#include “…/libdef.any”
// Find a detailed description here
#include “Model/Description.any”
Main =
// Path to draw settings
#path BM_DRAWSETTINGS_FILE “Model/DrawSettings.any”
// Model configuration:
// For more info on body model configuration options please load the model and double click on:
// #include “<ANYBODY_PATH_BODY>\Documentation\BodyModel.parameters.any”
// The Mannequin file specifies load-time positions for all the segments
// in the HumanModel. This is important for the model’s ablity to resolve
// all the kinematic constraints when the model is analyzed.
// The mannequin file also drives those degrees of freedom of the human
// model that are not governed by problem-specific drivers at run time.
#path BM_MANNEQUIN_FILE “Model/Mannequin.any”
// #define BM_TRUNK_MUSCLES CONST_MUSCLES_NONE
// #define BM_LEG_MUSCLES_BOTH CONST_MUSCLES_NONE
// #define BM_ARM_MUSCLES_BOTH CONST_MUSCLES_NONE
// Model of the human body to be used for the analysis
/// The actual model where all components are assembled
AnyFolder Model =
#include "Model/Environment.any"
#include "Model/JointsAndDrivers.any"
//-->Folder for design parameters
AnyFolder Parameters =
AnyVar Distance_From_PelvisContactNode_To_HeelNode = 0.6;
//-->Use of the object name to insert additional objects inside
HumanModel.Trunk.SegmentsLumbar.PelvisSeg =
AnyRefNode ContactNode =
sRel = .Scale({-0.02, -0.18, 0});
AnyDrawRefFrame Drw =
ScaleXYZ = 0.1*{1, 1, 1};
RGB = {1, 0, 0};
AnyBodyStudy Study = {
AnyFolder &Model = .Model;
tEnd = 2.0;
Gravity = {0.0, -9.81, 0.0};
nStep = 11;
FileName = "Output/ForceL5.xml";
UseRefFrameOnOff = On;
AnyRefFrame &ref1 = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.L5Seg;
XMLformatOnOff = On;
AnySeg &L5 = Main.HumanModel.BodyModel.Trunk.SegmentsLumbar.L5Seg;
//include the next line to have a camera in the model
}; // End of study
AnyOperationShellExec ConvertToAPDL=
Show=On;
FileName =".\Output\AnyFE2APDL.0.3\AnyFE2APDL\AnyFE2APDL.exe";
Arguments ="-i .\Output\ForceL5.xml -o .\Output\files_out\ForceL5.txt -t .\Output\APDLTemplate.txt";
WorkDir=".";
// // Include an operation sequence to run all required steps of your application (see Operations tab)
#include “<ANYBODY_PATH_TOOLBOX>\Operations\RunAppSequence.any”
}; //Main
Pavel sir please suggest me how to add the RotMat function and to construct ARefNode I am attaching my anyscrpt sit-up code.
regards
Ali Asadullah Syed
