I am using Plug-in-simple-GAIT model from AMMR with a new c3d file.
The new c3d file had new markers which i added to MarkerProtocol but now i am getting this error.
ERROR(SCR.PRS9) : C:/U..s/s..t/D..p/A..z/A..o/A..n/M..s/P..e/S..p/MarkerProtocol-mendeley.any(80) : Defined at : C:/U..s/s..t/D..p/A..z/A..o/T..s/A..p/CreateMarkerDriverClass.any(229) : 'InterpolRef' : Unresolved object
Model loading skipped
Can someone help me resolve this error.
Thank you for your time and help
Best Regards
Abdul Aziz
This is very likeluy because there is a marker defined in the markerprotocol for which no data could be found.
This could happen if you copied an existing protocol and your markers had different naming, or it could be simple typo error.
Please try to click the error message and it will take you to the location in the markerprotocol (line 80) for which it can not find the data. Please ensure you have this marker name in your C3D file. You can view the C3D file data in the modeltree at this location "Main.ModelSetup.C3DFileData"
