that gaitapplication2 was running with success and after several
iteration it gave me Finished Scaling with Success !
I have attached to this email printscree of the result in gaitapplicaiton2
I went threw step 13 and i noticed that i did outcomment everything in
environment file except the global reference area
i went to OptStudy and made calibration of the muscles and then ran kinematic
analysis but i got so many warmings for stretched out muscles and it failed at
step16.
WARNING(OBJ.MCH.MUS2) :
T:\AnyScripts\MyRepository7\Body\AAUHuman\Leg\MusPar.any(89) :
‘PeroneusBrevisPar’ : Muscle without strength : The muscle has been
stretched too much
ERROR(OBJ.MCH.KIN3) :
T:\AnyScripts\MyRepository7\Application\Examples\GaitUniMiami\GaitUniMiami.main.
any(212) : ‘OptStudy’ : Kinematic analysis failed in time step 16
The Model was moving in very weird way.
Can i get help here with waht is going on ?
I have atteched the new model in the file section udner Mike Arakilo Files
Thanks a lot
Waiting for your reply
Sent: Friday, May 9, 2008 3:28:54 PM
Hey,
easiest thing to do is to copy the GaitApplication2. exe in next to your model
Michael
Hey MichealGaitApplicat ion2 is giivn me eorr loading StudyGaitIt is saying
Faile to open the study configuration fileShall the files be on specific
location?I am location in command prompt the GaitApplication2 and writing the
followingGaitApplic ation2 ModelFile StudyFileI tried the following
alsoGaitApplicaiton 2 “ModelFile.txt” “StudyFile.txt” and gave the same error
GaitApplication. Shall I specify the path for each also for exampleGiatApplicai
ton2 “T:/…/ModelFile. txt” “T:/…/StudyFile. txt” ?Thanks for you
replyRegards- ---- Original Message ----From: Michael Skipper Andersen
2008 2:59:04 PMSubject: RE: [AnyScript] Error Loading a file in GaitUniMiamiHey
that you can specify which type of analysis you want GaitApplication2 to
perform.Regarding if GaitApplication2 will fix the difference in the heel
depends then the answer is probably yes. But the heel marker is one of the few
markers that are excluded from the optimization of the local marker coordinates
since some of them have to be used to define coordinate systems, but if the
markers are placed correctly, then GaitApplication2 will find the motion that
minimizes the errors between your marker on the model and the marker you have
measured. If you look in the file DataForConfigFile. any, then you can see what
the options are set to - this is the file that writes out the ModelGait.txt file
by using various string operations. The explanation of all the keywords can be
found in the documentation for GaitApplication2. Best regardsMichaelTo:
Loading a file in GaitUniMiamiHey Micheal, in step 11 I am making ModelGait.txt
File and then they are asking me to open the StudyGait.txt. StudyGait is the old
file , shouldn’t I create StudyGait.txt same as I did for the ModelGait for it
can fit my data ?Regards---- - Original Message ----From: Mike Arakilo
2:22:00 PMSubject: Re: [AnyScript] Error Loading a file in GaitUniMiamiHey
MichealI have moved the model in the x direction by roughly close to the markers
which i cant see anymore since they are overlaping but i think there is some
GaitApplicaiton2 will fix it ?Supposing I have the file ModelGait.txt and this
is the <modelfile> for GaitApplication2 , waht will be the <studyfile>
Michael Skipper Andersen<msandersen 60@ hotmail.com> To: anyscript@yahoogrou
ps.comSent: Friday, May 9, 2008 1:38:02 PMSubject: RE: [AnyScript] Error Loading
a file in GaitUniMiamiHey Mike,What step 8 asks you to do is to prepare the
initial guess for the local optimization performed by GaitApplication2. In the
Mannequin.any file, you will find all the joint coordinates defined, and if you
change these, you move the model, you have in the MarkerPlacementStud y, around.
So what you should do is to move your model over such that it is “close” to the
measured markers (the gray dots in the model view). How well it has to be done
depends on how much it will take to get GaitApplication2 to find the solution.
