Just to prove that you can’t please all the people all of the time,
my question relates to a model which is working when I don’t think it
should!!!
I am driving FreePostureMove with MoCap data. I have modelled ground
reaction forces with AnyGeneralMuscle where the AnyMuscleModelUsr1
strength is conditional on ground contact.
During phases of no foot contact there is the potential that dynamic
equilibrium could not be achieved due to MoCap measurement errors.
Therefore I attached `weak’ linear and rotational muscles between the
pelvis and ground. The strength of the weak muscles was 2 magnitude
less than ground contact muscles (ground contact muscles were not too
stiff nor the imaginary muscles too weak to cause ill-conditioning).
The model ran in an ID analysis and continued to run as I reduced the
imaginary muscles’ stiffness until they became zero (well less than
Study.StrongMuscleLimit = 0.001;). Thus implying even during no foot
contact the MoCap data collection was perfect!
Does my approach make sense? How can movement containing inevitable
measurement errors be analysed in the presence of an incomplete set
of external forces?
Your approach do make sense, if you have no foot contact you have
applied the weak muscles between the pelvis and ground which should
be able to carry the load, this should work if it is setup correctly.
I can only think of one possible explanation to that the model still
runs Inv. Dyn. Anal. when there is no strength in the weak muscles,
and it is out of balance, there must be one or more reactions between
the human model and the ground which is active, by accident.
You write that the model is driven by markes, i guess you know this
already but by default a driver adds a reactions of the driven dof,
unless it is switched off, by writing “Reaction.Type={Off}”. If your
model is driven by the markers one of those drivers could have
reactions in them by accident, this would be a direct reaction with
the ground.
Please try to check your drivers for unwanted reactions in general,
by looking at the Constraint.Reaction property of the drivers.
— In anyscript@yahoogroups.com, “jamesshippen” <jamesshippen@…>
wrote:
> Hi
it
> should!!!
ground
dynamic
the
magnitude
too
conditioning).
the
foot
inevitable
> of external forces?
> Thanks
> James
Many thanks for your reply; unfortunately I had set all driver
reactions to Off. I’ll continue to investigate.
On a related matter, when I specify tArray an unknown error is
generated during model load. Any thoughts on a work-around.
As ever…many thanks
James
ERROR : Model load : unknown error
wrote:
> Hi James
correctly.
still
between
your
> the ground.
> Best regards
> — In anyscript@yahoogroups.com, “jamesshippen” <jamesshippen@>
> wrote:
> > Hi
time,
think
> it
> > should!!!
> ground
AnyMuscleModelUsr1
> dynamic
errors.
> the
> magnitude
> too
> conditioning).
> the
than
> foot
> inevitable
set
> > of external forces?
> > Thanks
> > James
PS Perhaps I shouldn’t have used the phrase ‘work-around’ as the
obvious one is tStart/nStep/tEnd.
However I am finding that muscle activity can be very fleeting during
gait (please see the uploaded file shippen_muscle_gait.avi) and
therefore the finer control offered by tArray would be most useful.
Thanks (again)
James
> > Hi James
should
> correctly.
> still
muscles,
> between
this
dof,
> your
with
> > the ground.
general,
> > Best regards
> > wrote:
> > > Hi
> time,
> think
> > it
> > > should!!!
> > ground
> AnyMuscleModelUsr1
> > dynamic
> errors.
between
> > the
> > magnitude
not
> > too
> > conditioning).
reduced
> > the
> than
no
> > foot
> > inevitable
> set
> > > of external forces?
> > > Thanks
> > > James
Thanks (again)
James
> > Hi James
should
> correctly.
> still
muscles,
> between
this
dof,
> your
with
> > the ground.
general,
> > Best regards
> > wrote:
> > > Hi
> time,
> think
> > it
> > > should!!!
> > ground
> AnyMuscleModelUsr1
> > dynamic
> errors.
between
> > the
> > magnitude
not
> > too
> > conditioning).
reduced
> > the
> than
no
> > foot
> > inevitable
> set
> > > of external forces?
> > > Thanks
> > > James
I just tested the tArray initilization. You are quite right: It does
not work, and I also get the unknown error. I have bug-reported the
matter, which is a mechanism we use internally to get bugs tracked
and fixed. Thanks for bringing this to our attention.
In general, any occurrence of “Unknown error” is in principle a bug
regardless of how crazy the model may be. This error message is only
for handling cases that were not anticipated by the programmers, and
ideally there should not be any of those.
It is a great help that you guys report back to us when you find an
unknown error.
John
wrote:
> Hi Søren
> As ever…many thanks
> James
> wrote:
> > Hi James
should
> correctly.
> still
muscles,
> between
this
dof,
> your
with
> > the ground.
general,
> > Best regards
> > wrote:
> > > Hi
> time,
> think
> > it
> > > should!!!
> > ground
> AnyMuscleModelUsr1
> > dynamic
> errors.
between
> > the
> > magnitude
not
> > too
> > conditioning).
reduced
> > the
> than
no
> > foot
> > inevitable
> set
> > > of external forces?
> > > Thanks
> > > James
…any chance of the tArray bug fix making the next software
update? I appreciate all of the functionality could (eventually) be
derived from tStart/nStep/tEnd but the convenience of tArray would be
most useful for my work.
As a supplementary question, I am finding that the activity of
various muscles changes radically between time steps as shown in the
uploaded file shippen_gait_muscle.avi. Is this typical or indicative
of an error by me?
Ta!
James
wrote:
> James,
does
only
and
> unknown error.
> John
> wrote:
> > Hi Søren
> > As ever…many thanks
> > James
> > wrote:
> > > Hi James
have
> should
> > correctly.
> > still
> muscles,
> > between
> this
> dof,
> > your
> with
> > > the ground.
> general,
> > > Best regards
<jamesshippen@>
> > > wrote:
> > > > Hi
> > time,
> > think
> > > it
> > > > should!!!
modelled
> > > ground
> > AnyMuscleModelUsr1
> > > dynamic
> > errors.
> between
> > > the
> > > magnitude
> not
> > > too
> > > conditioning).
> reduced
> > > the
less
> > than
> no
> > > foot
> > > inevitable
incomplete
> > set
> > > > of external forces?
> > > > Thanks
> > > > James
Yes, our chief developer has just located the bug, and it will be
fixed in the next mnor release.
John
wrote:
> Hi
be
be
the
indicative
> of an error by me?
> Ta!
> James
> wrote:
> > James,
> does
the
tracked
bug
> only
> and
an
> > unknown error.
> > John
> > wrote:
> > > Hi Søren
> > > As ever…many thanks
> > > James
> > > wrote:
> > > > Hi James
> have
> > should
> > > correctly.
model
> > > still
> > muscles,
> > > between
know
> > this
driven
> > dof,
If
> > > your
have
reaction
> > with
> > > > the ground.
> > general,
> > > > Best regards
> <jamesshippen@>
> > > > wrote:
> > > > > Hi
the
> > > time,
don’t
> > > think
> > > > it
> > > > > should!!!
> modelled
> > > > ground
> > > AnyMuscleModelUsr1
that
> > > > dynamic
> > > errors.
> > between
> > > > the
> > > > magnitude
were
> > not
> > > > too
> > > > conditioning).
> > reduced
> > > > the
> less
> > > than
during
> > no
> > > > foot
> > > > inevitable
> incomplete
> > > set
> > > > > of external forces?
> > > > > Thanks
> > > > > James
