Filter C3d
How can i desactive the filter that AnyBody apply to my C3D file? No changed but desactived
In the AnyInputC3D class object, you can set ‘ProcessedDataFilterIndex’ value as -1.
Then no filter will be applied to your data.
Just a quick addition. There is also a setting called MarkerFilterIndex, which you should set to -1. The ProcessedDataFilerIndex only apply to the data in the ProcessedData folder whereas the MarkerFilterIndex applies to the data in Marker folder. Have a look in the reference manual.
Michael Skipper Andersen
Associate Professor
The AnyBody Research Project
