Please help me with my design to attach my exoarm with Anybody Human Right Arm. I have attached file here with this thread. How to find nodes in Anybody Human Body?
Dear Arpit Shah,
First, I would recommend you to modify your SolidWorks assembly model before translating it into AnyScript model.
It seems that there are four different parts in your assembly.
I guess that you may like to introduce 3 joints:
1 spherical joint
2 revolute joints -
In order to implement a revolute joint in AnyScript by using SolidWorks, I would recommend you to use an advanced ‘Hinge’ mate rather than using both coincident and concentric mates in your SolidWorks assembly.
By doing that you can avoid over-constrained kinematic situation in your model. -
After translating process is done, you should make your own application using the translated AnyScript files.
I would recommend you to start from a clean ‘StandingModel’ in our repository. Make a copy of that model and try to add your own files.
I did but In chart View I am getting Straight line in all my graphs. Which script I need to focus on.
Please upload your model in the debug section:
http://forum.anyscript.org/forumdisplay.php?f=27