Therefore step, 8-12 is going to be an interative process until you have gotten
the result you want. It is a good idea to first just move the man very roughly
close to the measured markers such he at least is not facing the wrong way and
are not meters
lengths in theLocakMarkerCoord ina teAndSize. any file ? Is there anyoutpurt
file i m getting first for i can rely on ?Thanks for your reply----- Original
Message ----From: Mike Arakilo <marakilo@yahoo. com>To: anyscript@yahoogrou
ps.comSent: Friday, May 9, 2008 11:52:54 AMSubject: Re: [AnyScript] Error
Loading a file in GaitUniMiamiHey MichealIndeed there was this mistyped mistake
i don’t know how i wrote it like this.anyway the model was loaded successfully
and i have changed the orientation matrix to 2*pi,x becuase it was not accepting
0,xI got to step 7 but i m not quite sure I understood what they mean by "In
comment the MarkerPlacementStud y again"Can I get explanation for it please
?Regards---- -Original Message ----From: Michael Skipper Andersen <msandersen60@
hotmail.com> To: anyscript@yahoogrou ps.comSent: Friday, May 9, 2008 10:52:09
AMSubject: RE: [AnyScript] Error Loading a file in GaitUniMiamiHey Mike,I
found that youhave specified tStart and tEnd in your AnyBody model to be 2.69 s
and 3.69 s (as far as I remember). If you check again in the main file you got
after converting the c3d file to AnyScript, you will see that you have data in
the interval from 3.69 s to 4.69 s. If you change this in the main file, the
model will load (at least it did for me).I hope this helps you.Best
regardsMichael To: anyscript@yahoogrou ps.comFrom: marakilo@yahoo. comDate: Fri,
9 May 2008 02:34:19 -0700Subject: Re: [AnyScript] Error Loading a file in
GaitUniMiamiHi MichealI was checking the euler-output file as you mentioned for
me that the time starts at 2.69 and ends at 4.81.My data has a tStart of 3.24
and a tEnd of 4.34so it should not give me this kind of errorFurthermore i
opened the txt with excel and change the first number in the first column to
0.0269 and i think something has been lost or something went wrong and the file
delimited file. so i got the following error during compiling.Evaluatin g
‘Jntdriver’ : Parametervalues are not monotonically increasing.To keep it on
Loading a file inGaitUniMiamiHey Mike,I actually think this is a problem that
many people will see, but it has slipped our minds in the documentation. So now
I will take the opportunity to explain the problem and also the solution - it is
that GaitApplication2wri tes out the joint coordinates in a file named
output-euler. txt and these are used to drive the joint angles in the AnyBody
model. This file contains time as the first column. When you start a new model,
all you have is the old version of this file. Since it is most likely that the
start and end time in the old analysis does not match the analysis you try to do
now, this file will cause the error you see below.Since you do not care what is
in this file now and it will be overwritten later on by GaitApplication2 anyway,
you shouldsimply modify the file such that the first timestep (the number in the
5:09 PMSubject: Re:
[AnyScript] ErrorLoading a file in GaitUniMiamiHi MichealThanks for your
Data\AnyBodyTechnol ogy\AnyBody. 3.x.x\Settings. anystSettings loadedLoading
Main : "C:\Documents and Settings\marakilo\ Desktop\MyReposi tory7\Applicatio
Settings\marakilo\ Desktop\MyReposi tory7\Applicatio n\Examples
GaitUniMiami\ MarkerMover. any(68) : ‘LinDrv’ : Time, ‘t’, has an invalid value
for this interpolationDeleti ng last loaded model…Done. Model loading skippedI
didn’t understand either what this is about because i mention in the main file
MArakilo.main in the c3d2any conversion.is there anyway to fix this ?The file is
still uploaded under my section area …Thanks very much for your replyRegarads-
---- Original Message ----From: Michael Skipper Andersen <msandersen60@
error you getis in the Enviroment.any file, where the force plates are created.
comparing theTrail13.Analog. any file and your own new file). It is therefore
always a good idea when you start a new model with a different setup to open the
Environment. any file, comment out everything except the definition of the
GlobalRef in the top. In one of the later steps, you will have to re-create this
file to reflect how your forces were measured, but you can wait with that until
after you have gotten the kinematics running.Best regardsMichael Skipper
Andersen---- - Original Message ----- From: marakilo To: anyscript@yahoogrou
marakilo\ Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami
…Parsing… Constructing model tree…Linking identifiers. …ERROR(SCR. PRS9)
: C:\Documents andSettings\ marakilo\ Desktop\MyReposi tory7\Applicatio
removed]
__ _________ _________ _________ _________ _________ _________ Be a
of this message have been removed] ____________ _________ _________ _________
_________ _________ Discover the new Windows Vistahttp:// search.
msn.com/results. aspx?q=windows+ vista&mkt= en-US&form= QBRE[Non-text portions
portions ofthis message have been removed] ____________ _________ _________
_________ _________ _________ Invite your mail contacts to join your friends
list with Windows Live Spaces. It’s easyhttp://spaces. live.com/ spacesapi.
removed] ____________ _________ _________ _________ _________ _________ Connect
us&source= wlmailtagline[ Non-text portions of this message have been
removed]
http://search. msn.com/results. aspx?q=7+ wonders+world& mkt=en-US& form=QBRE
________________________________________________________________________________\
Hey Mike,
Warnings about stretched muscles is because you have not run the calibration
study before running the model with muscles. However, it might be an idea to use
a model without muscles until you get the kinematics right. You can change this
in the HumanModel.any by out commenting the line:
#include
“…\Body\AAUHuman\BodyModels\TrunkNoMusclesTwoLegs\BodyModel_Mus3e.any”
and instead write:
#include
"…\Body\AAUHuman\BodyModels\TrunkNoMusclesTwoLegs\BodyModel_NoMuscles.any
I took at quick look at the picture you uploaded and in the bottom it writes out
the two solutions for the euler angles in the angle joint (in z,y,x order).
