I would like to include the arms in the Facet Joint model, but if I activate them and try to run a simulation the ‘initial condition’ operation fails because the model is kinematically indeterminate. I understand the two arms need to be driven by the drivers, but I don’t know how to do it. Is it possible to activate pre-defined drivers for the arms?
I had to adjust a couple of references in the files because the model structure was a little bit different. But the content is completely the same as in StandingModel. Please find these files attached.
