Hi Søren,
Thanks for your help in tackling my issue. I have taken your advice,
except for where you suggest excluding the human from the model and
then trying to get the environment up and running, I have done the
opposite. I am excluding the wheelchair for now, focusing solely on
the subject movement in space. Using the Runner example in the model
repository, I have successfully loaded all the markers, however now
that I am trying to attach the human to the markers, I have come up
with the following problems:
1.) Every time I get an error, even when it is something simple
like an unresolved object, the next time I run the model I always get
the following error (it makes no sense to me):
ERROR (SYS1): Model Load: Unknown Error
2.) If I then close out of AnyBody and re-start it, running the
model with the fix in it, the model compiles fine and I can continue
working. But I am finding I have to re-start the program every time I
need to correct a small error. Any idea why?
a. I am thinking that maybe I have an infinite loop or something
in my model because just to load the model generally takes over one
minute (60-80 seconds). Loading similar models tends to take about 5-
10, so there may be something wrong with mine…
3.) I have currently commented out the wheelchair wheel hub and
beam markers (because I am going to work on the environment once I
can get the model loaded). Setting up the body to be driven in space
is proving harder than expected – it is kinematically indeterminate
upon loading. I have 306 rigid body d-o-f, however only 276
constraints. I’m not sure where else I can “ground” my model to make
it kinematically determinate so I can get the model to load, which
brings me to my last question…
4.) Lastly, as I had mentioned in a previous post, the very
beginning and end of my file has marker dropout for about half a
second. How can I ever get the model to run in lieu of the fact that
the first couple of frames have two of my markers located at zero due
to dropout? I can never get my SetInitialConditions to run due to
this fact – am I incorrect in thinking this?
Suggestions would be much appreciated! I am uploading my model in
two parts (because it is large) under the title “TEST.zip,” and “text
files for TEST.zip.” Just unzip the text files and put them into the
TEST folder to get the complete model.
Looking forward to hearing back from you!
Thank you,
Sarah R. Dubowsky