From this, my guess is that it is the right ankle that made a strange motion?
This is suggested by the rather large number -1.49, which is inversion/eversion.
This is a fairly common problem and is simply due to the local marker
coordinates of the markers on the feet. As the two markers you have on the feet
(heel and toe) are almost placed on a straight line though the ankle joint, the
inversion/eversion degree of freedom will be very sensitive to placement errors
on these markers.
In order to fix this, you will have to change these local coordinates, and
possibly also the length of the foot, until you get a plausible motion. This you
can do in the LocalMarkerCoordinateAnySize.any file. Also, since you only have
these two markers on the feet, it is going to be a tough job to both optimize
the placement of the ankle markers and the length of the shank at the same time.
It might therefore be a good idea to switch “off” the optimization of the
y-coordinate of the ankle markers. This you can do in the DataForConfigFile.any.
As said before, this part of the modeling is going to be an iterative process
until you get the result you want.
Michael
Sent: Friday, May 09, 2008 5:01 PM
Hey Micheal
step16.
‘PeroneusBrevisPar’ : Muscle without strength : The muscle has been stretched
too much
Thanks a lot
From: Michael Skipper Andersen <msandersen60@hotmail.com>
Hey,
Michael
are not meters
s and 3.69 s (as far as I remember). If you check again in the main file you got
Settings\marakilo\ Desktop\MyReposi tory7\Applicatio n\Examples\ GaitUniMiami
5:09 PMSubject: Re:
.Constructing model tree…Linking identifiers. …Evaluating constants…
value for this interpolationDeleti ng last loaded model…Done. Model loading
skippedI didn’t understand either what this is about because i mention in the
main file that time starts at 2.24 and ends at 3.34 with 110 steps AS given my
…Parsing… Constructing model tree…Linking identifiers. .ERROR(SCR. PRS9)
removed]
locale=en- us&source= wlmailtagline[ Non-text portions of this message have been
removed]
Hey Micheal
Regarding the output of the GaitApplication2, what does it mean ? I have seen
Solution 1 and Solution 2 just for the ankle joint Right and Left and i have
seen 2 values for each. So How can i interpret those values regarding to ( z,y,x
order) ?
Does this means that i need to go to the model and make modifications and put
the solutions values ? If yes, Where can i change them ?
Now regarding the model in GaitUniMiami that i got so far, i have put the models
without the muscles for we can check the kinematics first.
Is it more appropriate for i can put more markers on the foot other than
PlugInGait ?
I have around 60 subjects that i need to run in this model for i can get the
muscles forces, is it for each subject that i will run this kind of interactive
and iterative way ?
Regarding the change of length and coordinates.
The good things here is that the data that I am running are of myself walking
into Vicon. So i can put the length of my foot and my shank … Is that the best
way to do it ?
As you suggested about turning “Off” the optimaziation of the y-coordinate of
the ankle markers … Why is that ? and How can i change it in DataForConfigFile
? I have went into the File but didint know how to change it.
Sorry for those questions, i have been working on it all weekend and I know
there isnt support on weekend.
I have a meeting tomroow afternnon with one of my supervisors and I want to show
him the difference between Gait3D and GaitUniMiami ( with my modifications to
both models) on the same data.
Thanks for your reply and sorry for any incovenience once again
Regards
Sent: Friday, May 9, 2008 4:51:10 PM
Hey Mike,
#include “…\Body\ AAUHuman\ BodyModels\ TrunkNoMusclesTw oLegs\BodyModel_
Mus3e.any”
and instead write:
NoMuscles. any”
on these markers.
can do in the LocalMarkerCoordina teAnySize. any file. Also, since you only have
any.
Michael
----- Original Message -----
Hey Micheal
step16.
WARNING(OBJ. MCH.MUS2) : T:\AnyScripts\ MyRepository7\ Body\AAUHuman
Leg\MusPar. any(89) : ‘PeroneusBrevisPar’ : Muscle without strength : The muscle
has been stretched too much
ERROR(OBJ.MCH. KIN3) : T:\AnyScripts\ MyRepository7\ Application\ Examples
GaitUniMiami\ GaitUniMiami. main.any( 212) : ‘OptStudy’ : Kinematic analysis
Thanks a lot
Hey,
Michael
are not meters
‘Jntdriver’ : Parametervalues are not monotonically increasing.To keep it on the
safe side, i opened the file again in text and changed 2.69 to 0.0269 and during
compiling i got the same error as before without changing the file size.The
5:09 PMSubject: Re:
valuable reply.The names looked different as on our vicon system it is giving us
Fx1 Fx2 … instead of FPBFx1_2 …I understood that i need to recreate this
environment file at a later stage and i commented out everything in environment
file except the global ref frame as you mentioned.I got another error just in
the end before loading stating the following:Loading Settings Script from :
'C:\Documents and Settings\marakilo\ Local Settings\Applicatio n
…Parsing… Constructing model tree…Linking identifiers. .ERROR(SCR. PRS9) :
removed]
removed]
